Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
Unable to access some menu options
Press the menu button and under the "PICTURE" tab, "film mode" and "pip" are not accessable, they are darker and they cannot be opened. Also in menu, the "CHANNEL" tab is skipped and cannot be accessed. Finally, under "SETUP" tab, "V-Chip", "Caption" and "PC" are darker and cannot be accessed. I have tried to find a reset to factory default and have not found that information in my owners manual. Thanks for your help. Paul
    Sergeant:
    Champion:
  • 298 Answers
Maybe if you go to parental control and type in the code to unlock the v-chip , all other will unlock as well.
Posted on Aug 16, 2008
The pip got stuck using a universal remote..i cannot clear it no matter what button I use
If you can access the Menu options with your present universal remote, get into it, and surf thorugh picture adjustment and PIP adjustment screen, and set the PIP option to OFF. If you can't access the Menu option with your present remote control, there is no other way to do this without its original remote control.
Apr 06, 2012 | Panasonic CT-36D32 36" TV
Cant access menu options
Press Menu button, select Playback icon by up/down buttons and press OK (shutter) button to get in playback mode.
There are few icons like self timer, movie recording mode, delete all files, delete single file/ picture etc.
Please click HERE to download user manual copy that has mode details of icons in camera OR click Vivitar Support link and put camera model number to proceed.
Thanks.
Jul 10, 2011 | Cameras
How do i unlock the key--- display on my Provision television that is operated by a beko 12.1 remote control.I also need the service code for some Geometric adjustment.
Service Menu Access Procedure To access the service menu, press and hold the handset sound mute button whilst pressing the TV's front panel 'Menu' button (under the front panel cover on the TV). The up/down channel buttons on the handset step through the options and the left/right buttons change the data values. Turn the TV off to get out of service mode and DO NOT touch any other handset buttons whilst in service mode. Service menu access is also similar for many other Toshiba large-screen TV's so this procedure may work on other Toshiba TV's - even those sold outside the UK.
Maybe this list can help you, click here for a list of each widescreen Toshiba TV Service Menu adjustment with details on the purpose of each.
The factory settings of each service menu option will be entirely different on every TV manufactured, due to component, tube and scan coil tolerances, so don't under any circumstances adjust your TV's settings to my factory default settings or your TV's picture will probably look awful! The factory settings are provided out of interest - the useful part of this document is actually the definition of each service menu option. You will see that some geometry settings are duplicated for each screen mode such as 'Cinema' and 'Subtitle'. This could, for example, help resolve a geometry problem that's present just in one screen mode.
I hope help you with this.
Oct 14, 2009 | Televison & Video
How to program pip on my vizio
PIP (Picture-in-Picture)
Picture-in-Picture is a feature which allows you to watch two different signal inputs simultaneously, when
selected.
Press menu, go to set up (the wrench icon). Drop down one to the button and highlight the option.
Press the button to activate the PIP feature, which will bring up a display showing Style.
Press either the or button to select it to be either PIP, POP or OFF.
Press either the MENU key to return to the previous menu display or the EXIT key to return to your
program if task has been completed.
If PIP is selected, then you will have the options of selecting the Input (Refer to PIP mode on page 60 of
this manual; for different combinations), Size (The size of the little box to watch the second signal) and
Position (Where you want to place the little box with the second signal).
If POP (Regularly called Picture-by-Picture) is selected, you will only have the option to select the Input
as the screen will display the two different signals side by side; each one occupying half of the screen.
Using the AUDIO key allows you to select which audio
Jun 11, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Using timer
Kodak EasyShare C613
Changing picture-taking settings
You can change settings to get the best results from your camera.
1Press the Menu button.
2Press to highlight a setting, then press OK.
3Choose an option, then press OK.
■Press the Menu button to exit the menu.
NOTE: To better understand each menu option, use camera Help. Highlight a menu choice, then press the button. Some settings remain until you change them; others, until you change modes or turn off the camera. Some modes offer limited settings.Press Menu, , and OK to access settings
Options
Self-timer
10 seconds (default)—
so you have time to get into the scene.
2 seconds—
for a steady, auto-shutter release on a tripod.
2-shot—
one picture is taken after a 10-second delay. A second picture is taken 8 seconds later.
Exposure Compensation
Increase or decrease brightness before taking a picture. (Also see page 27.)
0.0, -0.5, -1.0, -1.5, -2.0, +0.5, +1.0, +1.5, +2.0
From: http://www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00711/C613_UG_GLB_en.pdf
If this helps, please post a rating for me. Thanks!
OpenSource13
Apr 19, 2009 | Kodak EasyShare C613 Digital Camera
Unable to access restore-point feature
Try booting into safe mode and accessing it from there.
To get into safe mode, press F8 when you turn on your computer and keep pressing it until the menu appears from which you can select safe mode.
Jun 22, 2008 | Computers & Internet
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Normal Picture Mode Not Available With Cox HD-DVR (Motorola DCH3416) and HDMI Cable
With an HDMI cable connected, the cable box determines the picture size. The settings on the cable box must be changed in order for you to get the correct picture size. I have some experience with Motorola cable boxes; usually to access the settings you turn the box OFF and then press the menu or settings button on the box to bring up the display menu. Hope this helps!
Mar 05, 2008 | Sony KDL-32M3000 32 in. LCD Television
Shooting features
There is an option where you can set the camera to capture two images side by side, within the same frame. This feature is called “2 in 1” and can be accessed through the Mode Menu. Press the OK/Menu button, and use the right (>) arrow key to access the Mode Menu. Press the up (^) or down (v) arrow key to navigate to the CAMERA tab and then use the right (>) arrow key to access this sub-menu. Use the down (v) arrow key to navigate to the “2 in 1” feature and by using the right (>) arrow hey the “2 in 1” feature will be active for the next two shots. After the second shot the camera will display the menu option for “2 in 1”. You can select the option again, or you can return to normal shooting by pressing the OK/Menu button.
Sep 01, 2005 | Olympus D-595 Zoom Digital Camera
Shooting features
Aug 31, 2005 | Olympus D-545 Zoom Digital Camera
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
83 people viewed this question
Henry  Thomas
Henry Thomas
