Question about Epson Stylus Pro 10000 InkJet Printer
We are having problems printing a 10' x 42" banner on our Epson 10000 plotter. We are using a Xante Symphony RIP networked to the Plotter. For some reason it stops printing at approx. 76% (3/4) of the banner... Th RIP continues to spool and feed the file... But the Epson does not start printing again... even after the whole file is spooled. The file is a high res PDF (60" x 21") created out of Indesign CS5. It has a large graphic image background (mostly rich black) at 300 dpi. Any suggestions would be greatly appreciated. Steve Willis 916-743-0910
  • Steve Willis May 31, 2011
    Where exactly is the solution?
STEVE you have to print it as a tiled image. there is an update on the epson website for this issue. basicly anything over 90" you have to tile as two images split in half with no border in between if that makes sense. they explain it well in the update. when its something 120" x 36" lets say i run the set up at 36 x 60 then go to the page set up and there should be a box for tie image when you preview it again it shows the tiled image put back to back. you also have to tell it toreverse the print. i use adobe cs2 illustrator and it works well.
Posted on Oct 27, 2011
Plotter will not print
Check lan card led blinking pattern., Replace lan card(Jetdirect card 620n) & check, mostly lan card issue might be there..
Jun 12, 2015 | HP DesignJet 5500PS InkJet Printer
Im having Hp Designjet 800 Plotter. Which is installed with Windows 2000 Professional and Autocad 14. Im having problem while printing the autocad fonts which are in arabic. Its printing good in English...
Thats not the issue of yor lan card, in printer setting you need to select language selection mode auto,
arabic font should ben installed in your pc.
Mar 22, 2011 | Computers & Internet
Need manual and adjustment programme for epson 11880
My Epson Stylus Pro 11880 color ink-jet printer work fine but my problem is they can't print more than 7ft long & suddenly it's stop printing.
Jan 16, 2010 | Epson Stylus Pro 11880 InkJet Plotter...
HP 750C Moved across country, bought a new iMac. Forgot how to set up plotter settings so the mac can find it. on the network. I remember having to make changes on the plotter, but can't remember what...
Hello, the plotter should be seen in your print and fax preferences (apple menu, system preferences, print and fax): In the print and fax preferences panel, you can click on "+" at the bottom left of the window, you should see your plotter appear in the window, and click on the "add" button Best regards
Jun 10, 2009 | HP DesignJet 750c plus InkJet Printer
Are those papers printable on Brother HL-4050CDN ?
Hello !
If you want to print on canvas you need to use a plotter which use ink. An example is Roland or Epson. Personal i use Epson T5200 plotter and the result is awesome.
Apr 16, 2017 | Brother HL-4050CDN Printer
How do i print the usage page
You should be able to communicate with the plotter and get a control screen, through your browser, by typing in it's ip address. (i.e. 192.168.1.xxx)
Also, from the plotter, under utilites, you can view/print a usage report.
Nov 23, 2008 | Office Equipment & Supplies
1050C plotter
Here is the drivers page if you need a new set:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=33712&locale=en_US&taskId=135&prodTypeId=18972&prodSeriesId=24023
Aug 27, 2008 | HP DesignJet 1050c plus InkJet Printer
IP Assignment....
No, a tranceiver cannot be assigned an IP address. It just converts the signal between two types of lines (fiber, copper, etc.). This is mainly used for connecting together networking equipments such as switches or routers.
Depending on the type of interface you plotter have, you may need a device called a Print Server. This device has an IP address and allows a conventional printer signal to travel through an IP network. If your plotter is designed to be connected using a LPT (Parallel) cable, like old printers, you may look for the D-Link DP-301P+ or DP-300U.
Feb 12, 2008 | D-Link DE 853 (DE-853) Transceiver
Epson Stylus Pro 10000 InkJet Printer Logo
321 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
