Question about Yamaha Boating
Yamaha FX high output. I am trying to start it after replacing the battery from winterization and it will not crank but the unlock light it flashing. How can I fix it?
  • 608 Answers
Hi, hold down the unlock button on your remote until the ski beeps then it should crank. Hope this helps, regards Phil.
Posted on Jun 01, 2011
Yamaha wr125x no spark,checked continuity on wires from ignition to ecu,changed coil and plug,engine light flashes when turning over.fault code flashes 19..anyone help.tried ecu on my nephews bike and
Did you read up on what that fault code means? I'm stumped personally. You didn't mention checking the plug wires though, but given how thorough you're being I'm guessing you already replaced them.
Oct 26, 2014 | 2010 Yamaha WR 125X
2010 x1200x will not start after battery replacement
Just leaving it on a plain trickle charger could overcharge and damage the battery but it sounds more like you cannot disarm the bike. Have you changed the fob battery. Need a minimum of 2.9 volts. Panasonic or other make 2032 battery
Apr 16, 2014 | Harley Davidson XL 1200 C Sportster Custom...
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
2000 Land Rover Discovery 2 hard to start during this winter season
Aside from building a garage or installing an engine block heater I have used this trick in the past on my 98 RR HSE. It may work for you if the starting issue is simply temperature related. Placing a shop-light or shielded work light underneath your block at night will produce just enough heat in many cases to overcome the slow starting problem.
Other possibilities may be under powered/weak battery. The rovers are known for high cranking amp demand and a weak or mismatched battery could certainly cause this problem. On the outside chance that it may be fuel delivery related you might try priming your fuel injection prior to cranking. Do this by turning key to position 2 (or last position before crank) wait til all the bells and whistles stop usually about 3-5 seconds, and repeat a couple times. If this is helpful, the bad news is it may be indicative of mechanical issues on the horizon.
****SAFETY NOTE***** PAY ATTENTION TO LIGHT PLACEMENT MAKING SURE NOT TO PUT IT IN PATH OF OIL LEAKS.
Hope this helps.
Dec 11, 2013 | 2000 Land Rover Discovery
Waverunner fx high output jetski how to unlock without remote
ask the dealer as i have no idea and i would imagine that its like a lot of modern cars its a dealer only job to make more work for them with fancy electronic controls thats using encrypted software
Dec 24, 2011 | Yamaha Boating
I just finished replacing the head gasket on my car. Everything was put back together. New oxygen sensors, oil, spark plugs. Everything is in the right spot cause when i check the code nothing reads on it....
Hello it is not easy to use a computer with a 4 year old constantly trying to get your attention.Anyhow i said disconnect your battery wait 5 minutes to reboot the computer i have gone through your situation a dozen times if it doesn't start it should trip your check engine light and you will be able to scan and retrieve keep me posted.John
Jan 02, 2011 | 1998 Plymouth Neon
YAMAHA FX 1100 HO 2006 ROUGH IDLE WAVERUNNER
I have a Yamaha fx 1100 that starts real slowly the battery is fully charged but the bike sounds like its not got alot of power going to the starter can anyone help solve this also battery terminals are clean and not corroded
Jul 28, 2009 | Yamaha 12V Air Pump
Speed tops out at 20 mpg
new yamahas are bad for fouling plugs instead of cr9eb use cr8eb they are hotter and seem to work better make sure you change the battery in the remote if that doesnt work its the plugs
Jun 15, 2009 | Yamaha 12V Air Pump
Yamaha V-Star 1100 Custom stalls when downshifting
sounds more like a fuel problem to me. is it cold there did you use stabilizer in the gas? try some berrymans B12 in the gas it cleans everything up internally. it worked for me
Mar 18, 2009 | 2001 Yamaha V Star 1100 Classic
Boating Logo
171 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
