Question about Samsung Refrigerators
My Samsung RS2545SH refrigerator have ice build up in the fridge side and only the freezer side stop working. After we cleared all the ice in the fridge side, the freezer side cannot decrease the temperature to lower than 56 Fehrenheit.
Sea Breeze
  • 4654 Answers
SOURCE: Westinghouse fridge: no cool air circulating inside
Art, I need to get a little more information from you. Does the condenser fan under the refrigerator seem to work and blowing warm air from below and or behind the refrigerator? The motor feeling warm is OK. Only when too hot to touch on top. Needs to cycle also. When you opened the freezer did you hear the fan blowing? Thanks, JT
Posted on Apr 18, 2009
  • 1462 Answers
SOURCE: SAMSUNG SIDE BY SIDE FRIDGE FREEZER
these appliances are a pain in the butt. fault with water dispensor is oprob that the water bottle at bottom of fridge is frozen. rise in temp is prob that defrost not taking place. not a diy unless you are experienced
Posted on Mar 20, 2007
JOE LLAMA
  • 26 Answers
SOURCE: I HAD AN ICE BALL
Some how warm ambient temps are finding their way in there and causing this ice up. I do know that samsung had built a few of the ge models which have evaporator coils in the refrig section. You should shut off the refrig completely and leave the freezer door closed, but open up the refrig door and let it defrost down to room temp. After trying this log how many days it takes to come back and if its in the same area.
Posted on Apr 01, 2008
  • 5 Answers
SOURCE: Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Posted on Aug 13, 2008
woodchuck789
  • 4059 Answers
SOURCE: Ice build-up in lower freezer. We replaces the
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check , defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control. Part 13 in this diagram.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MSD2756GEW&productCategoryId=0165000&brandId=3048&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00002&componentDescription=CONTROLS&documentId=M0404275&backToLink=Return%20to%20Sub%20Components%20list
Posted on Sep 16, 2009
Samsung model rsh1dbbp: fridge running at 19 degees. have cleared ice build up in lower left hand side. freeer and water ok. no ice build up in freezer
The accumulation of ice on one side indicates a refrigerant problem. Basically there is a refrigerant leak and some of the refrigerant has been lost.
A technician can repair the leak and re gas the refrigerant for you.
Apr 01, 2011 | Refrigerators
RS2545SH. Fridge side is not cooling. Thanks
I have the same problem....anyone have a fix
Oct 18, 2009 | Samsung Refrigerators
Samsung RS2545SH refrigerator just stopped making ice. any advice?
Samsung Fridge  RS2545SH stopped cooling. The fridge section is about 50/55 and freezer is around 45. It wont go below. At one point, there was rumbling rattling sound from the compressor. Icemaker also stopped woprking.
Jul 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Refrigerator not getting cold in Fridge side
No. check this post from right here.
http://www.fixya.com/support/t245665-samsung_rs2556_refrigerator_side_not
Question: was the fridge running when you went to pick it up ?
Was it already on ?
My thinking is that you have the ice build up problem too and that it never thawed. If you unplug it, thawing could take days. Seriously. If you take the inside panel off and get some heat on it
only an hour or so.
You have the exact same model I do, and it works good, just designed poorly. It needs a drain hole on that condensor.
And your fan probably is fine. Do not spend $500.
Apr 06, 2009 | Samsung RS2556 Side by Side Refrigerator
this is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
Oct 30, 2008 | Samsung RS2630SH Side by Side Refrigerator
Aug 12, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung Refrigirater Model # RS2545SH
You have two problems that are related. Check water supply shut off valve to refrigerator. Turn it all the way off and then back on. It may be restricted. Shutting it off and then back on may clear the restriction.
May 23, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
Have a 2 year old SAMSUNG RS2545SH Side by Side
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
35 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
