Question about OKI C5200n Laser Printer
356 BELT ERROR
GETTING A 356 BELT ERROR PROBLEM. I INSTALLED BELT UNIT FROM TWIN UNIT IN OFFICE BUT GET SAME FAULT. OTHER UNIT WORKS FINE AND IS SAME EXACT MODEL #. WHAT COULD I BE MISSING?
  • Anonymous Jan 08, 2009
    I have a problem in my printer that is: there is a new error like these latter " replace belt, 356: blet life"
    please can you help my to solve this problem,
    thank you
Please Google your problem.
The method in the following link helped us to solve our same problem.
<OKI C9300 Code 356:Belt Unit Life>
http://www.fixyourownprinter.com/forums/printer/53306
There is a shortcoming, however, in this method:
The reset process resets the usage stats of toners, drums, fuse and belt. After reset it displays on Print Supervision as if all the a.m. parts have been replaced with new ones.
Posted on Mar 04, 2009
SOURCE:
Xerox 7345 error code 10-356 how to solve please help me
1)As soon as you locate the code in the list ,click on the link and you will be given a list of solutions.
2)Try to fix the issue causing the error code. All codes do not require service many can be solved by the operator itself.
For more printer related assistance just give a call @ 1-866-293-9220.
Sep 01, 2018 | Xerox Office Equipment & Supplies
Tape recorders.
Most tape problems would be mechanical in nature. I am venturing a guess that the belt(s) are cut. If your brand/model uses two (2) separate motors, then either both belts are cut (unlikely) or the regulator circuitry powering these motor(s) are defective. In some instances, the logic circuitry (especially those with dubbing features) maybe at fault.
Corrective procedures would entail opening the unit for a look and see. This of course would require that you be familiar with electronics circuitry & mechanical components, use of a DVM and possibly even soldering. Should you be uncomfortable going this route, perhaps it will be to your advantage to seek the services of a qualified professional.
Incidentally, should the downtime and cost of repair be no longer economically reasonable, then perhaps purchase of a new unit might have to be considered.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 25, 2008 | Audio Players & Recorders
How can i download office word
office word is part of office suit office suit 2010 is the last program
the new program is office 356 which you can buy for a year or monthly
( 356 days of the year) unlike office 2010 which is yours
Oct 04, 2016 | Microsoft Office Word 2007 Full Version...
IRC4080i printer. How do I correct error code E000007-0001?
Error Codes Relevant to Fixing/Pressure Belt Displacement Control
E007 Fixing belt displacement error
0001: Upper belt displacement fault. (Either the upper belt full displacement or the belt displacement sensor
fault.)
0002: Lower belt displacement fault. (Either the lower belt full displacement or the belt displacement sensor
fault.)
0101: Upper belt HP detection error.
0102: Lower belt HP detection error.
Note:
Adjust the fixing/pressure unit HP with the following service mode at the installation or when replacing the
fixing (pressure) belt.
COPIER > FUNCTION > FIXNG > FX-UHP-S
> FX-LHP-S
Points to Note When Replacing Fixing Unit
By executing the service mode, the alarm code is closed and the total rotation time is cleared. Thus, this mode
must be executed when replacing the fixing unit.
If the mode is not executed, the following symptoms will occur.
-The alarm code is not closed.
06-0002: Fixing unit life alarm (Caused by the belt displacement)
06-0004: Fixing unit life alarm (Caused by the torque up)
-Although the total rotation time of the replaced fixing assemble does not reach to the message threshold, the
machine wrongly recognize that it reaches to the threshold and displays the message.
Be sure not to execute the mode except at the installation and the fixing unit replacement. If not, an error
message may not be displayed when the fixing unit reaches to its life.
Sep 10, 2015 | Canon Office Equipment & Supplies
Xerox 1250
10 355 and 10 356
355 external heat roll sensor did not go low within 5 seconds and 356 ext. heat roller did not go high after 5 seconds
the sensor sits by the web motor check the flag is not missing the sensor will go bad as well.
good luck
Mar 04, 2014 | Office Equipment & Supplies
Am getting error 356: Belt Life - Is there a way to replace that yourself?
I suspect this is the transfer belt that needs to be replaced. I've seen the error as 355 not 356 but that could be depend on when in the life-cycle of the belt you see the error. You can replace this yourself. The entire list of steps is given here for the C5150n: http://my.okidata.com/man-c5150-c5200.nsf/MOCContents/380C6DEE82CF117285256CC50063D2D3?OpenDocument . (The entire manual is here: http://my.okidata.com/man-c5150-c5200.nsf/InsideUsersManual?OpenFrameSet .)
The transfer belt, part 42158711, costs ~$210 from this vendor: http://www.fastprinters.com/ProductDetails.asp?product_id=OKI-42158711 . It's probably close to $250 from OKI. Staples has it for $270; Amazon.com lists one for $166.
To replace the transfer belt, you have to take out the image drums and put them in black plastic bags (if you take more than 5 minutes to replace the belt). Remember their order. Then locate the blue locks on each side of the belt unit and rotate them about 45 degrees to unlock them. Lift out the belt unit using the handle at the front. Unpack the new belt and hold it with the handle to the front of the printer. Catch the gear at the back with the drive gear on the belt unit. Lock the blue locks and then reinstall the image drums.
I hope this helps.
(If the problem is the motor belt, that's a different issue.)
Feb 04, 2013 | OKI C5150n Led Printer
Oovoo wont install on my computer
No Microsoft Office is not the problem. Please make sure you are downloading the right installer file fitted for you Operating System. Or if you can please post the exact error message that you are getting.
Jul 01, 2012 | oovoo.com
Office 2007 Install Problems
It can be very aggravating to reinstall Office; you probably need to use the free removal tool that Microsoft provides for situations like yours. It may have nothing to do with Office 2007 and everything to do with whatever else you added via Add/Remove Programs. My best advice is patience; Office12 is huge, and takes a long time to put all its junk in there; Microsoft will walk you through it if you have patience with their tech support folks and time to wait on hold to reach someone. The good news is they get paid to sit with frustrated folks like you. If you can be more sprcific what the error message(s) say(s) that will help whomever could help you get to the root cause of your issue(s).
Dec 08, 2008 | Microsoft Office Professional 2007 Full...
OKI C5200n Laser Printer Logo
1,344 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
