Question about RCA S1001 (1GB) MP3 Player
When I turn ON my SC1001A (by pushing the triangle beside the top right corner of the screen) and although the manual switch on one end of the player is pointing at the "Unlocked" side (or if the switch is on the "Locked" side, as well, this happens), after the "RCA" image shows for about 3 seconds, then the screen shows a small lit square with "keys locked" apears for 2 seconds, then "Shutting down" flashes briefly then the machine shuts down. I cannot get past this event to use the MP3 player, at all. Can anything be done?
Right half of screen out
This is a problem in the processing of the video signal, cheaper to replace the DVD player.
Mar 06, 2012 | Televison & Video
Dvd player is not recognizing the dvd when i try to play it.
1. Click start -> Click Run (Windows XP)/ Start Search (Vista) / Search Programs and Files (Windows 7)
2. Type Regedit
3. Click on the triangle/plus sign beside HKEY_LOCAL_ MACHINE
4. Click on the triangle/plus sign beside SYSTEM
5.Click on the triangle/plus sign beside CurrentControlSet
6.Click on the triangle/plus sign beside Class
7.Click on the Folder {4D36E965-.......}
Note: The first 4 digits might be the same we need the digit that has a 65
8. Restart the computer and your done
Thanks for choosing
Jun 08, 2011 | Computers & Internet
Exclamation point in triangle blinking on dashboard
Hi, The exclamation point in triangle blinking is the "Emergency Blinker" This blinker turns on all all of the turn signal lamps at all four corners of the car. Left and Right, Front and Back. The triangle represents the European symbol for roadside emergencies. In fact on European Mercedes and other cars there is a triangle shaped reflector you can put behind the car so that other drivers know you have an emergency. THAT TRIANGLE ON YOUR DASHBOARD IS A BUTTON. PUSH IT ONCE. THE BLINKING SHOULD STOP. If you have a roadside emergency, and are broken down by the side of the rode. Push the Red Triangle and your lights will blink on and off ouTside to say, in effect "help".
Hope this helps.
Jan 13, 2011 | 2005 Mercedes-Benz C-Class
How do the corner lights switch on.can not find a switch
Hi and welcome to fixya,
The corner light switches on if and only if you switch the signal light (left handle bar) to left or right. pushing it on the center will deactivate it. well this is the basic for most bikes. I don't know if your bike has the same mechanism. Getting back to the topic. The corner lights will also turn on when you push the hazard button. this is with the triangle sign. Locate it either on top of the left handle bar or the right handle bar.
To answer your question further, the corner lights switch is controlled electronically or mechanically through a relay or contactor switch. This makes the ticking sound whenever you activate it.
Hope this helps
Dec 27, 2010 | 1998 Honda GL 1500 SE Gold Wing
How do you turn the volumbe up and down on my camnex mp3 player [t850 4g]
push the play button (V on the top of the unit - other end is pause II) until the volume level (number in the lower left corner beside the speaker icon) turns green (2 or 3 seconds), then push the FF button >>I to raise the level or the REWIND I<< to lower the level
Oct 20, 2009 | Mach Speed TRIO Onyx MP3 Player
Hi my coby MP605 wont turn on
hold your hand on the power switch for a bout n hour
Nov 29, 2008 | Audio Players & Recorders
Yellow circle..
No worries. Instead of going to the default "Music" menu, you must have shut off your player when you were in the "Now Playing" menu. Just press the "menu" button to go to the main menu, and go from there.
-Tha Mp3 Doctor
Sep 03, 2008 | Philips GOGEAR SA6045 MP3 Player
Power buton
Hold the power button for about 2-3 seconds and the release it. If the battery is charged, it should come on.
Aug 30, 2008 | Apple iPhone Smartphone
Peoblem in my shinco PMP-1700 DVD
try lightly pushing the small white button at top right hand corner of touch pad a few times, I have found this normally brings the screen to life again
Mar 14, 2008 | Shinco PMP-1700 Portable DVD Player with...
RCA S1001 (1GB) MP3 Player Logo
44 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
