Question about Intex 1000 Gallon Swimming Pool Filter Water Pump ()
Ok my pool has a plus sign on it and my filter has a plus sign up top i cant figure out if i have hoses wrong top hose to the left bottom to the right is what i did??
    Brigadier General:
  • 3,301 Answers
If you can't get an answer, heres their toll free number Tel: (800) 234-6839
Posted on May 28, 2011
How do i clean and backwash my krystal clear saltwater system model cs8110 pool. Also it is very cloudy and I cant see the bottom of my pool
Hello... Is this your first pool? If so, do you have a local pool chemical supply company? They will test a sample of your pool water with way better equipment than the test strips... Than they will tell you exactly what you need and how to apply them... This is my 4th year with this salt system and 18'x 4' intex pool... Starting them up is tricky and it still takes me weeks to get it right... But the pool store told me how to start it up for next year so hopefully it won't take as long...
The phrase backwash referes to cleaning the filter... With the intex filter/pump system, that is the filter cargtridge that inserts into the pump/filter housing... Close the pool valves, open the filter cartridge housing, take the filter out and hose it down with a garden hose... Before you return the filter, dump out the nasty water sitting in the filer/pump housing... the Return the filter, screw back on the cap, open the pool valves and open the vent screw on top of the filter cartridge housing lid... This allows the pool water to flow back into the filter/pump and removes unwanted air pockets in the hoses... Once the water flows out of the vent screw, screw it back down to stop the water coming out... Now your down backwashing the filer...
Hope this helps,
Dan
Jul 13, 2014 | Intex Automatic Salt Water System for ...
Where to connect valves
Hook a temp hose up to it, put it in water and see which way it flows. The intake is then connected to the bottom output from the pool.
Apr 09, 2014 | Swimline Hydrotools Sand Filter
I have a fairly new (1st season) Krystal Clear Model 637R. It ran fine for a few months but now I can only keep it running for about 5 minutes before it shuts down. I then have to take the top off and...
I would check the hose connections again. Plus on the filter pump housing where the hoses hook up there should be orings. Check those to insure they are not dry rotted or if they slipped out of their groove.
Jul 22, 2011 | Intex Pool & Spa
Do not know how to install the filter to the pool, misplaced the instructions
1 - Connect your shortest hose from the bottom of your skimmer (if your pool came with one) to the lowest hole in your pool.
2 - Connect another hose (if I remember correctly, the 2 remaining hoses are the same length - if not, use the shorter of the two) from the outside of the lowest hole to the bottom place on your filter.
3 - Connect the final hose from the top place on your filter to the highest hole on your pool.
Your pool's water leaves your pool thru the lower hole & enters the filter. The filter then returns the water to your pool thru the highest hole.
If your pool did not come with a skimmer, you need to be sure to screw the vent cover over the lowest hole. You will need to screw the vent cover to the highest hole as well, but this is MOST important with the lowest hole as the suction could cause serious injury or even death to anyone (especially a child) who unsuspectingly gets too near. The suction could 'grab' a child and harm him/her or even cause the child to become trapped underwater. Please don't forget to correctly secure this spot of your pool.
Jun 21, 2011 | Intex 1000 Gallon Per Hour FilterPump
How do I connect up a hayward pro grid de4820 to a pool pump
motor gets hooked to bottom ,top is outlet back to pool there should be a bottom drain plug hose to pool goes on top return and on pump inlet
Jul 13, 2009 | Pool & Spa
When vacuuming out iron, its blowing back into the pool
ok -
1. go to k-mart or pool shop and get yourself some pool socks.
Pool socks fit over your skimmer filter and will filter out smaller bits before going into your filter system - very good to use when 'vac'ing your pool when there are lots of particals in your pool.
2. If you have a sand filter system - you will have a control handle some where on your pipe work near your filter, which will have around some settings you can select with handle... like....> Normal, backwask, rinse, recirculat + others PLUS a pressure guage.
If you do have this sytem - 'vac' your pool on Normal - then when finished OR pressure builds - back wash - rinse - then back to normal.
sorry about spelling :)
Jul 06, 2009 | Intex Easy Set 2500 Gph Filter Swimming...
How do I chabge the sand in my s-200 Hayward sand
take top off open bottom drain use a small wet vac hose to get as much out through top out be careful not to damage filter bars wash the rest out through bottom drain with a garden hose
Jul 02, 2009 | Hayward SAND FILTER, PRO SERIES
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Intex 1000 Gallon Swimming Pool Filter Water Pump () Logo
59 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
