Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
The beater carpet cleaner is not turning - Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
    Master:
    Sergeant:
  • 385 Answers
You may have a broken belt. Hope this gets you going in the right direction.
Posted on May 28, 2011
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
Kenmore model 401.39035900 vacuum cleaner beater problems
probably need a new motor and beater bar.
Feb 20, 2013 | Vacuums
Carpet brush beater bar not working
did you look to see if the belt was broke or stuck
Oct 04, 2011 | Bissell Carpet Cleaner Powerbrush Deep...
Beater bar wont spin
hello rud.... this is due to either a broken belt or lots of carpet fibers or pet fur in the beater bar mechanism. turn it off, unplug it and then turn it on it's side and check to see if the bar turns freely by hand. if it does, you will have to replace the belt assembly.... most dyson's have the belt built in to a plastic housing forcing you to buy a pricey part. Joe
May 15, 2011 | Dyson DC14 All Floors Upright Vacuum...
I have a Hoover Windtunnel vacuum cleaner and new high pile carpet. The vacuum cleaner will not move forward without extreme effort. I have been told that I need a vacuum without a beater bar and that...
you can adjust the height on some vacumes like for bare floors and medium nap it will adjust how far the beater bar is from the carpet see if your is adjustable
Apr 11, 2011 | Vacuums
Beater head makes loud noise on 'carpet' mode
Possibly a belt problem, but more than likely a brushroll problem.
The bearings are cheap and nasty, and are prone to siezing.
If you visit http://www.sparesaver.com/help-and-support/dyson-section/dyson-technical-advice-450/ they have alot of info on repairing dyson cleaners AND they sell the parts, cheapest ive seen online.
Hope that helps
Jun 29, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson dc07 drive for the beater is not functioning.
sounds like your clutch has failed it is very common on the dc07 its not an easy job to fit but it can be done if you want to see how its done then youtube fit dyson clutch its a step by step video of how its done good luck
Nov 02, 2009 | Vacuums
Not working
The bissell shampooers use belts t run the pump and the beater bar. if the master beltbroke which is the one that controls the pump and beater bar then yes the machine will not dispense water or turn the beater bar. it will have to be replaced *the belt that is*
Nov 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
49 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
