Question about Frigidaire Washing Machines
How do I put a replace belt back on a frigidare clothes dryer model fer211as1
    Brigadier General:
  • 3,301 Answers
This is a good look at how http://repair2000.com/wpoolbelt.htm
Posted on May 28, 2011
HOW DO I PUT DRUM BELT ON A PORTABLE HAIER DRYER I HAVE ORDERED THE BELT IT CALLS FOR FROM HAIER COMPANY TWICE AND IT IS STILL TOO LONG MAYBE I AM PUTTING IT ON WRONG help please
Your idler pulley will take up the slack in it. It won't be real tight any way once on. If there is still a lot of slack when ou turn it on and the drum doesn't turn, then take it back. Take the old belt with you so that it can be matched uproperly.
Jan 25, 2015 | Haier HLP140E 115 volt portable dryer...
Making a squlling noise while drying
have you checked the belt drive? Belt may need adjusting or replacement.
Jul 27, 2014 | Frigidaire Brand New Frigidare Dryer Motor...
Need manual for maytag washing machine model As11
probably needs a belt. pull the washer from the wall and tilt it back against the wall, make sure it is stable. then look under and find the belt and replaced from a local vendor.
Jan 02, 2012 | Maytag VRSCDX Night Rod Special Washing...
How to replace a fuse in frigidare model gleq2152ee0
you will need to remove the lid,the the control panel then the front panel needs be removed then the drum need to come out depending on what fuse you are replacing. to remove the belt take off the small access panel on the rear and take the belt off the pulley.
Feb 24, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Belt replacement on a frigidare stacked dryer
Check the below link :-
Paste and copy it in other browser and click enter.
Any further help, let me know.
Thanks for using "Fixya"
Do rate the solution as "Fixya" if 100% satisfied.
Jun 01, 2009 | Frigidaire Dryers
Drum turns very slowly,,makes banging noise
You have something in the path of the belt or the belt has come loose. The motor turning the belt may be loose on the bracket. You can slide the motor back some to tighten it.
Jan 25, 2009 | Frigidaire FGR231A Gas Dryer
Dryer belt broke on my dryer.
I use a putty knife to press against the spring clips to pop the top. Then I use a quarter inch nutdriver to remove the screws holding the front panel on. I remove the wires from the door switch and lift out the front panel. I remove the drum and put the dryer on a work bench or a tailgate. I inspect the blower wheel(most of the time they get loose). I get the ball of lint out of the front panel filter housing. I vacuum out the dryer with my shopvac. I oil the rollers and idler and inspect the drum slides for wear. I loop a new belt rib side down to the drum and set it back in the dryer. With my left hand I drop the belt under the motor pulley and raise up the idler looping the belt on it and let the tension hold the idler. I manually slowly turn the drum to make sure the belt is secure and not twisted. I place the front back on. Snap the top down and give her a try. Piece of cake.
Jan 11, 2009 | Maytag PYE3300 Dryer
Frigidare dryer belt replacment
if your dryer is the one as pictured it is quite a job! I dont feel like writing a bunch of steps that may not even be the right model. Is the pic correct? Ill try to help if it is.
Nov 27, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Hotpoint condenser dryer ctd00
change the drive belt. evidently the belt has stretched to the point the belt tensioning device can no longer do its job. when you change the belt make a diagram of which way the belt is reaved through the tensioning device. if you don't you'll be back here asking how to arrange the belt.
Jun 19, 2008 | Hotpoint TDC32 Electric Dryer
New dryer belt configeration
loop belt around drum gather belt at bottom feed left to right through bracket opening pull up and fit belt around motor shaft flat side of belt will be on bottom side of pulley doward pressure of pulley will put tension on belt
Jun 18, 2008 | Whirlpool LER5636P Electric Dryer
Washing Machines Logo
81 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
