I have a Sentry Security safe S3607. \if the eletronic key pad fails (loss of power) do I need a new battery or key?
  • 76 Answers
SOURCE: lost key
To order replacement keys, for small chests and files, you will need to know the key numbers which can be found right around where the key goes in. It should be a stamped number, letters, or both located around the keyhole. For Personal, Home and Home/Office Safes, you will need the model number and serial number. I think that the most economical place to buy keys is from www.SentrySafeShop.com. You can do a search for "lost keys" and it will give you a screen where you can enter your model number and key number. (It is a very easy screen to use. They just need 1.)Model # and 2.)Serial or Key #.)
In Summary:
For Small Chests or Files: A lock reference number is required. It will be a letter, a number, a letter and number, or "blank" (no letter or number), engraved/located on the silver cylinder of the lock. These are model numbers 0500, 1100, 1170, etc...
For Personal, Home and Home/Office Safes: (model numbers will begin with: S0, S3, S4, S5; I0, I3, I4, I5; A3, A4, A5; J3, J4, J5; L0, L3, ,CS,CSW,DA,DS,KS,KSW,MS,MSW,OA,OS,and SC): Indicate your model number and the safe serial number found on the front right-hand side of the door, between the hinges.
Here is the direct link to the key replacement screen: http://www.sentrysafeshop.com/Keys-Sentry-Safe-Replacement-Keys-p/keys.htm
Posted on Apr 28, 2009
  • 80 Answers
SOURCE: sentry safe battery life
http://www.sentrysafe.com
the instructions are located link above.
mine lasted a couple of years...
mj
Posted on Sep 07, 2009
  • 80 Answers
SOURCE: Sentry Safe A3750 won't open new batteries
call them
mj
BElectric
  • 1140 Answers
SOURCE: i have a sentry safe
Frank -
You can download your manual here:
http://www.sentrysafe.com/CustomerCare/Product_Manuals
You will need your model number to select the correct safe. The number listed above is your serial number.
Hope this helps.
Posted on Oct 18, 2010
  • 3 Answers
SOURCE: I need the instructions on
http://www.sentrysafe.com/Products/169/MS0100_Combination_FIRE-SAFE_
Scroll to the bottom and click on Owner's Manual.
Posted on Mar 25, 2011
Have key and code...safe will not open
Sentry Safe not unlocking - YouTube
? 0:36
https://www.youtube.com/watch?v=4mbtSUAoS6w
May 8, 2013 - Uploaded by 1diazsantana1
When i put the pass-code on my Sentry Safe the handle will remain locked and I ... mine dont want to open either! i get 5 beeps ... How To: Open A Locked Sentry Safe If You ForgotCombination Code Or Lossed Key Model Is ...
Opening a Sentry Safe with a Rubber Mallet, some WD-40 ...
idoneitmyself.com/.../opening-a-sentry-safe-with-a-rubber-mallet-some-...
May 7, 2010 - Since this safe can only be opened with an electronic code, this is a .....i have sentry V260 electronic with key, no handle. cant find key and ...
Jan 05, 2016 | Sentry Safe Fire-Safe .8 Cubic Ft....
How do I open my Sentry Safe when the batteries have gone dead?
Some safes come with a key to open it with when this happens.key hole is cancelled under or near the keypad...not sure if yours is one of them.or there maybe a slot to plug in a battery pack .good luck..hope I have helped.
Oct 03, 2014 | Sentry FIRE-SAFE Combination Safe DS3431,...
I cannot open sentry safe tc8 331. How can I change the batteries and where are they
This safe came with two long keys (maybe 6 inches). Rotate the key pad and it will come off. Insert one of the keys in the slot and turn. Should be able to pull the locking arm down now and open the safe. The batteries are inside, behind the plastic plate on the door. It slides up a little and then comes off.
Jun 27, 2011 | Sentry Safe TC8331: Safe Fire-Safe ®...
I have purchased a second hand Sentry S3607 safe. I is locked and I need the code and also the cover for the battery cover. Where can I get help
Lost combination: First, find your safe's Model and Serial Number. The Serial Number is printed on the small label beside the door hinge (outside). Send a copy of this, a notarised letter (last name must be different than that of owner) stating you are the safe's owner, and a check or money order for $12.00* (U.S. funds) to: Sentry Group, Dept. 200, 882 Linden Avenue, Rochester, NY 14625-2784 USA. If using a credit card (Visa/Mastercard only), call 1-800-828-1438 and fax your Model and Serial number with the notarised letter
to 585-381-2940.
May 10, 2011 | Sentry Fireproof Safe
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
Aug 10, 2008 | Sentry Fireproof Safe
How to open my safe with the code
Apr 18, 2008 | Sentry Fireproof Safe
Forgot how to open my fireproof lockbox
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
Nov 03, 2007 | Sentry Fireproof Safe
Computers & Internet Logo
337 people viewed this question
David Payne
David Payne
