Question about HP D4360 DeskJet Printer InkJet
I CANNOT PRINT SPREADSHEETS OR DATABASE FROM MICROSOFT WORKS. TO MY HP PRINTER. IT GIVES THIS MESSAGE: MICROSOFT WORKS 8 HAS STOPPED WORKING. A PROBLEM CAUSED THE PROGRAM TO STOP WORKING CORRECTLY. IT HAS BEEN REINSTALLED 4 TIMES AND WE STILL GET THE SAME MESSAGE. WE INSTALLED IT ON ANOTHER COMPUTER AND IT WORKS FLAWLESSLY. I REMOVED THE HP PRINTER AND INSTALLED A CANON PRINTER AND IT WORKS FINE.
5 Suggested Answers
  • 237 Answers
SOURCE: Printer "out of memory"
So which printer are you wanting help with?
Posted on Nov 23, 2008
CompuGuy44
  • 432 Answers
The problem isn't your printer. The problem is with your Microsoft Works software. I know of six solutions that may work.
1) Download the latest service pack for .NET Framework 1.1. http://www.microsoft.com/downloads/details.aspx?FamilyId=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en
2) Go to this website and download the update. http://www.microsoft.com/downloads/details.aspx?FamilyID=65f5b806-e6a1-4f92-a656-e56eeda67e3d&displaylang=en
3) Uninstall printer completely (again). Unplug the printer from the computer. Reboot computer. Download the lastest driver from HP website. When installing the driver software, choose (type)a different directory,( ie. C:\MYHP\HP4180\ ). Plug Printer back to computer.
4) Go to this website. http://support.microsoft.com/kb/841220
5) Click START, click RUN, type SPOOL. Double click printer folder, clear (delete) any files in this folder.
6) Download the latest version of Microsoft Works 9.0.
Let me know if this works.
Posted on Feb 03, 2009
  • 3 Answers
a reasonable fix for microsoft is for you to spend $40
Posted on Apr 15, 2009
  • 7 Answers
SOURCE: HP CUE-Scanning flow component has stopped working. a problem caused the program to stop working correctly.
check out the below link which worked for most of the hp products
<a href="http://hpanswers.blogspot.com/2008/07/hp-cue-scanning-flow-component-has.html">Click here for the working solution</a>
Posted on Jul 03, 2009
After giving a print i get a message (Page too complex) Plz help...
Can I assume that you are printing spreadsheets?
Press the "check mark" to clear the message. If that doesn't work, you'll have to add more memory to the printer.
Dec 21, 2010 | HP LaserJet 3055 All-In-One Printer
Hello guys, i´ll be very
Issue Print jobs are stuck in the print queue (spooler) on a computer running Microsoft Windows connected to the print server. Nothing prints, and the print job in the printer's queue shows a status of Printing . These print jobs cannot be deleted even on the server, and it will not disappear or print until the Print Spooler service is restarted. Solution For Microsoft Windows Server 2003 and Microsoft Windows XP Professional x64 Edition, a fix is available in Microsoft Knowledge Base Article, The Print Spooler service may stop sending print jobs to a printer that uses the standard port monitor on a Windows Server 2003-based computer . Click here to view Microsoft Knowledge Base Article 934885 (http://support.microsoft.com/kb/934885) . To prevent this issue from occurring, disable the bidirectional printing support for each HP printer driver installed. To do this, perform the following steps:
  1. Click Start , point to Settings , click Printers , right-click the icon representing the printer to be modified, and then click Properties .
  2. Click Ports , click to clear the Enable Bidirectional Support check box, and then click OK .
NOTE: Sharing a printer over a network is a feature of Microsoft Windows and not HP printer specific.
Nov 01, 2010 | Office Equipment & Supplies
I can print word processing documents and off the web, but I can no longer print databases. I have several small databases, which I could once print in Landscape. Now I get an instant "out of memory"...
Best Solution posted 2 years ago
5986a52.jpg CompuGuy44
  • Rank: Wiz hp.gif computers_small.png
  • Rating: 82%, 1025 Votes
Aug 29, 2010 | HP DeskJet F380 All-In-One Printer
While trying to print from a microsoft works spreadsheet...it always says "out of memory" and prints a distorted page.
Hi
here are some ways to override the problem
When you try to print
it says
Microsoft Works Out of Memory
This problem may occur if there is a problem with the printer driver that is installed on your computer.
  • Method 1: Install a different printer driver
    Contact the manufacturer of your printer to inquire about how to obtain and install the most recent version of the printer driver for your printer.
  • Method 2: Configure the printer as the default printer
    Configure the printer driver that you have installed as the default printer. To do this, follow these steps:
    1. Click Start, and then click Printer and Faxes.
    2. Right-click the printer that you want to set as the default printer, and then click Set as Default Printer.
    3. Click File, and then click Close.
    4. Start Works, and then print the spreadsheet or the database file.
  • Method 3: Install an emulation printer driver
    If the problem persists after you install the most recent version of the printer driver for your printer, install an emulation printer driver. An emulation printer driver is a driver that imitates the functionality of a different printer driver. For example, you may be able to resolve this issue if you install the driver for the Hewlett-Packard DeskJet 550C printer or for the Hewlett-Packard LaserJet II printer. To do this, follow these steps if the printer is connected directly to the computer:
    1. Click Start, and then click Printers and Faxes.
    2. Double-click Add Printer.
    3. Click Next, and then click Local printer attached to this computer.
    4. In the Use the following port box, select the port that you want to use.
    If the printer is connected directly to the computer, the port is typically LPT1 (Recommended Printer Port).
    5. Under Manufacturer, click the manufacturer of the printer driver that you want to use as the emulation driver. For example, if you are installing Hewlett Packard 550c, click HP DeskJet 550c.
    6. Under Printers, click the model of the printer that you want to use as the emulation driver, and then click Next. Select HP. In Drivers, select HP DeskJet 550c.
    7. In the Printer name box, type a name for the printer, click Yes to set the printer as the default printer, and then click Next.
    8. Click the appropriate option for sharing the printer, and then click Next.
    9. Click No, and then click Next.
    10. Click Finish.
    Note If you are using a USB printer, go to step 12.
    11. Start Works, and then try to print the spreadsheet or the database file.
    12. Open Control Panel.
    13. Open Printers and Faxes.
    14. Right-click HP 550c, and then click Properties.
    15. Click Ports.
    16. Click USB001 Virtual Printer port for USB.
    17. Click Apply, and then click OK.
    18. Start Works, and then try to print the spreadsheet or the database file.
Hope this will solve your problem
Jan 02, 2010 | HP Photosmart C5180 All-In-One InkJet...
Microsoft Word problem
This error message may occur when there is a wrong Printer selected when u try to Print but if it still says the same thing just uninstall and reinstall Works and Check............
Good Luck
Mar 01, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Feb 03, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Nov 23, 2008 | Office Equipment & Supplies
HP D4360 DeskJet Printer InkJet Logo
41 people viewed this question
Seeker5211
Seeker5211
