Question about GE Washing Machines
Water pump on washing machine is clogged. Model #WHDSR109J5WW.
JOE LLAMA
  • 26 Answers
SOURCE: LG Intello 7KG Washing Machine
You may have some articles that made their way into the pump housing. Alot of times I see dimes get stuck in the ports of the pump, remove and check out thoroly and also check hoses coming to pump for little son of a gun articles that like to hide.
Posted on Apr 01, 2008
the dr
  • 447 Answers
SOURCE: frigidare front load washing macine leaks water
Sounds like the dispenser is leaking somehow, there is no filter that would cause it to leak. Remove lid of washer by screws on back lip and inspect during fill to see where leak is.
Posted on Jan 20, 2008
jsrock516
  • 5911 Answers
SOURCE: washing machine clogged with dirt
You probably have sediment clogged in the inlet hoses and/or screens in the water inlet valve of the washer. First, turn off your water taps in the back of the washer. Disconnect the hoses one at a time and insert them in the wash tub. Turn the water taps back on to see if you are getting water through the lines. If not, you will need to remove the hoses and flush them out. If the hoses appear fine, inspect the sediment screens on your water inlet valve (this is where the hoses connect to). You can use cotton swabs to remove most sediment. If you cannot get the screens to clear and/or if sediment has gotten inside the water inlet valve, you will probably have to replace it. Try flushing the lines and cleaning the sediment screens, first, though. I hope this helps you.
Posted on Aug 04, 2008
  • 35 Answers
SOURCE: Leaking from the bottom of maytag washing machine
a good possibility that the front door seal is leaking check for tears or any small holes if it is that it it is hard to do
Posted on Jun 07, 2009
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
I have hitachi washing machine appear lode model SF-100JJS error p9 please tell me what is solution, ?
That is an F not a P. The codes are generic. It is a pump clog, block, or defect.
SOLVED: I am getting F09 error code - Kenmore Elite HE3 Washing ...
https://www.ifixit.com/Answers/View/47460/I+am+getting+F09+error+codeMar 20, 2011 - The F09 error is a water pump problem, either clogged pump, or pump malfunctioning, ... The Kenmore Elite HE3 is a washing machine by Kenmore. .... hi i have f9 display always when i start machine can you help with this. hitachi washing machine f9 error Google Search
May 09, 2016 | Washing Machines
I have a fisher pykel washing machine model WL80T65CW1 and it keeps coming up with a code 245
That is a water draining problem. From Sears: "Remove any clogs from the house drain for the washer. Remove any clogs or kinks from the washer drain hose. Unplug the washer and check the drain pump for a clog. If the drain pump is defective, replace it."
May 12, 2015 | Fisher Washing Machines
Whdsr109j5ww, this is a ge washing machine. Can you tell me the size of the machine (capacity)?
The GE Appliances support page describes this as a 3.2 cubic foot Super Capacity washer.
I hope that was helpful to you, good luck and take care.
Aug 07, 2011 | Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
WHDSR109J5WW WASHER WILL NOT SPIN
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | GE Washing Machines
Does not pump water out model fwt445ges2
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Jul 16, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer machine will not drain water .the model is WJSR2070
2. Water Pump
**The most common issue will be an obstructed hose or, line.....
Jul 11, 2009 | GE WBSR3140DW Top Load Washer
Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Dec 06, 2008 | Roper RAS8445KQ Top Load Washer
Clogged washer pump
you have to take out the little motor that drains the water and clean it up , first you open the front panel or back panel depending of the model , second follow the DRAIN HOSE to where its attached to the DRAIN MOTOR , remove the motor for cleaning , its probably clogged.
Apr 05, 2008 | GE WBSR3140DW Top Load Washer
Kenmore 90 washer won't drain
Check first drain line or water pump to see if they are clogged.
2. Water Pump
Jan 14, 2008 | Washing Machines
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
