Question about PNY 2GB microSD Memory Card
2GB Micro SD Card Memory Card locked - PNY 2GB microSD Memory Card
  • 827 Answers
Hello Naryan,
Download FE Explorer from the link http://fexplorer.en.softonic.com/download/25347
Insert card into your phone but don't access it through phone.
Run FE Explorer and Open the path C:\system.
You will find a file called mmcstore ,rename the file mmcstore.txt
Copy that file(mmcstore.txt) to your pc and open that file in notepad.
You will find your password in that file to unlock memory card .
Also visit :
http://www.mobiclue.com/recover-memory-card-password-from.html
Posted on Jun 22, 2011
My micro sd card is locked how to unlock
Hi, i have here a photo that will show you on how to remove write protect on a micro SD.
1. You need to insert your micro SD into an adapter. 2. Unlock the micro SD through your adapter as shown below. 3. Once done, your micro SD is no longer write protected. eibraz_16.jpg
NOTE: The lock switch doesn't lock the micro SD into the adapter; The lock switch doesn't lock the data on the micro SD; The lock switch simply tells the "user" not to write. It just says "please, don't write me."
Aug 12, 2011 | SanDisk 2GB microSD Memory Card
When i try to format my micro sd card system shows remove write protect how can i format it
I hope this helps.
Aug 09, 2011 | SanDisk 2GB microSD Memory Card
I have my 2GB MICRO SD MEMORY CARD it automaticaly got locked .Now i dont know the password how to open it ? I am using Nokia C3
Here is a tip that I wrote about SD Cards and how to unlock and lock SD Cards.
If you are getting a memory card locked message then check this out.
How to Unlock SD Card
heatman101
Oct 12, 2010 | SanDisk 2GB microSD Memory Card
My microsd 2gb memory card show write protected.plz help me
You will need to use a regular SD Card Adapter for the micro sd card. The micro sd card itself does not have a write protected switch, but a regular SD card adapter will, and that does affect the microsd card. You just need to put it in an adapter, flip the switch to make sure it knows it is "locked" - so switch it to locked first, then switch it to unlocked. From there you should be able to write to the card. If you can not then it is possible the micro-sd card is having physical problems and may need to be replaced. Here is a little diagram showing how to unlock the card. Before you go though please make sure to rate my answer 4 thumbs up, it is extremely important to me for you to do so. I would be forever grateful!
Here's the link:
http://www.instructables.com/id/Remove-the-write-protection-on-a-Micro-SD./#step1
Thanks
Tim
Oct 12, 2010 | PNY 2GB microSD Memory Card
I have nokia 7210supernova and i got my kingston 2gb micro sd memory card locked and i don`t know any password so how to crack micro sd memory card password
There should be a switch on the side of the memory card, which says 'LOCK' on one end, and 'UNLOCK' on the other end. Switch it to UNLOCK. If this fails, contact first your network provider(Orange, Voadfone...). If they cannot help, you need to contact Nokia. If this fails, contact Kingston. This will help.
pennywise25
Aug 05, 2010 | Kingston 2GB Secure Digital Memory Card
My Micro SD Card No.- Kingston 2GB micro SD Card
My Kingston Micro sd-c02G is Locked i want unlock password
Jan 04, 2010 | Kingston 2GB Secure Digital Memory Card
My memory card has been locked.How to unlock memory card name is micro sd 2GB...........
There should be a very small switch on the card that allows lock / unlock. Simular to old floppy disk.
Nov 24, 2009 | SanDisk 2GB microSD Memory Card
When i want to send picture to memory card it comes up and says its not ready
This happens with 2GB cards.
If you are using an SD adapter (where you put the micro SD in the adapter to make it a full size SD card) and you have an built-in card reader, it may be your card reader is a little old and wasn't made to support 2GB cards.
One other thing to check is that the card is not locked. Look for the lock sysmol in the corner and make sure it is unlocked..
Oct 11, 2009 | SanDisk 2GB microSD Memory Card
The SD m2 2gb Micro does not work on my phone
the card shows sign of a rom ic being lost its firmware
Sep 05, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Lock memory card in nokia 3110C
Use memory card unlocker. Its a small device like card reader. You can unlock your card with that.
May 15, 2008 | Nokia 3110 Cellular Phone
PNY 2GB microSD Memory Card Logo
225 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
