Question about Vacuums
Hi, i have a sharp twin energy big wheel 12.0 amps vacuum cleaner and i just need to see how exactly to replace the belt on it (pictures) because when i put in the new one it snaps. it looks simple enough.
SOURCE: Sharp Twin Energy EC-T2840 - no suction
no sound - sounds th like the motor is frozen. this type of vac pulls the air threw the bag so by time i it gets to the motor the air is clean, unlike older vacs. it is possiable as well that a wire to the motor has become disconected. (unlikely) has the vac gotten wet at all or have you vacumed damp areas? it would be the only thing i can think of to lock up the motor. another good test and maybe the first is to take of the belt the brush might be bad and stoping the motor from spinning.
Posted on Sep 26, 2008
SOURCE: i got new belts but the brush wont turn
Make sure the vacuum is on the carpet setting..the brush won't turn on the hard floor setting..
Posted on Dec 28, 2008
  • 22 Answers
SOURCE: how to put on a belt on eureka uno bagless vacuum cleaner
Unplug the vacuum.
Turn it over so you have access to the bottom of the unit (you should see the brushroll)
At the base where the "head" attaches to the body there is a small silver button that you must depress to remove it from the body. Press the button in with a screwdriver or unsharpened pencil while pulling the "head" away from the body.
Use a #2 Philips screwdriver to remove all the large screws from the bottom. They are all the same size and type so you can collect them for safekeeping without worrying about which one goes where. There are 2 smaller screws (if I remember correctly) that are for the upright lock that you do not need to remove. They will be on the small plastic piece near where the bottom brush "head" attaches to the vacuum.
Remove the clear plastic clog cover.
Gently pry the gray cover off. This shouldn't be too difficult as the cover goes loose when you remove the screws.
Flip the gray side over and you should see the innards including the brushroll, the motor, wiring, etc. Facing the assembly like you were looking head-on at the vacuum the belt should be on the right.
Pull up the far end (non-belted end) of the brushroll and then the belted end.
The brushroll should now be free and you should check the teeth on the belted end of the brushroll to ensure none are broken.
Remove the old belt from the motor (also toothed) and replace with new belt (a second spare would be handy to keep around and this is a good opportunity to clean up the air path).
Put toothed end of belt into the belt loop and stretch it a bit to get the toothed end back into place. The belt should auto adjust but just in case you may want to manually rotate the brushroll a few times after replacing the far end (non-toothed end)
Repeat the rest of it in reverse order to put it back.
Posted on Feb 03, 2009
EwingElect
  • 276 Answers
SOURCE: vacuum cleaner won't go - missing a step
In between the filters there's an access panel that can be removed - there may be a blockage there. You should also check your hose for a blockage.
Otherwise you may need to take it to your local Electrolux Service Center. There may be a problem with the pressure board. The machines have a 2 year warranty, not sure what it'd be in your neck of the woods.
Posted on Apr 03, 2009
frcs68
  • 1605 Answers
SOURCE: manual or parts list needed
you can get the parts listing form the following link
http://www.vacorama.com/sharp_vacuum_cleaner_parts.html
Posted on Apr 14, 2009
Replace vacumm belt
Well Marlene, I have belts for the twin energy Sharp uprights, and if you get me an address, I can mail them to you. As for the installation instructions, those would best be posted after you receive the belts and are ready to install. You can call the shop # 269-279-6077, 8 AM - 5:00 PM Mon-Thurs. Fridays after 1:00 PM.
Oct 22, 2013 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
I won't pick up dog hair. It seems to have plenty of suction when I detach the hose.
The reason it won't pick up is because the belt is worn. If the belt is stretched or worn it won't pick up well. Here is the belt you need for this model:
Sharp Vacuum Belt
Jan 30, 2010 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Beater bar does not work
You will most likely either need to replace the belt, or remove roller and clean hair out of the ends to let it spin freely
Aug 16, 2009 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
I need to replace the belt on my Sharp Vacuum Cleaner: Model ECTU4609. Can't find Owner's Manual and can't figure out how it goes on .
i have replaced vacumm belts before .. Normally it is located underneath..flip over the vacumm unscrew some screws.. open the cover..youll see a large roller pin type object remove it carefully noting how it is placed..pull it out.. and replace the belt...you can also clean off the debris while doing this..an added plus..for vacumm maintenace..
PLease indicate whether this has helped you at all ..Thank You
Jul 05, 2009 | Sharp Twin Energy EC-TU4606 Bagged Upright...
How can i keep the belt onmy sharp vacuum
If you have a rug that has tassles or open bits of "carpet tassles," this will injur ANY upright vacuum cleaner. Best way to vacuum a rug is to use a hose with a suction only floor head or small tool on the end.
Jan 29, 2009 | Sharp Twin Energy EC-T2630 Bagged Upright...
It won't ****!
try turning it on and looking at the spindle to make sure the belt is not broken and it is spinning.
Nov 23, 2008 | Sharp Twin Energy EC-T4660 Vacuum
Stopped working
Well it could be the motor, if it is it would cost around $80 or so for a motor. May be better to buy new, thre are a number of good brands out there.
May 12, 2008 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Vacume wont **** opened it up see nothing wrong HELP
If no suction usuallly means a clog, either in the hose and the dirt inlet by the brush roll. Sometimes if the belt is stretched, it won't turn the brush roll under load and it would seem like there is no suction.
Apr 19, 2008 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
Vacuums Logo
155 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
