My screen is flipped sideways on my computer like someone hit rotate but it doesnt have a rotate button.
    Scholar:
  • 132 Answers
Your video card software has likely got the settings..
Right click on you desktop
Slect properties
Slect settings
You should now see about 6 tabs - one of which will configure your display card..in here, there will be a 'rotate' function.
Hope this helps.
Posted on Aug 16, 2008
My dell screen is sideways
On Windows 7, it says graphics options instead of monitor settings.
Typically, to fix this type of error, you would use ctrl+alt+up arrow key to flip the screen right side up.
(incidentally...
ctrl+alt+right arrow = flip to the right
ctrl+alt+left arrow = flip to the left
ctrl+alt+down arrow = flip upside down)
If that doesn't work, or if your keyboard shortcuts have been disabled, right click on the desktop background, click on Graphics Options, then Rotation, then Rotate to Normal.
Also, if you have Intel Graphics installed on you computer, the software might have reset the default rotation setting. To fix this, right click on the desktop, then click on Graphics Properties. This should bring up the Intel Graphics window. Choose Advanced Mode, and click OK. Find the rotation settings (right side, 2nd from bottom), and choose Rotate to Normal.
Feb 11, 2015 | Dell Inspiron Computers & Internet
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
Picture received from friend is sideways - is there a way to edit the way the picture looks or downloading them to correct?
find out where the image is on your computer and right click on it and go to open with then click paint. Once in paint click on the Image button at the top and go to flip/rotate and rotate the picture 90 degrees
Sep 23, 2009 | Computers & Internet
Toshiba 16''laptop. Image sideways on LCD Rotated 90 dergrees. Was on Walmart web site and when I searched the site for an item the screen turned sideways Model satellite A105-s4334
Many video card's software utilities include keyboard combos that can flip or rotate the screen. Try to go into the video properties by right clicking on a blank part of the desktop and selecting PROPERTIES. Look around on the Settings > Advanced area for rotation options. Chances are that you accidentally hit the right key combo to rotate the screen and it had nothing to do with the website that you are on.
Jul 07, 2009 | Toshiba Satellite A105-S4024 Laptop PC...
I hit a button or something and it made my toshiba computer into a tablet or somthing. i dont know how to make it go back into a normal mode. its toshiba a215
Is your screen sideways or upside down? If so, use this:
Just like a ctrl-alt-del except
press ctrl-alt-up arrow
ctrl-alt-down arrow flips it upside down.
ctrl-alt-left and right arrows will rotate the screen sideways.
Dec 12, 2008 | Toshiba Satellite A215-S7422 Notebook
Screen is sideways
this is ok, either someone's yanking your chain, or you accidently activated an ability of your graphics chip, this mode is for "tablet" PCs which have a portrait mode. you most likely have an icon in the bottom left of your screen by the clock for graphics settings, one of these will be to rotate the screen.
it is also possible that this ability may be programmed to one of the hotkeys, however without model info I cannot tell.
your mouse should have flipped too, if not then someone may be fooling with you..
check if you can click your icons... if you cannot then right click on the desktop and change the wallpaper on your desktop, also re-enable your icons from this menu, you may also need to unhide your start bar
hope this helps
Sep 27, 2008 | HP Computers & Internet
Icons sideways on my toshiba laptop
Go to the desktop
right click
go to Graphics Options>Rotation>Normal
Hope it's fixed now
:D
it works on my Toshiba Satellite U400 with intel graphics media accelerator
Jan 19, 2008 | Computers & Internet
Screen has rotated 180 degrees
I have lots of Dell monitors and none of them has the ability to flip the screen orientation built into them. What I suspect has happened is he accidentally hit a keystroke combination that activated a feature in your video card driver. If you have the built-in Intel Extreme Graphics read this link and let us know if it helps. http://engtech.wordpress.com/2006/08/01/stupid-windows-features-monitor-display-turns-sideways-or-upside-down/
Dec 30, 2006 | Dell E173FPc 17" TFT LCD Flat Panel...
Computers & Internet Logo
325 people viewed this question
David Payne
David Payne
