Question about Carrier Heating & Cooling
Have a problem with my carrier air conditioner smelling like mold--also when cleaning what i can reach in the back fan it is totally black then when i turn it on small particles of black come out with the air
  • Sam Gibson
    Sam Gibson Feb 09, 2017
    I'm sorry to hear that your air conditioning unit is giving off a mold like smell when you turn it on. It might be a good idea to have a licensed, experienced, and reputable professional come out to look at it. I'd be curious to know how often you should have your ducts cleaned and inspected. I've never thought about mold in my own HVAC system. http://www.lotusfilters.com.au/air-condi...
    Master:
    Sergeant:
  • 394 Answers
If you are in the market for an Air Duct cleaning check out Air Duct Cleaning Dallas Tx.
Posted on Apr 28, 2016
  • 413 Answers
Sounds like you need to have the duct work cleaned by a professional.
Is your duct work in the concrete floor? If so check for water in the duct work. You can go to one of your supply grilles in the floor, take the grille up and look into the ductwork. If you have water, you need to find out if you have a plumbing leak or if it is just runoff from a hard rain. Nevertheless, it needs to be fixed.
Is your duct work in the ceiling? If so, and you still have mold, just have a professional duct cleaning company clean your duct work and it should solve your problem.
One other thing, make sure the condensate drain from your heater is not stopped up and dripping water into the duct work if the duct work is in the floor.
Posted on May 28, 2011
My Kenmore 70088 Air Conditioner have mold
Hello, the coils can be cleaned with coil cleaner that is sold at any heating and cooling store, usually in a aerosol can. The inside of the AC can be cleaned with soap and water. They also sell a cleaner for mold at heating and cooling stores that can be used to get rid of the mold.
May 15, 2012 | Kenmore 70088 Air Conditioner
When the unit is turned on, for the first 15 minutes or so, there is a distinct stale mouldy smell. I suspect dust collected on the unit coils is being wet by condensensation and it smells as the first air...
You can check the cause of that smell if you have the tools to open the unit. The first test is to place a piece of paper in front of the evaporator and start the fan. If the paper is **** or stays in front of the evaporator, you have a clean evaporator. If it is not ****, you need to open and clean the unit. The blower may be filled with dust and molds. It is best to find someone who knows how to work and clean your a/c unit
Sep 10, 2011 | Carrier 52PQ307 Wall/Window Air...
Black mold inside unit, fan becoming noisy, I have a hunch that it,too, is covered with black mold.
It sounds like you know the problem and the sollution is to clean it. these system require rutine cleanings every 6 months because they have condensation always in the pan
Aug 24, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I have mold growing inside where the fan is.
The outer chassis needs to be removed and then gain access to the scroll fan. Once accessable use a mold and mildew remover on everything EXCEPT the evaporator coils. Many mold and mildew removers are very corrosive to evaporators. A well used scotch brite pad works well on any styro-foam and metal. A pot scrubber brush also does a good job on cleaning the scroll fan. Once you finish cleaning use a fresh water squirt bottle to rinse off the mold and mildew cleaner residue as best you can. Place rags in the bottom and rinse. Wring out the rags and rinse again. I personally use Mr. Muscle Mold and Mildew Remover but it is really hard on your hands. Disposable Latex gloves are a must. You will not get rid all of the discoloration off of styrofoam but you will get rid of the smell and the majority of the problem. This is a task a homeowner can do.... just be careful when gain access to the scroll fan.
Thanks for choosing FixYa,
Kelly
Jul 13, 2011 | Frigidaire FAS257S2A WallWindow Air...
Hi. We've been running our LG BP6000ER window unit air conditioner for four seasons. We've made seasonal efforts to clean the interior with a hose, but this year we're noticing a strong mold/mildew smell...
take it outside .get the hose .buy some coil cleaner hardware store .clean the coils good.. both of them .try to be carfull of the controls not to get them to wet ..cover them if you want ..after cleaning coils tilt unit to remove most of the water let it dry, use a fan its quicker should do the trick .it will work like new and smell better
Aug 22, 2010 | LG BP6000ER Air Conditioner
MY SHARP AF120FX ALSO DOESNT DRAIN AND THERE APPEARS TO BE NO DRAIN HOLE AND THE UNIT HAS ALWAYS BEEN ON AN ANGLE. THE UNIT FILLED WITH BLACK MOLD ON THE STYRO FOAM INSIDE TOP OF UNIT SO I SPRAYED IT WITH...
Many newer units are made to retain the water and splash it onto the condenser coil... Clorox in the water will kill the mold and not hurt anything... You can carefully drill a hole if you want..
heatman101
Asker's Testimonial " good knowledge, very helpful thank you " - rubicon1952
Aug 19, 2010 | Sharp AF-S120FX Air Conditioner
My goldstar air conditioner has a lot of mold growing in where the fan blades are and the vent. How can I clean this or get rid of the mold
Air condition and coil cleaner,can be found at your local hardware store.
I have used simple green full strenght,cleans and kills mold.
Jan 18, 2010 | LG Goldstar GWHD5000 wall/window Air...
Window AC - foul smell
if the unit is cleaned and this smell is only when the condenser is on means the fresh air is open and this smell comes from outside . because the condenser fan is sucking air from condenser through it to motor side .
May 02, 2009 | LG Art Cool LA121CNP wall/window Air...
Carrier Air conditioner
Most likely the transformer is shot on the air handler. To test this go to the thermostat and move the selector to fan on, if the fan blows it's not the transformer. Let me know. THX RepairUSA
Sep 02, 2007 | Carrier 38CKC042 Air Conditioner
Moldy smell to air
I have a maytag ac unit that kept smelling moldy. We tried spraying with antifungal, only helped for a short time. I took the unit (ac unit slides out of window case) outside and carefully removed screws only to discover the fan was covered in mold!!!! Oh my what a horrible discovery! I washed the fan blades with bleach and water mix. I completely and carefully washed and wiped down the air conditioner careful around the control box. Then I let the unit sit outside in the sun untill completel dry. Good bye mold and fresh clean cool ac!! I will do this each year now that I saw that ugly mold!! That is definetly a health hazard! I would reccommend you either thouroughly clean your unit or pay someone to do it or get a new unit right away!! Don't use that moldy unit another day!! Good Luck!
Oct 03, 2006 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
520 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
