Question about Numark MP302 2-Disc CD Player
I just bought and installed the Numark MP302 DJ CD player and It seems to be getting no power. Am I doing something wrong or is this unit DOA.
SOURCE: numark cd mix 1
The buttons usually wear out, open unit and replace the buttons.
Posted on Oct 03, 2008
  • 92 Answers
SOURCE: setting up new CD laser
Any new laser will not require any adjustment, most modern CD players do a self calibration on power up. There is a small dot of solder that must be removed somewhere on the circuit board. You'll see it's shaped like two half circles with a small gap between them which is bridged by solder. Remove this and you should be good to go! You should just be able to touch a soldering iron to it and drag it off. Or you can use a "solder ******" or de-soldering braid.
Posted on Oct 09, 2008
SOURCE: dj io with Traktor PRO
gvjccçznvcncbdfjcvnmcmxnfbfjgkksdfsd
Posted on Jul 01, 2009
SOURCE: Since I started using the Numark DJ i0 soundcard I
get the lastest download from www.numark.com and then go to your startup menu and go to numark folder and change your audio latency setup to the next level and repeat it unitl works
Posted on Jul 29, 2009
SOURCE: Numark HDX system needs upgrade: Insert upgrade cd?
You just need to type Numark Hdx in your search engine or on numark's website, and they have the download for the firmware update. Download and burn to disk. Turn on your deck holding the eject button until it ask for you to insert the disk you burned. Go thru the prompts and let it install firmware *NOTE DO NOT TURN OFF DECK* or you will ruin it.
Posted on Aug 24, 2009
One cd player wont read
Take a can of compressed air and blow into the player all around and try it. The heads get dirty over time and stop reading. Clean the dust off the laser head and they usually start working again.
Feb 28, 2013 | Numark Industries Numark CDN 22 Mk4 Double...
Numark cdn25 dual cd player when open close the lcd screen gets dim
Are you using the original factory power supply? That sounds like it isn't strong enough. The mA is what I mean.
Feb 28, 2013 | Numark CDn25 Professional DJ CD Player
I have windows 7 and it is a 64 bit operating system, when i plug the dj io into my usb connection and try to install the drivers it comes up as not recognising the hardware and keeps saying that the...
Good day,
Is your Numark DJ/io soundcard comes with a software cd/dvd. You need to install it first in your system to use it. If you have no cd. Try downloading on the product website for the software. Tnx
Aug 18, 2011 | Numark DJ/iO Sound Card
Alright well I have a Numark rack mount dj set with two CDN95 2 disc players. Well I bought it used with speakers and everything and do not know how to plug everything, I really need some help please...
As shown in the Quick Start Guide (link below) this unit should be connected to a Mixer Unit.
http://www.numark.com/stuff/contentmgr/files/0/662529d8e9e5b8ebe1747274e5bad9d6/file/cdn95_quickstartguide.pdf
Looking at the Diagram they appear to be standard AV Cables so you should just be able to plug the CD Outputs into the Amp AV Inputs (as long as it's a Dual Amp) and then connect your speakers to the Amp (make sure the speakers impedance matches the Amp.
Further details available at http://www.numark.com/cdn95?tt=5
Please leave feedback
Cheers
Andy
Apr 25, 2011 | Numark CDN95 2-Disc CD Player
Very reluctant to play burned CDs
What specific message or symptom does it display?
And commercial CD's are fine?? Look to the machine that created them. Make sure they're finalized.
Mar 05, 2010 | Numark MP302 2-Disc CD Player
One cd player stopped working have no manual
Are you getting any sort of errors on the display. When you say it stopped working, what is it doing or not doing exactly?
If it's the CD tray - very common - it will have to be replaced by a professional.
- OPTiC
DJ Equipment Repair Videos
DJ Equipment Repair
DJ Equipment Sales
Numark Parts
Jan 16, 2009 | Numark Fusion 494 Complete DJ Package
Numark cd mix 2
Well, it's not that hard to set up. What do you need help with? If you want to know how to connect:
1) The CD units go into the back of the mixer - in the CD / LINE INPUT - Left side on CD / LINE INPUT 1 and Right side to CD / LINE INPUT 2
The output of the mixer - MASTER OUT - goes to the INPUT of your stereo, amplifier, or receiver's LINE INPUT connection.
That's it. Press PLAY on your CD players, and raise the faders/volumes, and your all ready to go.
- TWEAK AV LAB
Nov 30, 2007 | Numark Fusion 494 Complete DJ Package
Numark MP302 2-Disc CD Player Logo
21 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Electro Med Services...
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
