Question about Pentair Minimax NT Heater
Pentair minimax model 100DSI gives 3 flashes "ignition lockout". I checked both high limit switches, the pressure switch and the thermal fuse...all of these are OK. Any suggestions as to what to check next and how to check it.
  • ANTHONY LONNETT May 28, 2011
    Thanks for the response, but everthing you indicated is already stated in the manual. Please note that the heater continues to go into ignition lockout mode after resets. After each reset, i can detect the spark for about 4 seconds, and then the control unit gives the 3 flashes. In all attempts, i get the 3 flashes, and I do not smell any gas whatsoever, which leads me to believe there isn't even pilot gas. Could it be the gas valve and not the ignition control box. In any case how do i check the control box and the gas valve?
  • 1,940 Answers
IMPORTANT! IT IS RECOMMENDED THAT NO MORE THAN TWO IGNITION ATTEMPTS IN SUCCESSION BE PERFORMED FOR NATURAL GAS SYSTEMS . BEFORE FURTHER IGNITION
ATTEMPTS, WAIT AT LEAST FIVE MINUTES FOR GAS TO CLEAR.
1. Should the main burner fail to light, or flame is not detected during the trial for ignition period the
control will go into lockout and the valve will be turned off immediately.
2. Recovery from lockout requires a manual reset by resetting the thermostat or turning off the ON/OFF switch for a minimum period of 5 seconds.
If the heater continues to go into Ignition Lockout mode:
The ignition control box will spark the pilot and detect that it is lit. These boxes are very reliable but they can fail.
Posted on May 28, 2011
  • Jeremy Moore
    Jeremy Moore May 28, 2011
    If you see the spark, but the pilot is not lighting, it sounds like your gas valve is not operating correctly, or the safety shut-off is closing the valve. If you smell gas, but it is not lighting, your Ignition Control box has probably failed. Here is your Ignition Control box:http://www.aqua-man.com/row_num.asp?Ic=2... The Thermopile Generator can shut off the gas valve if it has deteriorated. Here is the Thermopile Generator:http://www.aqua-man.com/row_num.asp?Ic=2... The gas valve can be found here:http://www.aqua-man.com/schematic.asp?kc...
My temperature says HI. but my temp is not warm
The error code is HL, not hi
This is telling you the high limit switch is tripping(safety feature)
Lack of flow, corroded heat exchanger, bad high limit switch, bad thermal regulator.....
Take these steps to try and get it narrowed down.
With heater off
Locate the high limit switch, unplug the two wires connected to it, put a jumper wire in between those two wires. Turn on the heater, if it fires you need to wait till it heats all the way up. If if heats up with no fault in the cycle then most likely it's a bad high limit switch, if it continues to trip then thermal regulator, it may need both parts.
If it doesn't fire at all then you will probably need a professional
Aug 17, 2014 | Pentair Minimax NT Heater
Model minimax nt std w/ddtc. will not fire up. code E04= fan failure. I can see and hear the fan running. It tries to fire twice then ignition lockout led flashes 3 times=ignition lockout. is there a...
FIRST ... CHECK YOUR FILTER !! IT MUST BE CLEAN ! THERE IS A PRESSURE SWITCH ON THE HEATER WATER INPUT LINE . IT MAY NEED TO BE REPLACED .. JAY.. THE POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA
Jun 20, 2011 | Pentair Pool & Spa
Why does the display show "HI" all the time?
This means that either there is a bad high limit switch, or you are getting a bad burn, or the pump is not moving water fast enough. With the power off remove the panel on the side above the plumbing.
There will be a pressure switch seated right on top of the header, then right below that, there are 2 high limit switches (1" round disks) Most typically, the pressure switch will start to leak and currode the contacts of the high limit switch, but some investigating will be necessary.
Dec 28, 2010 | Pentair Minimax NT Heater
Pentair Minimax Ignitor lockout fault
tried to run 3 x check gas ans ignitor
Jun 05, 2010 | Pentair MINIMAX NT TSI IGNITER
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
Dec 12, 2009 | Coleman Heating & Cooling
Triton minimax 400 pool heater won't ignite
Make sure the gas valve is set to on and thermostats are set properly. Check the pressure switch and high limits for continuity.Check wires for signs of damage, etc..
Jun 27, 2009 | Pentair PUREX MINIMAX HEATER; THERMOSTAT,...
Heater not working
yor heater has 3 high limits and a flame rollout switch(aka thermal fuse). be advised that bypassing safetys is not recommended and is dangerous.these component failures are symptoms. we need to find causes.if limits are failing look at sooted or possibly a nest on your heat exchanger. if its a flame rollout problem look at obstructed burner or oriface.
Jun 22, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Pentair Minimax NT Heater Logo
409 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
