Question about Kenwood KDC-MP342U Car CD Player
I am installing my cd player and i got an installation kit there is an orange wire but on my cd player there isnt an orange wire there is a blue with white stripe what do i hook the orange wire to....
    President:
  • 676 Answers
The orange wire is usually for a dimmer. MOst stereos will not have this connection.
Posted on May 30, 2011
How to wire aftermarket cd player to ba falcon
Get the facia kit, Acc+ and Gnd are tapped off the cigarette lighter Batt+ is found in the BLUE plug behind the interior fuse box. Speakers FL, RL, RR are found behind the glove box and the FR speaker in the drivers kick panel. There are also other precautions to take when installing it to avoid frying the ICC computer which controls all the interior. When attaching speaker wires ensure you connect the correct side behind the glove box connect the left side of the cut and in the drivers kick panel connect the right side of the cut. Speaker wire colours are Grey FR, Orange FL, Pink RR & Blue RL. All speaker wires are twisted together. Influential Customs
Aug 02, 2010 | Alpine CDM-9821 CD Player
I'm installing a pioneer deh- 2750mp cd player into a '92 Ford Laser, and was wondering how the wire colours match up?
Hello! Ford wiring
Power
Constant +12volts Green/Yellow
Switched +12volts Yellow/Black
Ground Red
Power antenna Blue
Illumination Blue/Red
Speakers
Front Right + White/Green
Front Right - Green/Orange
Front Left + Orange/Green
Front Left - Light Blue
Rear Right + Pink/Blue
Rear Right - Green/Orange
Rear Left + Pink/Green
Rear Left - Pink/Blue
Guru..............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Jan 22, 2010 | Pioneer DEH-2700 CD Player
Trying to install pioneer cd player in street rod.
You need:
a 12v + source from the battery (yellow wire)
a 12v + switched with the key (red wire)
a Ground (black wire)
then you need your four speakers hooked up, i'm unsure of the color codes on them but they are usually pairs i.e. green and green with black stripe for one speaker white with black stripe for another etc.
other wires such as illumination (orange) and power antenna (blue) are optional
the illumination (orange) you would connect to 12v + from a headlight switch and it would cause the unit to dim when you turned your headlights on
The power antenna (blue) is used, as the name implies to control a power antenna if you have one, or more commonly as the signal to turn an audio amp on (on the remote connection)
Hope this helps
Feb 15, 2009 | Pioneer DEH-1600 CD Player
Installing CD player
here is the wiring schematic.
Constant 12V+ Orange Switched 12V+ Yellow Ground Black Illumination Gray Dimmer Brown Antenna Right Window Trim Front Speakers 6 1/2" Doors Left Front (+) Tan Left Front (-) Gray Right Front (+) Light Green Right Front (-) Dark Green Rear Speakers 4" x 6" Side Pillar Left Rear (+) Brown Left Rear (-) Yellow Right Rear (+) Dark Blue Right Rear (-) Light Blue
And you will need a Wire harness... Metra #GMRC-LAN-01
And a mounting Kit Metra #99-3305
And antenna adapter Metra #40-cr10
This is for the basic radio... if you have upgrade NAV/Onstar/Premium sound.... there are different wiring harnesses available.
Let me know if you need more help.
Jan 08, 2009 | 2004 Chevrolet Silverado 2500HD
Radio wiring color codes
u need the colors of the radio or the car wires.... here are the car wires and the radio are below that. I suggest however gettiing a wiring kit..They are around 8 dollars and well worth the money. It makes is so easy to connect a radio.
RADIO 12V|orange + at radio
RADIO GROUND Black
RADIO SWITCH yellow
POWER ANTENNA dk. green at radio LF SPEAKER tan - gray at radio or LF speaker
RF SPEAKER lt. grn - dk. grn at radio or RF speaker LR SPEAKER brown - yellow at radio or LR speaker
RR SPEAKER dk. blu - lt. blu at radio or RR speaker
Radio wiring
constant power yellow
switched power red
power antenna/amp turn on blue
illumination is orange
all speakers the one with the black stripe is the negative connection.
right rear is purple
left rear is green
left front is white
right front is grey
hope that helps ya...
Aug 30, 2008 | 1999 Oldsmobile Alero
Sony cdx gt710
the blue with silver wire goes with the oranges which is illumination and dimmer the blue by itself nothing on it is the antenna that should have been matched up with the other plain blue antenna wire runnning from your dash
Jan 17, 2008 | Sony CDX-GT710 CD Player
Wiring Diagram Pioneer DEH 45x4
Well first you will have to get the fit kit for your car to prevent the radio from being stolen, and make it fit right. you can get this part at Best Buy, Circut City, or even sometimes at walmart. also you will need to get the proper wiring harness. all you have to do is go to an audio place and ask them for the proper parts for your car and they will get them for you. After you have everything that they say you need all of the wires match up colors. extra wires you will have is the remote wire witch is blue w/white stripe. and an orange one (illumines) witch if isnt on the wiring harness for your car its fine. all the ill. wire does is dim the radio when you dim your other componets in your car.
Jan 16, 2008 | Alpine CDE-9846 CD/MP3 Car Stereo
Wiring Problems
You didn't cut the plastic connectors off the factory wiring, did you? One is gray and one black.... if not, just get to a stereo shop and buy a wiring kit for your car and all colors will match. They're about $10. If you DID..... well..... we have a LOT of work to do....
Sep 11, 2007 | Car Audio & Video
Kenwood KDC-MP342U Car CD Player Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
