Question about Kenmore Washing Machines
F35 code will only work in kids mode and below
  • Kenmore Master
  • 1,902 Answers
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Posted on May 28, 2011
Konica 7022 error F35-1
F 35-1 pertains to Abnormal Low fixing temp TH1. Try to clean the thermistor and reset the code by entering mode 25, software switch 3-1, make it zero. If the problem occur again, try to replace thermistor. Make sure that AC supply from mains is okay.
Aug 27, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Kenmore elite 5t steam f35 and sud problem
The F35 error code indicates a problem with the analog pressure sensor, air hose or air trap. If the hose and trap are good you will need to replace the pressure sensor
The "Sud" error code indicates too much or the wrong kind of laundry soap was used. Be sure to use only HE (high efficiency) detergent on this model of washer.
Please see the links provided below for access instructions & other troubleshooting tips covering the error codes displayed:
- Link 1
- Link 2
Hope this helps (remember to rate this free answer and leave some testimonial).
Sep 25, 2011 | Kenmore Elite 45986 Front Load Washer
What is code F35?
he "F35" error code is indicating a problem with the water level pressure switch operation (key#20). There could be a blockage in the air dome or pressure switch hose (key#21). The air dome is located on the back of the tub on the left hand side. (See image below) If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch (key#20).
Jan 13, 2011 | Whirlpool Duet WFW9550 Washer
I keep getting the error message F35. Can you tell me what that means?
The Central Control Unit detected a fault in the analog pressure switch but it could also indicate a draining problem. Check the link below to see what you can try to address the problem.
Troubleshooting Error Code F35 on Kenmore Elite and Whirlpool Duet Washers
Nov 03, 2010 | Washing Machines
Code F35
hello
what The F35 error code indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
The f35 error shows you and indication that ice maker sensor readings are out of normal range.
then what you need to do to fix up the problem is to bale out the water from it then clean up all form of water ant dry you can see from the screen
Please before you can carry out this instruction you will have to put OFF all source of power supply .
thank you and good luck.
Jun 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I got a trouble code coming up it is f35 what does that mean
The "F35" error code is indicating a problem with the water level pressure switch operation (key#20). There could be a blockage in the air dome or pressure switch hose (key#21). The air dome is located on the back of the tub on the left hand side. (See image below) If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch see diagtam below for key numbers
May 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine wont wash. fault code is f35. please help
The "F35" error code is indicating a problem with the water level pressure switch operation (key#20). There could be a blockage in the air dome or pressure switch hose (key#21). The air dome is located on the back of the tub on the left hand side. (See image below) If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch (key#20).
Feb 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
ON SWITCHING ON THE COPIER KONICA 2020 ERROR CODE F35 DISPLAYS PROMPTLY
How to clear fuser abnormality codes (F34, F35, F36), 2020.
Solution:
To reset fuser codes, perform the following steps:
1. Access the 25 mode (power the machine OFF. Hold down the 2 and 5 keys, and power the machine ON).
2. Press P-4-7-P on the key pad. (1, 4, 5, or 6 will be displayed on the copy quantity indicator).
3. Press the 0 key to change the indication to a zero.
4. Press the start/print key to enter the new data.
5. Power the machine OFF then ON to exit the 25 mode.
If the code comes back then your fusing unit will need parts/service.
Dec 14, 2009 | Office Equipment & Supplies
Konica 7020 F35 - 10 Where is DIP switch 3
In mode 25, pwr off then holding 2 and 5 down turn on. Service mode 25 has SW setting find 03-1 should read 03-1-0 not 03-1-1 (1) is a code F35-10
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 10, 2009 | Konica Minolta Office Equipment & Supplies
Error code f35-3 on konica minolta 7145 copier
How to reset failure codes (F34, F35, F36). To reset failure codes, perform the following: 1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys). 2. Select [1. software SW settings]. 3. Using the arrows on the left of the touchscreen scroll to DIP SW 3. 4. Using the middle arrows scroll to BIT 1. 5. On the touchscreen select OFF (0). 6. Power the copier OFF/ON.
Mar 04, 2008 | Office Equipment & Supplies
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
