Question about SanDisk Sansa Shaker SDMX9N-512 MP3 Player
SANSA SHAKERE PROBLEM, PLEASE! HELP ME! (i'm from Paraguay)
Hi, I have some troubles uploading files to the Sansal, when I drag the song to the "sansa folder" a message appears, it says that the Disk is protected and can't be "re-writed"(dunno how to translate that phrase..) therefore, I'm not able to upload music to the MP3 Player....HELP PLZ!
Mail: joacodenis@gmail.com
Messenger: metaljoaco@hotmail.com
Thank you...Joaquin-Paraguay
  • Anonymous Dec 26, 2008
    blaa blaa blaa....blaa
  • 8,596 Answers
Right click the folder and select Peoperties. Then select the Sharing tab - allow sharing. Try again.
Posted on Dec 14, 2008
How to upload music files from sansa clip to IMAC
Plug the device to pc, it will appear icon "sansa clip..." or removable disk, double clip on that >> double on Music folder >> drag & drop songs from Music to pc.
Good luck
Apr 29, 2010 | SanDisk Sansa Clip MP3 Player
How do i chare it with power and how upload the
The Sansa m250 uses one AAA battery, it doesn't charge.
To put songs on it, plug it into your computer via the wire it should have come with. The computer will take a while and then a box should pop up, where you can select to view files. Just drag and drop songs into that folder.
Jul 17, 2009 | SanDisk Sansa m250 MP3 Player
My Sansa WONT read my micro and wont upload songs
You should try to copy your music/files to your computer and format your SD Card. After that, copy your music/files back to the SD Card.
Feb 09, 2009 | SanDisk Sansa e200 MP3 Player
Cant load songs
hi sir
please try to re-install and try.
if it not then go to the tools >setting>phone>restore factory setting.. and type ur passward. i think it will work.. don't forget to fix
Sep 02, 2008 | SanDisk Sansa e260 MP3 Player
Loading My ITunes library into new Sansa Clip
Hey guyi,
According to information provided by the manufacturer (Sandisk), the Sansa Clip MP3 player can use two different methods to upload songs: a simple drag-and-drop interface, or syncronizing the player with Windows Media Player.
With the traditional drag-and-drop interface, you would need to connect the player to your computer and select the "Open device to view files using Windows Explorer" option when it is presented. Once you have done this, you should be able to double-click on the "Sansa" player and then the "Music" folder. After this folder has been opened, you should be able to drag and drop (or copy/paste) the files into this folder to upload them to the player.
For more information or instructions on how to add files to your Sansa music library using Windows Media Player however, you may wish to refer to your owner's manual or the following link on the manufacturer's website:
http://www.sandisk.com/assets/File/Downloads/user-guides/clip-usermanual.pdf
Unfortunately Windows Media Player does not currently appear to support the ability to directly import iPod playlists, but if you keep most of your music files in the same folder/directory on your computer, both programs should be able to share the same music library. Please keep in mind that this may only apply to music that you loaded onto the computer yourself and other unprotected file formats that both programs recongize (like .MP3 files), and may not necessarily apply to copy-protected songs downloaded from iTunes or other online music services.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 06, 2008 | Audio Players & Recorders
Cant load songs
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Can't load songs
ive had this same problemo. you cant use the media converter to drag and drop songs. you have to download your songs or rip them onto windows media player. you plug in the sansa and then when its recognized there will be an area on the right hand side where you drag the songs and they appear on sansa.
SanDisk Sansa e250
Well the SONGS folder might be hidden [happened to me]
Steps to see hidden folders:
-My computer
-Tools
-Folder options
-View
-Show hidden files and folders
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
Formated the SanDisk Sansa E280
You dragged & dropped files in recovery mode? Recovery mode is only for re-installing the firmware or formatting the device if it is unresponsive. If you are wanting to drag and drop files onto the device, the music needs to be put into the Music folder on the device. If you do not see the Music folder, you will need to enable hidden files and folders on your PC. Best of Luck. p.s. - you can add to this question this doesnt work.
Oct 08, 2007 | SanDisk Sansa E280 MP3 Player
Wont upload music onto device!
hey, the same thing just started happening to mine. Let me know if u find a solution.
Jan 17, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Shaker SDMX9N-512 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
