Question about Explorer Appliances BO696 Gas Kitchen Range
The glass from the top of my Explorer Appliances BO696 Gas Kitchen Range shattered and I need to replace it.
I have one for sale, it was stored next to our range for a few years but never been used reply to make an offer plus shipping from (Tustin, CA.) brandogm@gmail.com
Posted on Aug 17, 2012
5 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: shattered glass top for Hotpoint range/ how to replace
The cook top on your range should come off by removing 2 to 3 screws under the front edge of the cook top. You will need to open the oven door to see them. Once you have them removed the top should lift up. Please ensure you have the range unplugged and/or the circuit breaker turned off before attempting any repairs to the heating elements. Live voltages are still present with the unit turned off. Now...depending on the type and model of your range, the wiring harness may have a quick disconnect type of plug. If yours is so equipped, replacing the top will be a cinch, because you can remove it from the range to work on it. Take the old top and new top and place them next to each other upside down on a padded surface. Placing some towels on a kitchen table or counter top works best. Now all you have to do is carefully transfer the entire harness and burner elements to the new cook top. You should be able to move the entire assembly with all the burners still connected. A second set of hands will make the process go much easier. If your range does not have the quick disconnect type of wiring harness have someone hold the cook top up or prop it up with something. Carefully remove the element mounting brackets from the cook top (with all the elements still attached). Carefully support all the wires as you do so, and lay the entire assembly (elements and wires) on top of the oven cavity insulation. Once you have everything disconnected from the cook top, discard the old one and position the new one in place. Carefully reinstall the elements while supporting the wires. Additional care should noted not to handle the ceramic material of the elements and/or the heat coils themselves. They are very fragile and the oil from your hands can potentially damage the elements and shorten the life of them. Let me know if this helpful to you. If you get stuck along the way, or have any questions, please respond to this posting by adding additional comments.
Posted on Sep 10, 2007
SOURCE: Dynasty DGRSC 30 Gas Kitchen Range parts replacement
Have you tried contacting Jade Products who manufactures Dynasty ranges? 866-607-5694
Posted on Dec 28, 2007
SOURCE: I need to replace the glass cooktop on my Maytag electric stove
  1. Open oven door and remove two screws that secure top.
  2. Lift up front and slide forward about 8 inches so that you can disconnect two wire couplings.
  3. Place on table upside down(I put newspaper down to catch the broken shards of glass) and remove burner unit (1piece, 4 screws).
  4. Place old burners on new stovetop in the same position as original.
  5. Remove 4 white plastic shims (round) from old stovetop and put on new stovetop.
  6. Tighten all screws and then sit it back on stove (two front tabs fit into slots) and then insert screws into holes and tighten.
  7. Took about 20 minutes, including vacuuming broken glass from inside burners and cleaning grease form crevices between burners and old stovetop.
  8. Wrap old stovetop in the newspapers that are underneath it and place it all in a plastic garbage bag to avoid any broken glass from falling out.
Posted on Jan 26, 2010
SOURCE: Kenmore gas range model 790 door glass shattered, handle problem
We have the exact same problem. This design is totally unacceptable! Thank you for the suggestion of switching the handles as a temp fix (they don't appear to be exactly the same, but we'll give it a try). Has anyone found a permanent solution? This wasn't a 'cheap' range....we expected better craftsmanship.
Posted on Mar 29, 2010
ANYONE HAVE AN OLD OVENTHEY ARE NOT USING? I'LL BUY IT FROM YOU IF THE PRICE IS RIGHT
where are you located? & are you looking for one to cook on or collectible vintage ones?
where i live in Paterson,nj,we have stores that sell used stoves/refrigerators,etc,restored to almost new condition,for about $150.-maybe there's some of these businesses near you?
my friend is selling a vintage stove,but unless you are local & can pick it up, i can imagine the shipping charges to get it to you would equal buying a top of the line stove in your area.
Apr 04, 2015 | Explorer Appliances BO696 Gas Kitchen...
Need replacement glass screen for BO696
Jun 06, 2012 | Explorer Appliances BO696 Gas Kitchen...
Can my oven still be used if the outside glass is shattered
No!!!
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Dec 12, 2010 | Whirlpool GS460 Gas Kitchen Range
I cleaned my gas stove and the igniter is constantly triggering when plugged in.
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
Burners Keep on Clicking
heatman101
Dec 07, 2010 | Explorer Appliances BO696 Gas Kitchen...
Spinflo gas appliances
good day,
hope this link blow will solve your problem.
kitchen appliances
Jun 22, 2009 | Explorer Appliances BO696 Gas Kitchen...
BO696 problems-burners too high on lowest position (propane used)
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
Oven glass shatter on kgst307gwh0
You would need to contact Kitchenaid about any possible product issues
Mar 05, 2017 | KitchenAid KGST300 Gas Kitchen Range
Explorer Appliances BO696 Gas Kitchen Range Logo
260 people viewed this question
Top Explorer Appliances Kitchen Ranges Experts
Vernon Taylor
Are you an Explorer Appliances Kitchen Range Expert? Answer questions, earn points and help others
