Question about Amana Refrigerators
My amana reffigerator ice maching is making shells of ice cubes.
    Sergeant:
    Champion:
  • 257 Answers
This indicates not enough water getting to the tray. check the ice maker shoot where the water comes out to see if it's obstructed with ice. You can defrost it if so, but you may need to replace the water fill solenoid in the back of the refrigerator where the supply line connects.
Posted on May 28, 2011
Melting/refreezing ice in the ice makes
If the ice is the only item that appears to be melting or defrosting. I would believe the most possible issue. The icemaker is leaking intermittantly into the bin and freezing the cubes inplace.
Ric
Mar 09, 2010 | Amana ABB2527DES Stainless Steel Bottom...
HI, our Amana ice maker produces only a shell of an ice cube sometimes. It happens during half of a harvest is emptied. We turn the ice off and let it sit for a few hours and then some harvests are...
you are having a problem with not enough water getting into the ice maker.
we call this getting "hollow cubes"
you have to clear or replace the valve that connects to your house water line. most are whats known as a "piercing type" valve. they get plugged or break into the water line of your house.
you can try to shut off the valve and then turn back on and see if you get full size cubes after that.
most likely you will have to replace the valve with a "drill type" of valve from your local hardware store.
this is very common and the new valve will fix your problem.
Jan 08, 2010 | Amana ATB1832AR Top Freezer Refrigerator
Too much water in amana bottom freezer ice maker
Try closing the valve partially on the incoming water to the icemaker. Close it to a trickle. Water is fed to the icemaker by a short timer. Too much water pressure means too much water. If this helps it but not solve it, get the spec sheet for the icemaker and adjust to make cubes smaller. This shortens the timer. If no joy, you may need to replace icemaker module.
Sep 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ice cubes not freezing completely before dumping
check evaporator fan if working or u may have a leak , or check condsr fan motor :)
Aug 28, 2009 | Amana ARS2464B Side by Side Refrigerator
Not making ice
replace complete im and water filter , 100 % it will work :)
Jun 26, 2009 | Amana Refrigerators
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Amana bb120 bottomfrezer ice makerwon't work
HOLLOW ICE IS ALWAY A SIGN OF A WATER INLET VAVLE FAILING
May 31, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
63 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
