Question about Troy Bilt 5.5hp Self Propelled Mower
Mower will start for about 5 seconds and then die. I cleaned the air filter and sprayed the carb. still only starts for a few seconds and stops. I also replaced the spark plug. I have a TB1803 21"
  • Troy Master
  • 7,482 Answers
Hi reynolds 859...
Sounds like you have dirt/debris in your carburetor jets or fuel passages.
Check/Clean/Replace your fuel filter if you have one.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 31, 2011
Engine starts after primer bulb is pressed 5 or 6 times, but dies after running a few seconds.
Main jet in carb is clogged. Also check the fuel lines to carb and make sure that they are intact and have no leaks.
Jul 29, 2016 | Toro Recycler 22" 149cc Personal Pace Lawn...
Pushmower won't start?
A few quick steps can help you diagnose the problem. Remove the air filter cover and air filter. Spray a shot of carb cleaner into the carb and try to start the mower. If the mower starts on the prime then you have a fuel issue. Be sure your fuel is fresh (less than a week old. Fuel is bad at 21 days old) and clean or rebuild the carb. If the mower wont start on the prime then it is an ignition or compression problem. Start by checking that the stop cable is pulling the bail off ground sufficiently.
Jul 27, 2014 | Toro Power Lawn Mower
Mtd yardworks walk behind starts then idles down shuts off after 20 seconds whats wromg
Usually when a mower dies, it is a fuel delivery problem. Have you changed the filter? Is the gas fresh. Also has the air filter and spark plug been changed recently? the Carburetor may need to cleaned. Take the air cleaner off and spray some carb cleaner in the throat of the carb. Also, take about 1/3 bottle of carb/fuel system cleaner and add it to the gas in the tank.. For the new mower engines, there is no fine-tune adjustments on the carburetor. Also clean the exterior of the carb with carb spray.
May 20, 2014 | Mtd Garden
Toro Mower wont stay running
The main reason why a mower starts up and then cuts off after a short period of time is because of poor air flow to the carburetor and is most likely a blockage somewhere.
First you should try this. Remove gas cap and filter then place a really thick rag over the top of the carb where the filter was and either blow into the gas tank or wrap a rag around a tapered air chuck and then place the air chuck in the gas tank (with rag fitting snug around chuck) blast it a few times and listen for bubbling, if it's bubbles then you have removed the blockage..
Take the carb off of the mower and clean the carb / jets with a thin piece of wire.
Be sure to clean the gas tank completely and the fuel line.
Check the oil level, some mowers have a low-level oil shut off.
Change the plug out with one thst is reccomended for your engine.
I wouldn't reccomend running the mower without the filter, that causes dirt and grass debri to enter the carb, fuel line and tank.
This should fix the problem, if it don't you should find a lawn mower repair service.
I hope this helps.
May 11, 2013 | Garden
We have a briggs and stratton lawn mower that has very few hours on it but has been in storage for the last 5 years, it starts but dies
Clean the gas tank,after a year gas can turn into a gel which will clog the carb,clean the air filter,check spark plug,and readjust the carb(a small screw on the carb
Sep 03, 2012 | Briggs & Stratton Garden
John deere mower Won't start
Sounds like the carb is varnished up and needs to be rebuilt. They make rebuild kits depending on the carb number and you can rebuild it.
May 05, 2017 | Garden
Mower starts and stops with in a few seconds
Ok your not getting fuel into the carburetor it sounds. This could be either your carb.needs cleaned or your low idle screw on the carb. needs adjusted. The idle screw is located directly underneath the air filter. Remove filter and turn clockwise all the way and then counter-clockwise 2 1/4 turns, then test. Adjust until it sounds about right.
Sep 22, 2009 | Toro Lawn Mower With Toro Power Tools
Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Sep 14, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Troy Bilt 5.5hp Self Propelled Mower Logo
149 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
