Question about Fisher and Paykel Washing Machines
Dishwash/dry cycle does not complete for "Normal". It stops sometime after the soap container opens and there is water remaining in the bottom of the dishwasher. I have tried changing to one of the other washing options, but the dishwasher will not allow any changes from "Normal".
  • Fisher and P... Master
  • 1,902 Answers
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning and the drain pump is working fine then the problem is with the timer that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on May 28, 2011
There are soapsuds in the bottom of the dishwasher when the cycle is done
This sounds like the dishwasher got the wrong type of soap. It is a real problem to get the wrong soap rinsed out..follow the directions given by the repairman..it may take 5 or 6 cycles... The jet dry is just an extra in this issue...it will be okay when the soap is fully rinsed out.
Feb 02, 2013 | KitchenAid Architect? II K SERIES KUDK03IT...
Leaving a white film on everything
Hi, what you are currently experiencing is as a result of dishwasher detergent, combined with mineral deposits from hard water, which in yurn can leave a white film on the inside of the dishwasher.
You have to clean the dishwasher by sprinkling baking soda onto a damp cloth. Scrub the inside of the dishwasher to remove soap scum, grime and mineral deposits.
Pour 2 cups white vinegar into the bottom of your dishwasher. Turn the dishwasher on and run it on a full cycle. Stop the dishwasher halfway through the wash cycle and allow the vinegar and steam to work on the remaining mineral deposits for 20 minutes before resuming the cycle.
Open the dishwasher and dry the interior with clean, dry cloths. Keep the door propped open for 20 to 30 minutes to allow the dishwasher to dry completely.
Hope it helps....
Jun 27, 2011 | Whirlpool Dishwashers
My indesit idl40 cleans everything, but leaves a film? does not seem to rinse?
Jun 26, 2011 | Indesit Dishwashers
Why does a lot of detergent remain in the soap dispenser after a washing cycle is complete
Was the dispenser cup wet when you added detergent?
Make sure the dispenser cup is dry before adding powdered detergent. If dispenser cup is wet, the detergent can clump.
Is the cycle incomplete?
If the previous cycle did not complete, the detergent can become caked in the dispenser cup if it is left sitting in the dishwasher.
Is the detergent old?
Older detergent exposed to air will clump and not dissolve well, which will cause the dispenser door to stick to the detergent. Replace detergent if necessary and store the detergent in a tightly closed container in a cool dry place.
Is the water temperature too low?
For best washing and drying results, water should be 120oF (49o C) as it enters the dishwasher.
Were items blocking the dispenser that kept it from opening?
Items blocking the detergent dispenser will keep it from opening. Make sure water action can reach the dispenser.
Detergent guidelines
  • Use automatic dishwashing detergent only.
  • Other detergents can produce excessive suds that can overflow out of the dishwasher and reduce washing performance.
  • Store tightly closed detergent in a cool, dry place.
  • Fresh automatic dishwasher detergent results in better cleaning.
  • Add detergents just before starting the cycle.
  • The amount of detergent to use depends on the hardness of your water and the type of detergent.
  • If you use too little, dishes won't be clean.
  • If you use too much in soft water, glassware will etch.
  • Suggested fill amounts are for standard powdered detergent. Amounts may vary if you use liquid or concentrated powdered detergent. Follow instructions on the package when using these detergents.
  • Water hardness can change over a period of time. Find out your water's hardness by asking your local water department, water softener company, or county extension agent.
Nov 25, 2010 | LG Washing Machines
Water won't empty. the bottom remains full
check to see if the water is draining completely. let it fill then drain and cancel unit check to see if this works if not check the drain pump. might also you will want to check soap,alot of times you can add jet dry and lets say a cascade with jet dry shine sometimes can over suds a machine this will cause the unit to keep rinsing to get the soap out,so when it finally ends there is extra water in unit. it is called over sudzing. let me know if my tip helped you.
Feb 23, 2010 | Dishwashers
We have the Whirlpool Gold quiet partner III dishwasher and lately have noticed residue on the dishes after the cleaning cycle is complete. Where is the trap to clean?
Make sure your water is hot, at least 120deg f. Also, use least amount of soap you can get away with. Usually around 2 tablespoons for soft water. Use powdered soap not gel. Gel leaves a tiny residue each load and will clog up plumbing in dw after 4,5,or 6 years. Rinse agent such as Jet Dry is highly recommended.
Try the "Tang" trick. Orange Tang drink mix is mildly acidic. With an empty dishwasher, start and fill, then normal drain. On second fill, add a full jar of Tang then let the dishwasher run for a few minutes. Crack the door to stop the dishwasher and let it sit for several hours or overnight. Then close the door, push start and let the dw run through the remaining cycle. This will sometimes clean out the crud in the water lines.
Hope this helps! Ken
Jan 06, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
The wash cycle runs and runs.
Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
The whole process uses about 2 gallons of water.
Sep 14, 2009 | Dishwashers
Soap dish does not open during normal cycle on my maytag dishwash
the soap u use may be causing this try cleaning it out real good and use liquid soap
Apr 20, 2009 | Maytag DWU9962 Dishwasher
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Soap remains in soap cup after complete cycle is run
I had the same problem. The door on the cup does not open all the way. Here is what I did. On the back of the dishwasher door are 7 phillip head screws. Take those out and the door inner cover comes off. There are 2 pieces of black insulation that are glued to the cover. The smaller one had slid down to where it was blocking the cup door from opening all the way. Pull this black insulation off and put it back in the right place. I even put a little hot glue under to keep it from sliding again. Hope this works.
Nov 18, 2007 | GE Tritonr XL GSD6260JCC Dishwasher
Washing Machines Logo
32 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
