Question about Cell Phones
How do i remove the outer cover on ablackberry mobile phone
  • 159 Answers
Blackberry Take-Apart guides can be found on www.ifixit.com
Please remember to rate my solution to show yourappreciation.
Amardeep
For more tips visit my blog at http://thegeektweet.wordpress.com
Posted on May 28, 2011
How do i remove the back cover to the android 6.0 smart cell phone
if the makers of mobile phone dont wants let you to open the back cover of your mobile phone then maybe you can remove it after voiding the warranty of mobile phone and if your phone have a normal back case for your mobile then you can easily open your mobile's back cover.remember dont try anything because it may remove warranty from your mobile phone.
Jan 14, 2017 | Android Cell Phones
Tip
How to repair your Mobile when it dropped in water?
<p><span>If you worry as your mobile phone drop in water. It may happened by rain or else. However, there is no need to panic. You can save your mobile by repairing it.</span><br /> <p><span> </span><br /> <p><span>. Quickly open all cover part as possible such as the cover, SIM card, memory card battery, etc</span><br /> <p><span> </span><br /> <p><span>.Take a piece of dry cloth or tissue paper for removing the water. If you sure that dry it completely, or some inside part out of your reach.</span><br /> <p><span> </span><br /> <p><span>. You can use a hairdryer and begin to drying the mobile by put it in the place where battery is located, and keep it too close to the mobile it may harm the electrical mechanism of the mobile phone. </span><br /> <p><span> </span><br /> <p><span>. Keep the mobile phone in sun light or in warm place for twenty to thirty minutes.</span><br /> <p><span> </span><br /> <p><span>. You may take off the covers and battery from the mobile phone. Keep the mobile in a dry or warm place to remove the water from the mobile phone. </span><br /> <p><span> </span><br />
on Dec 24, 2010 | Cell Phones
How do i open the back of the android 6 smart cell phone
If the makers of mobile phone dont wants let you to open the back cover of your mobile phone then maybe you can remove it after voiding the warranty of mobile phone and if your phone have a normal back case for your mobile then you can easily open your mobile's back cover.remember dont try anything because it may remove warranty from your mobile phone.
Where is turn signal flasher on 2001 olds aurora
Hazard and Turn Signal Flasher Replacement
Remove the left knee bolster. Refer to Knee Bolster Replacement in Instrument Panel, Gages and Console.
Remove the left IP endcap. Refer to Instrument Panel Outer Trim Cover Replacement
Gently pry outward on the rear edge of the IP outer trim cover until the retainers securing the outer trim cover to the IP retainer disengage from the retainer. Slide the IP outer trim cover rearward until the tabs on the front edge of the outer trim cover disengage from the IP retainer.
Remove the knee bolster compartment by pulling past the holding tab (1) and lifting up.
Unsnap the knee bolster by pulling down and rearward to remove from the vehicle
Remove the hazard and turn signal flasher module (1) from the I/P carrier. Disconnect the electrical connector.
Feb 12, 2015 | 2001 Oldsmobile Aurora
My 8 button does not work
Try removing the outer front body cover and then the keypad. check if the rubber layer below the keypad is well placed according to the keys. Or try replacing the outer body of the phone. or show it to the officials.
Jul 19, 2012 | Samsung Rugby SGH-a837 Cell Phone
Need to get the outer case off the phone because something is broken inside the sliding mechanism that allows the phone to slide open.
Before You Remove the cover (removing the cover will void the warranty) contact your wireless carrier and see if there a recall/known issue with the device, if there is the can replace it at no cost to you
Sep 21, 2010 | Samsung Gravity SGH-T459 Cell Phone
Have ablackberry 9630 dual sim china cannot
"not allowed to dial" problem
--> SOLVED :dance2:
Hello everybody, after playing arround for a while, collecting a lot of other information from the net, I got the problem solved with my phone:
01. Make sure two SIMs are online with good coverage, WLAN switched off.
02. Press the "call"-button and type in *#9646633#
03. The phone shows "Engineer mode" with a menu of 10 different items.
04. Go to No. 10 "RF test tool", using the up/down button at the left side of the mobile.
05. Choose "GSM"
06. A message shows up "Wifi....blabla", just confirm with OK
07. Choose "Power Scan"
08. Select your local GSM frequency (in my case DSC 1800 for Germany) and press OK.
09. The mobile will freeze now, because its adjusting itself. Leave it like this for about 2-3 minutes and wait !!!
10. Connect your mobile via USB cable to a PC, DO NOT CONFIRM any connection mode at your mobile, just and ONLY connect the cable!!!
11. Press the Menu button (second from the left, the one with the seven small dots on it) until you are at the main menu with the 12 icons on the display.
12. Go to "Settings" --> "Network Setup" --> "SIM1 network setup"
13. Go to "Preferred mode" and choose "GSM preferred" or "GSM only"
14. The mobile will switch to your selection, but the message that it will stays on display. Do not press anything else, just wait for about 10 - 15 seconds.
15. Disconnect the USB cable from the phone, it will show you that it has switched to your selection.
16. Get back to main menu, switch off and restart the mobile --> DONE. :smoke:
I hope my "weekend job" is helping a lot of other people to get rid of this annoying problem. Please bomb your supplier with emails, so maybe we do get a general solution to this problem. Next I will check why I do not get the "Opera Mini 3" working, maybe an update is necessary first.
Nov 17, 2009 | Cell Phones
Outer screen not working
it maybe that the ribbon that connects the outer screen to the motherboard on your phone has either been damaged or has detatched my advise would be to take it back to the shop you bought it from if its still covered by the 12month guarantee or take it to a mobile phone repair shop to be fixed.
Oct 30, 2009 | Sony Ericsson W380i Cellular Phone
LG GB220 Mobile Phone Manual Wanted
I want to put this phone on the my music but how am a
going to hear music
Sep 12, 2009 | Cell Phones
How do you turn on a t-mobile dash smartphone
It's a small round button on the back/side of the phone.
If holding the phone w screen facing you, the power button is on the top left, outer edge of the phone. Just hold the button down till you see the screen light up.
If holding the phone in your left hand with the screen facing you (without your thumb covering the screen), the power switch should likely be under your left thumb as you naturally hold the phone.
Aug 06, 2009 | T-Mobile Dash Smartphone
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
