Question about Nintendo Wii Console
Unit not responding to handheld piece - Nintendo Wii Console
  • 50 Answers
Hi there
you have the no sync error
This needs to be repaired.
you can send the console to Nintendo for free if in warranty, if out of warranty then this will cost you around $150, the whole process will take 4-6 weeks
I prefer the Wii repair guide Method, download the guide and follow the simple step by step instructions and fix the problem in less than an hour, no hassle, low cost everybody is happy.
Best Regards
WiiRestore
Feel free to leave a comment if you need assistance
Posted on Jun 01, 2011
My EnGenius cordless is not responding.You can not answer or make calls on it.I tried to turn it off-it's not responding
It has somehow unregistered with the base unit. Go to the base with your handheld. On the handheld menu, you can select "register". Try that by first. Next, press the gray (usually) button on the base unit and register the cordless again. If no go, de-register the cordless and try the steps again. Post for more if those did not work.
Feb 17, 2015 | EnGenius Lands Phones
The calculator writes 8 all over
During operation of the TI-Nspire handheld it may be necessary to reset the device. Circumstances which may require a reset include; keys not responding, device will not turn on or a garbled display. To reset the device:
• Remove the keypad (for TI-Nspire with ClickPad, TI-Nspire with TouchPad, and TI-Nspire CAS with Touchpad) or the battery door (for TI-Nspire CAS with ClickPad) and remove at least one battery from each column of batteries. After 2-5 seconds, reinsert the batteries but do not turn the handheld on.
For the TI-Nspire and TI-Nspire CAS handheld units with ClickPad:
• Hold down [home] [enter] [P].
• While holding these keys press [on].
For the TI-Nspire and TI-Nspire CAS handheld units with TouchPad and the TI-Nspire CX and TI-Nspire CX CAS:
• Hold down [doc] [enter] [EE].
Please Note: For TI-Nspire Family handheld units that contain rechargeable batteries you can alternatively hold the above keys while pressing the [reset] button on the back of the handheld rather than removing the battery for 2-5 seconds.
• The device will boot up as in the previous reset, but will display a menu with the following options. Please try options 2, 3, and 4 in that order.
• 1: Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
• 2: Delete Operating System - The operating system will be deleted without deleting any documents on the system.
• 3: Delete Document Folder Contents - This will delete the user's documents, but will not delete the OS. Selecting this option is the same as using the RESET hole on the back of the unit.
• 4: Complete Format - This will delete the OS and all documents for a total wipe of the handheld.
Please note that the second and fourth option will require that the OS will need to be reinstalled
Mar 12, 2014 | Texas Instruments TI-Nspire Graphic...
A Sony Clie PEG-N610C has been in storage for years(it appears unused). Neither the AC charger or the cradle charger will make the charge indicater light respond. It is completely dead in all respects. Can...
Since the battery is within the unit it can leak or go BELOW the threshold level of the cell wherein the charger will not work to charge the unit. However if you can confirm the battery voltage to be below, use a multimeter to check, then before replacing use a JUMP START with an external limiter DC bench supply , you can use a series resisitor of about 47 ohms with a 6-9 VDC.
If the battery takes up voltage the see if the charger will respond and the set will power.
Sep 30, 2011 | Sony CLIE PEG-N610C Handheld
My sgx is locked up and won't do anything - won't
Remove the battery and the unit will shut down. Wait 1 minute, install battery and the unit should power up and work as normal.
Sep 18, 2011 | SkyGolf SkyCaddie Handheld GPS Unit
My sceen just freezez and wont respond
What you can do here first to correct the problem is to reset the unit, follow this to reset the unit.
To reset the unit if it is hung, slide the power switch and hold for 8 or more seconds until the unit resets.
Jun 27, 2010 | Garmin Nuvi 760 Handheld GPS Receiver
Touch screen would not respond
HI,
Here is a link to get you to the Palm support page. You can do a phone call to the but it will cost you $25. There is also a chat feature and that looks like it is free so hopefully that will help.
Best wishes.
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/supportservices/page_en.html
Aug 16, 2009 | Palm Z22 Handheld
Where can buy spare parts
I need a new blade aftermarket
Sep 27, 2008 | Philips HR1358 Handheld Blender
Treo600 Touchscreen doesn't respond.....
Try running a piece of paper around the edge of the screen. There may be was something stuck in there, pressing the screen slightly and causing it to not respond to the stylus
Jan 14, 2008 | Palm Treo 600 Handheld
Treo 600
Try running a piece of paper around the edge of the screen. There may be was something stuck in there, pressing the screen slightly and causing it to not respond to the stylus4.gif.
Jan 01, 2008 | Palm Treo 600 Handheld
PEG NX70V
are you syncing alot of medai or do you have large files on your handheld? if you do manually delete them from either a memory card or the handheld. this happens to me when i try to hotsync my palm, just unplug the hotsync cable when it seams to stop then reset your device. you could just take out your memory card too.
Jun 28, 2007 | Sony CLIE PEG-N760C Handheld
Nintendo Wii Console Logo
50 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
