Question about Microsoft Windows Vista Ultimate Edition
Network adapter failed error code NC315-5W.HP M8330F product number GX6122AA#A2 L cannot connect to the intent. PC crashed. We replaced the power supply and graphics card.After installed the PC works .Disconnected the moden for 30 seconds and reconnected and no change.
5 Suggested Answers
rathika
SOURCE: internet connection disconnected
Try to update the wireless drivers in safe mode and restart your machine. Check this it works
Posted on Mar 19, 2008
JonwVBFL
  • 56 Answers
SOURCE: XBOX LIve help - wireless network adapter
Go to your Airport Utility, then Option-Click the radio setting button to reveal a drop down menu, from there, select "b/g compatible", not "n (b/g compatible)". That takes away the benefits of an 802.11 n network, but it gets the job done with 54 Mbps.
Next up is to Option-Click the button for encryption setting and select "WPA Personal". In DHCP settings under Internet, using the 360's MAC address, reserve an IP so it stays consistent. Finally, in your NAT options, select the 360's IP address as the "Default Host" to prevent any Live functionality issues, and restart your Extreme Base Station. Once you go to the network settings on your System blade, you should see your WPA-encrypted network show up. So your 360 and Airport Extreme can work together with encryption, although you kind of neuter the Base Station in the process.
Posted on Feb 06, 2009
frcs68
  • 1605 Answers
SOURCE: Problem wirh Microsoft 6T04 Network Adapter
check out the following link
http://www.errornerd.com/error.php?seed=Tunnel.sys&gclid=CKTH6oL245kCFQKaFQodonn0QQ
there are few steps need to perform to fix the problem.
Posted on Apr 09, 2009
  • 2678 Answers
SOURCE: Code 10 network adapter
Teredo tunneling is a method of tunneling IPV6 traffic over an IPV4 network.99.9999999% of the networking in the world is IPv4 so why vista would want to change it is beyond me but yet another failing of Vista no wonder it's being replaced this year I just feel sorry for the mugs that have it and are still being sold it!
However back to your problem and a solution t's simple just do the following and you should be OK
To uninstall IPv6 from a computer using the command prompt
1. Open Command Prompt.
2. At the command prompt, type ipv6 uninstall, and then press ENTER.
Posted on Jul 29, 2009
49-2F9D Service error
49:xx xy fault code is Firmware crash , look at the 49 error as bieng like a blue screen crash on windows, there are many things that could cause this to show- what to do-
disconnect both the mains cable and any other network/usb cables that are connected to the printer.
allow 20 seconds for the ram to clear. then re- power the printer still with no network connections, allow to come to fready - at this point you should try to get an info page from the printer ( use the menu(tick) button then scroll down once then press menu(tick) twice. this should now print out a information page and also at the same time you will have proven there is nothing wrong with the printer.#
BEFORE re-connecting the network to the printer - CLEAR ALL PRINT Queue's from the workstations (pc) as the likely fault is a corrupt print file, if you dont clear the print queue then the printer will attempt to print the failed file again and again and again and again and ag-sod it you got the idea
Feb 18, 2014 | HP LaserJet 2420 Printer
Network card wont connect
Step 1:
wireless or hard wired ethernet connected ?
The HP Mini has built-in Bluetooth capabilities that allow you to connect keyboards, mice and other Bluetooth-enabled accessories without using wires. Before you use the Bluetooth on an HP, you first need to enable it. Powering the Bluetooth on the computer on is easy to do, however, and should only take a few
Click on the start menu from your computer's desktop. Select "All Programs" from the options on the Start menu. Choose "My Bluetooth Places" from the program menu. Choose "Power On" from the menu when it appears. Select "Search for new devices" from the menu to locate and connect your Bluetooth accessories to your Mini.
Feb 25, 2013 | HEWLETT-PACKARD ProBook 4320s C Notebook
HARD DRIVE FAIL GX612AA-ABA HP
There are two SATA harddrives, and they are 320GigaByte apiece.
(320GB) (Spindle speed? 720RPM)
http://www.pcrush.com/product/Desktop-Computers/133361/HP-Pavilion-m8330f-Media-Center-TV-Desktop
Regards,
joecoolvette
Jul 07, 2012 | HP GX612AA Pavilion Media Center M8330F...
Hello, i have a hp notebook which code 31 error on
http://support.microsoft.com/kb/932520
Microsoft says to Ignore the problem, and the adapter will continue to work correctly. If the message is really annoying maybe you can try turning off IPv6.
Control Panel\Network and Internet\Network Connections
right click your network card>properties
uncheck the IPv6 box
that'll turn off IPv6-then just disable the adapter driver
Feb 23, 2010 | HP Pavilion dv6000z Notebook
I need to uninstall and then reinstall my microsoft network adapters because they are not working properly and i am not able to connect to the internet so i need to know where can i download the network...
