Question about LG LDF6920ST Fully Integrated Dishwasher with 5 Wash Cycles 3 Spray Arms
We have an LB dishwasher P/No.: 3850DD3006J. We love it. It doesn't work any more. When you turn it on it runs for about 5 min. and then gives a message that says: OE and all the lights flash. Turned the power off and on: put it on rinse and it ran for 14 minutes - seemed to work fine but after 14 minutes it stopped and the OE was displayed again and it stopped.
MNTECH
  • 1543 Answers
SOURCE: error code oe
That's not OE, that's DE = Drain Error. Open the access door at the lower left on front of the machine. Use the small hose to drain the remaining water out of the machine, then open the large knob which is attached to the filter. If there is nothing in the filter, you may have an object which made it past the filter and is blocking the pump impeller, or the impeller may have come off the pump motor shaft, which would require pump motor replacement.
Posted on Oct 15, 2008
SOURCE: oe code on LG dishwasher following garbage disposal replacement
Well, there is the plastic block in the garbage disposal where the drain hose goes on (as not every disposal will be attached to a dishwasher). Punch this out with a screwdriver, fish the plastic plug out with your hand and reattach the hose. You are good to go.
Posted on Dec 01, 2008
  • 3230 Answers
SOURCE: Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Posted on May 06, 2009
  • 3230 Answers
SOURCE: Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
Good Luck!!!
  • 500 Answers
SOURCE: My LG dishwasher is stopping
Hi rebeccasolom,
OE means "Outlet Error"
The drain pump is either clogged or the outlet hose is kinked.
- Inspect the Drainage hose at the back for kinks.
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it.
Kind Regards :-)
If you found this solution helpful, please rate it.
Posted on May 26, 2011
Bosch shy66c06 doesn't turn off when door opened
This is a partial solution. After reading lots of other similar descriptions (none of which were automatically identified by FixYa, btw), we realized it was probably water in the 'catch basin' or whatever that pan (white plastic) below the sump pump is. Sure enough, there was about 1/2" of water in the pan. We hoped that by overriding the float switch and watching it run through a cycle, we would be able to see where the leak came from. Unfortunately, running a rinse & hold (10 min) didn't do it, so we are about to run it on a quick wash (56 min). To do this, we have left everything connected (power & water), and removed the toe kick cover, to give us access to the works below the main compartment. A long chopstick works well to get at the red float switch actuator; we used two of them to dip a washcloth in the water to soak, and then remove the washcloth and wring it over a bowl. Slow, and tedious. But the alternative was to do the 3 hr teardown just to get the pan dried before we could run it through a complete cycle. We're still hoping this will let us see the leak.
Jan 11, 2013 | Bosch 24 in. SHY66C02 / SHY66C06 Built-in...
My x5 3.0i 2006 t won't start this morning but temperature, gas level clock were wrong so I turn the engine off and restart a couple times it won't start and I saw message trans. false safe...
no. I'd suggest to disconnect a battery for 15 mins, reconnect, wait for 5 mins and try to restart. If it doesn't help (sometimes there's a program block to prevent stealing equipment) call a dealer
Aug 04, 2017 | 2003 BMW 5 Series
Hi, We have a G638 plus and have it connected to the cold water tap. When we press start, it fills the machine with water and once the machine has been filled, the program doesn't start and after 2-3...
Hi
Intake/Drain light flashing means an issue while draining. You would need to check for air gap on the dishwasher, it may be clogged. It prevents dishwasher from draining, sometimes the drain flow is restricted due to gunk. Cleaning or bypassing the air gap will resolve the issue. If this doesn't resolve the issue then it is due to seized (or stuck) drain pump. Disconnect the power to the dishwasher or turn off the breaker to the dishwasher. Tip machine on its back; remove screws that hold the bottom tray on. Remove the hoses to the main motor, remove electrical connections & remove motor (single screw holds motor, it is on the outside back of the machine). Try to rotate the motor (use WD40 is necessary). If you cannot rotate it, then motor will be required. If the error still appears then cancel the error message, turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Switch the appliance off and then back on again. Hope this helps... Please post back if you need more information.
Daniel
Aug 16, 2011 | Miele 24 in. G638 Plus Free-standing...
It wont clean the dishes. The water is going in I can hear it but My thoughts are the arms are not spinning. I did check and they are not obstructed but its hard to see if they spin. How can I tell if...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 07, 2011 | LG LDF6920ST Fully Integrated Dishwasher...
Brand new Matytag MDB7749AWB Dishwasher does not work correctly. As soon as the power was turned on, all three cycle indicator lights ('Wash', 'Dry', and 'Clean') came on and always...
Try putting the unit into a test mode. This my clear your issues otherwise call for service.
One of two ways to do this.
In standby (no lights) Press the combination of buttons:
hi temp wash > sanitize > hi temp wash > sanitize > hi temp wash
All lights will come on and the washer will run a test cycle anywhere from 5 to 10 minutes.
If that button comb doesn't work use:
heated dry > sanitize > heated dry > sanitize > heated dry
May 27, 2011 | Maytag Dishwasher
My dishwasher is leaving sediment on my glasses
Here'sthe best and final trick which I continue to do about every 6 weeks orso: Pour 1-2 cups white vinegar into the dishwasher and run it throughits longest cycle, using the hottest water setting. This will dissolveall the hard water mineral deposits and clean the dishwasher's pipes out reallywell with none of the danger associated with muriatic acid. And it's verycheap. If that doesn't do it tryreplacing the pump.
May 11, 2011 | Maytag Dishwasher
My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
May 02, 2009 | LG Dishwashers
LG LDF6920ST Fully Integrated Dishwasher with 5 Wash Cycles 3 Spray Arms Logo
337 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
