Question about Dynex 400-Watt ATX CPU Power Supply
Hi ive changed the mother board on my acer x3200 and i get on the screen disk boot faliure, insert system disk and press enter can anybody tell me what and where to get system disk thanks
  • 393 Answers
System Disk means you need to have the OS Disk.
Like XP/Vista/Windows .
Install the OS and your PC runs.
Thanks for using FixYa.
Posted on May 28, 2011
  • fullvsht Sep 07, 2014
    If its the same model MB and hardware. In the Bios, set the hardrive as 1 in boot order. If this doesnt work, use recovery disc or OS disc and run "repair", it will write a new boot sector without destroying all of youe data.
Acer Aspire X3200 - VIRUS - Won't boot or re-install
it seems like the HDD is not getting recognised , try this might help you get into BIOS setup by tapping delete key or f2 when system turns on , load the defaults settings for bios then try loading OS , if you are getting the same error message that means hdd has gone bad or the cable to the hdd is loose
Jun 29, 2010 | Acer Aspire X3200 PC Desktop
HI THERE, I AM TRYING TO INSTALL A FRESH COPY OF WINDOWS ONTO A ANOTHER COMPUTER, I AM USING THE CD'S I ALWAYS USE SO THEY ARE BOOTABLE DISKS, I KEEP GETTING MESSAGE BACK "DISK BOOT FAILURE, INSERT SYSTEM...
First you need to make sure that the CD drive is selected as the first boot device.
You can set that by going into BIOS setup by pressing Del/F2 during system startup OR during startup press F12 and select CD drive from the boot device selection menu.
Press Enter.
See if the system is able to start from the disc.
Thanks
Feb 20, 2010 | Computers & Internet
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER... i have a mother board K7S741MG-6L, bios version 426wp225, i have this problem BIOS CHECKSUM ERROR , KEYBOARD ERROR or NO KEYBOARD PRESENT (which is...
your hard disk is disconnecetedor loose . pls check the hard disk power cable & IDE or SATA cable. Then check BIOS hard disk detected or not if hard disk is not detected your hard disk is faulty.
Dec 11, 2009 | Foxconn WinFast K7S741MG Motherboard for...
Acer aspire x3200 error reading "disk boot failure, insert system disk and press enter"
Check to make sure you don't have anything in your floppy drive. (3.5 drive or 5.25 if really old system).
If you can boot from bootable CD then probably your Hard Drive is not working and all other periferals are OK. If it is making clicking noises then the drive arm or the head is most likely shot and you need a new hard drive.
The one chance you do have is if your Hard Drive just needs to be made bootable again. Load up the XP cd as if you where to reinstall XP but instead goto the recovery console, type "fixmbr" at the command prompt once you have entered the XP logon, its very simple once you get there very well laid out.
Hope this helps. Best Regards,
Nov 09, 2009 | Acer Aspire X3200 PC Desktop
Disk boot faliure please insert disk and press enter
Sounds like your hard drive has failed and became corrupted or the boot sequence is causing this on the motherboard. I reccommend entering CMOS setup if you can and changing the boot sequence to putting the hard drive first and if that doesn't work insert a recovery disk in during the disk boot failure...please insert disk and press enter screen. Jus make sure to press enter after inserting the disk if that is done...and if that fails I suggest replacing your hard drive with a similar one of equal value and qualities.
Jun 05, 2009 | Intel Motherboard
No harddrive detected, verifying dmi pool data, disk boot failure
Help on making a bootable XP install CD for including storage device drivers (such as SATA drivers that's not included in older XP CDs): http://rapidshare.com/files/211421782/nLite_Instructions_XP.pdf
Follow my brief instructions to make an updated XP CD.
May 15, 2009 | Acer Veriton 7500G PC Desktop
Disk boot failure prompt
hi, SInce u do not have a HDD u will need to boot up from cdrom, for that in the BIOS 2nd options,change the boot up sequence first to cdrom , second to any other disk.. let me know
Dec 17, 2007 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Boot from CD
hi...i had a problem that my friend bios password and he forget now...now system is got crashed..i want install new os..but for that i have enter to bios settings...anybody tell wat's the default password ...mine is acer travelmate 5720.....i need a password now...pls anybody help..
Jun 21, 2007 | Acer Aspire 5610-4648 Notebook
Disk boot failure
After making 100% sure you have no diskette or CD in any drives the conclusion may well be that the disk is ruined. You ay try to boot from a diskette or CD and see if you can access the disk then. (see www.ultimatebootcd.com for instructions to make a boot CD) "The ultimate boot CD" has a few tools that might help you out. Since you can't boot you must make it on a different computer, though. You may also try to insert the disk in a diffe rent computer to see if it can be booted there. Also make sure all cables are properly connected.
Apr 03, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
Open Questions:
See all Dynex 400-Watt ATX CPU Power Supply Questions
Dynex 400-Watt ATX CPU Power Supply Logo
292 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
