Question about Husqvarna 23 Hp 48" Deck Yard Tractor
Excessive vibration when blades are engaged. No visible problems. Started after a rag wrapped around one blade.
  • Roy Cagle
    Roy Cagle May 28, 2011
    You could remove each of the blades and check to see that each one is "balanced.". One unbalanced blade can lead to the problem you are having. While you have the blades off, you may want to sharpen them, balance them, and then try reinstalling them. That will also allow you to inspect the area on the madrell where the rag wrapped around the blade.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
If it started when a rag wrapped around the spindle mandrel? You may have damaged the mandrel. Check where they bolts onto the deck, if the mounts are damaged, this could give you the vibration. You could also have done something as simple as bent a blade.
Posted on Jul 13, 2011
How do I remove nuts to replace deck pulleys?
Pully shaft runs through deck to blade spindles. Wear floves amd wrap heavy rag around blade and hold tight whist undoing pulley nuts. Another option is to place a oil filter strap wrench around pulley grooves and tighyen to achieve leverage. Happy fixing.
Sep 02, 2015 | Garden
Poulan pro engine dies when blades are engaged
Something may be wrapped around the blade shaft under the mower deck or maybe the shaft bearings are bad.
Aug 10, 2014 | Poulan Garden
Excessive vibrating
Exsessive vibration is normally attributable to the mower deck. If the vibration is occurring while the blades are engaged and cutting this would indicate a need for further investigation. Check the blades for damage or uneven ware. If the blades are new or appear in good shape check the mandrals and shafts to ensure they are not Brocken or bent. You can get mandrel assembly's for around $60.00 online and replace all you need in one go.
Jun 14, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Old Snapper Mower dies when blades engage now won't start
I would have to say the engine seized up, sorry!
Jun 06, 2013 | Garden
Dixon zeroturn DM 42 Pto will not engage.
did it burn out the clutch?or did you knock off the wires when removing the twine
Apr 07, 2012 | Garden
When i try to engage my blades on my lawnmower the belt starts smoking and the mower will cut off
You either have something wrapped around or jammed in your blades(obstruction of some sort), or the bearings seized in one of the blade shafts. Check underneath and see if there's something stuck or wrapped up in there, and remove it if present. If not, turn the individual blade shafts to see which one is stuck, and that's the one you'll have to replace.
Mar 21, 2010 | Garden
46" craftsman lawn tractor shuts off when engaging
check the wire from your clutch to were it plugs in. should be on your right side. some have a yellow cover. make sure the wire is not broken. check under your deck and make sure you don't have a large grass build up
Oct 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a crftmans rider ltx 1000 , i was cutting the lawn picked up a cable which wraped itself arouf the mandrels for the blades and stopped the mower , got cable removed started right up no problem ,...
Yes, if you jammed something in the blades and the belt stopped, the engine pulley wore a thin spot in the belt.Every time that thin spot runs around a pulley it rides deeper in the pulley making it vibrate.Take the belt off and you should be able to see or feel the spot where the engine pulley burnt it. Replace the belt and it should fix it.
Jul 31, 2009 | Craftsman Garden
Runs fine when idling but kills or runs rough when blades are engaged
This could be due to the blades becoming blocked, maybe by rag, or shreds of tarp, which have wrapped around the blades, thus tightening them up, in which case, it just needs a clean up. Or,
It could be a switch problem. Like the safety cut out one, under the seat.
Hope that helps
Jul 11, 2009 | Mtd Garden
Want to change blades on Craftsman 42" mower
Thanks for using FixYa!! A FixYa rating is appreciated for answering your FREE question.
Jun 20, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna 23 Hp 48" Deck Yard Tractor Logo
442 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
