Question about Whirlpool AD35USS Dehumidifier
Hooked up garden hose for continuous mode but it Problem with the Whirlpool AD35USS Dehumidifier Hooked up garden hose for continuous mode but it seems the water is going into the bucket and not through the hose. Other than attaching the hose as per the manual, it doesn't seem to be draining from the hose
I had the same problem with the LAD 704 DUL.....I tilted the unit back slightly with a wedge under the front side and the water is now draining through the hose into my drain....
Posted on Jul 03, 2011
    Brigadier General:
  • 4,736 Answers
First, the hose should not exceed 5 feet in length. There is no pump in that model dehumidifier. It relies totally on gravity to drain through the hose.
If all of the above is as stated above, I suspect that hose or the tubing inside the hose connecting is clogged. Which forces the water into the bucket rather than the hose.
To remove the clog in the unit, you will need an 18" long plastic Zip Tie or something similar, that is appropriately sized to fit into the hose connection/drain hole. NO wire coat hangers though.
Carefully feed the Zip Tie in to the hose connection. About 6" in the tubing will bend. You need to gingerly work the Zip Tie past this bend, until the Zip Tie bottoms out or you run out of Zip Tie to work with. The slowly remove the Zip Tie while rotating it. This will breakup clog. As you near the end of the Zip Tie coming out, be prepared for some water to follow. DO NOT perform any of this while the unit is plugged in to the wall outlet.
Hope this helped you solve the problem, Robert. Please let me know. Thanks.
Posted on May 28, 2011
Will not drain out of the hose i have to keep emptying the pan i thought it was suppose to drain out of the hose to keep running
If the hose is connected to the tap on the drain pan/bucket, did you knock out the center of the hose connection on the bucket? If you didn't that's the problem. If that's not where your hose connection is located, do not put the bucket back in. It triggers the unit to fill the bucket and not use the hose drain. Keep in mind the hose must remain lower than the connection on the dehumidifier to drain properly.
Mar 21, 2011 | Whirlpool AD35USS Dehumidifier
Why is my dehumidifier not collecting water
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Mar 19, 2011 | Whirlpool AD35USS Dehumidifier
Compressor not running but fan is running.
heatman101
Feb 10, 2011 | Whirlpool AD35USS Dehumidifier
Dehumidifier is running but not collecting water. The fan is working but the compressor is not.
heatman101
Feb 06, 2011 | Whirlpool AD35USS Dehumidifier
My dehumidifier still has power and blows out air but doesn't collect water---what might be the cause of the problem?
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Jan 22, 2011 | Whirlpool AD35USS Dehumidifier
Dehumidifier causing drop in house voltage when compressor comes on?
heatman101
Jan 16, 2011 | Whirlpool AD35USS Dehumidifier
Whirlpool dehumidifier has power going to it and runs just won't dehumidify.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 03, 2010 | Whirlpool AD35USS Dehumidifier
Whirlpool dehumidifier drains into the bucket, not the garden hos
I had a sililiar problem. I think I tightened tthe hose after putting a new rubber gasket on hose fitting, Also checked angle of hose.
Jul 26, 2009 | Maytag M7DH45B2A Dehumidifier
Whirlpool AD35USS Dehumidifier Logo
389 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Mike Squire
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