Do not worry, to uninstall the driver, open device manager. under it choose network adapter and uninstall the Wired or Wireless drivers which you are supposed to.
Open HP.com
type the product number. EX: FZ017PA. (this is a Compaq CQ45 model). You will have something similar to it.
To locate the product number:
http://h10025.www1.hp.com/ewfrf/wc/document?tmp_renderType=findModel&lc=en&dlc=&cc=us&docname=c00033108&product=18703
Now, type the product number in the search area of HP.COM, choose your product and click support and drivers download. VOILA.!!!
regards
Jan 03, 2010 | Compaq Presario Notebook
Unable to connect to internet. tried suggestions there is not network adapters and there is no network & sharing center in the control panel . what do i do
Download the drivers of the network adapters and the flash bios update from hp.com using your product number and then choosing software and driver downloads .
Oct 20, 2009 | Compaq Armada M700 Notebook
Card reader disconnected from motherboard and can't find where to reattach. Only space is top with blue base but still says disconnected. Esystem tower
Does it say the error in windows or on start up?
what is the exact error?
Usually they are connected to where one would connect the USB internal connector it should say USB.
May 13, 2009 | HP GX612AA Pavilion Media Center M8330F...
Error code 31 4 to 6 network adapter
Check these things:
  1. Is you Ethernet adapter Active
  2. Is your Cable the correct one (NOT a cross over)
  3. Refresh your IP Address for your Ethernet Card
  4. Reboot your computer and power down your modem, then power the modem up AFTER your windows is logged on
  5. Verify your modem "really" can connect, use another computer.
  6. Verify the are no network issues with your ISP
Apr 16, 2009 | Acer AM1610-UD2180A DT E2180 2.0G 2GB...
I have a compaq presario 700 laptop that is no longer charging.
The notebook battery may have a defect if it will not power on the notebook and if it will not hold a charge. The battery indicator light on the notebook either does not light or always blinks orange. The notebook operates correctly when connected to the AC adapter.
A battery that will not charge may be the result of an AC adapter failure, a system board failure, or a battery failure. Perform the steps below to diagnose the failure.
Troubleshoot the power supply
To verify that the AC power supply is functioning properly, follow the steps below.
1.
Plug the AC adapter directly into a functioning wall outlet, and plug connector into the computer. Do not plug into a power strip, surge protector or secondary power source.
2.
Verify the following operation and take the appropriate action:
That all power cord connections are secure.
If the AC adapter connection to the notebook is loose, the connector may be damaged and require repair. Contact HP service and support for further assistance.
That the power button or power LED is lit when the computer is on.
That an LED on the AC power supply adapter is lit when plugged into an AC wall outlet (not available on all AC power supply adapters).
That the AC power supply adapter is the correct type.
Different notebook models require different AC power supply adapters. You will need to know the Product Number of your notebook to determine the Part Number of the replacement part. Click Start > HP Help & Support to view the product name, product number, and serial number that you'll need to have to speak with HP Customer Service.
View the See Also section for information about locating HP Help & Support in your operating system.
Troubleshoot the System Board
If you've verified that the AC power functions properly, troubleshoot the PC's system board by following the steps below.
1.
Remove the battery, and keep the notebook connected to AC power.
2.
Press and release the Power button to start the computer.
If the notebook PC powers on , then the AC adapter and system board are functioning properly. Go to Troubleshoot the battery .
If the Power LED is off , then the AC power adapter needs to be replaced. Contact HP Service and Support for further assistance.
If the power LED is on , but the notebook PC does not power on, then the notebook PC needs to be repaired. Contact HP Service and Support for further assistance.
3.
Shut down Windows by selecting Shut Down from the Start Menu.
If you have verified the AC power supply and system board are functioning correctly, troubleshoot the battery by following the steps below.
1.
Insert the battery into the battery compartment on the bottom of the notebook PC.
2.
Connect the AC power supply and allow the battery to charge for 15 to 30 minutes.
NOTE: The Battery Charging light should be on while the battery is charging. If it is not on, check the AC power adapter connection to the notebook PC.
3.
Unplug the AC power adapter cord from the notebook PC.
4.
Press and release the Power button to start the computer using only the battery as the power source.
If the PC does not power on, then the battery needs to be replaced. Contact HP service and support for further assistance.
If the notebook PC does power on, the battery is functioning properly.
NOTE: If you have purchased a second battery for your notebook PC or you have access to an identical battery, you can also check the battery by inserting the second battery into the PC and performing the Troubleshoot the battery steps again.
Apr 14, 2009 | Compaq Presario 700 470024-192 Notebook
Microsoft Windows Vista Ultimate Edition Logo
52 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
