Question about Microwave Ovens
I'm trying to change the kitchen faucet and the shut off valves under the sink will not turn, I've tried to spray them with WD40 but they still won't turn. I live in a Condo so I cannot shut off the main water valve
    President:
  • 2,992 Answers
If you can't work the shutoffs on the water lines under the sink, your only choice is to contact your condo maintenance people. They need to have some way to shut the water off to your unit when they make repairs. They can tell you if there are some more valves in another area that you can access, or they may have a maintenance closet somewhere and can turn the water off for you so you can make the repair.
Sometimes you can turn a sticky valve by using a large set of channel-lock pliers or similar type on the knob so you can get leverage. They look like this if you're not familiar with the type:
If it's been a while since the valves have been used, they often don't want to move without help. Once free, they may work fine, but sometimes it's a good idea to replace the shutoff valves as part of the new faucet installation. They're not expensive and you'll know they will work if you need to shut them off in the future. Get "ball-valve stops" which make a positive shutoff. Stops that use a rubber washer can sometimes let water trickle through (or more than trickle!) when shut off. Depending on the kind of valves currently installed and the type of pipes supplying your water, you might want the condo maintenance people to do the replacement. But if 1/2-inch copper pipe is what you have and there's a couple of inches between where the pipe comes through the cabinet back or bottom and the current valves, you can just cut them off with a tubing cutter. Then you can replace them with valves that just slide over the pipe and are fastened by tightening down a compression fitting (tightening a nut, in other words).
You should also plan to use new supply lines from the shutoffs to the faucet. Again, they're cheap and the old ones can sometimes leak when you try reconnecting them. Corrosion and mineral build-up from hard water can lead to poor sealing. The current ones may also be clogged with minerals, and new ones will give your new faucet full flow.
Once you've got that problem of turning off the water supply solved, it's usually not too difficult to change the faucet. Make sure you have a basin wrench on hand; on many faucets it's impossible to reach the supply connections with any other kind. The box from the new faucet may tell you if can get away without one.
Good luck with the project, and thanks for using Fixya!
Posted on May 28, 2011
I obtained a Grohe replacement faucet head (kitchen) - part number 46298IE). The box contains (besides the faucet head) two small round cylinders (white); one has a green end; the other is white with a...
Thanks for the info about the lifetime warranty, who knew? The two parts mentioned are flow control valves that get inserted at the base of the sprayhead, not the in the hose. The green one says "water care" which will restrict flow more than the white one. It's an either or scenario, not both. There is a VERY faint arrow that points up toward the top of the nozzle. Push it all the way up and reconnect the hose tightly. That's it. My replacement didn't come with a wrench, did that come with the original faucet?
One more thing, if you bought a house that has this and don't qualify for the lifetime warranty, don't get stuck paying $100-$150 for this part if you just need to replace the aerator. The gray head that the water comes out twists out with a wrench revealing the aerator. The part number is 13929 or sometimes referred as 1392900, $10-15, if you can find it.
Sep 19, 2011 | Microwave Ovens
Just put in a new moen kitchen faucet, why does it have hardly any water pressue?
You might have a clogged aerator screen. Remove the aerator from the faucet and see if the flow is normal. You can rinse the aerator off if it's clogged. It's also possible the stops (shutoff valves) aren't open all the way. Sometimes, if they're old, they don't turn on fully again after you shut them off to put in the new faucet. If you still have low pressure after removing the aerator, you may need to replace the valves.
I don't know if the instructions mentioned it, but it's good practice to remove the aerator and run a faucet to flush the water line after installing it. There's usually a lot of debris that comes through at first. That's usually why you'll have low pressure in a new faucet.
Jul 14, 2011 | Microwave Ovens
I have a 7560c moen faucet that is loose at base of sink. how do I tighten it Thank You
The faucet is secured by a nut from underneath, and it's hard to reach because of the sink basin. You need a special tool called a basin wrench to get up to the nut and tighten it. This picture shows one in use:
The faucet you have has only one threaded piece and nut, but it's the same principle.You can find basin wrenches at the big-box home improvement places and most hardware stores, or you may be able to borrow one from someone who does plumbing repairs. They aren't expensive if you decide to buy one.
Jul 08, 2011 | Microwave Ovens
I have a Price Pfister faucet model F-534-70CC. It won't swivel,what do I do????
If this was a new install, back off the retaining nut a half turn. Most people have a habit of overtightening.
If it has been installed for quite some time, check to make sure that the sprayer hose is not wrapped around something or wegged somehow (under the sink).
I have a brita faucet filter. And the selector knob is getting harder to turn. If it gets any worse I will need to use a wrench. I wanted to try to lube up the movement if I can open up the casing. How...
I have a Brita faucet filter (model FF-100) that lately has become harder and harder to turn. I toyed with the idea of forcing the unit apart but, instead opted to lube the mechanism directly from the top, where the unit attaches to the faucet.
To this mean, you will have to 1) Detach the unit from the faucet. 2) Remove the filter. 3) Thoroughly wash the unit, inside and out, turning the knob to flush any debris that may be present. 4) Pour some drops of vegetable oil inside the mounting opening, coating the valve stem within. (Oil may pass thru the unfiltered water outlet, so choose an appropriate working space). 5) Turn the water handle (knob) to lube the valve repeatedly, until it loosens. 5.b) Optionally, you could let the oil sit for some time inside the base. 6) Rinse the unit and reinstall it on faucet (without the filter). 7) Turn knob to unfiltered position, and flush with warm/hot water. 8) Do likewise with knob set to filtered, but open faucet only slightly, to avoid over-spraying. 9) Remove base unit from faucet and repeat steps 3-9, as needed. 10) Reinstall unit with filter, as instructed by manual.
Water valves may seize due to mineral deposits. While you may be tempted to use detergents or solvents, be reminded that unless thoroughly rinsed, chemicals may corrode plastics, degrade your filter, or even wind up in your drinking water, so caveat.
Apr 04, 2011 | Microwave Ovens
My Grohe Ashford faucet is loose from kitchen sink. For the price - the things seems cheap to me - under the sink some traingular piece of plastic holds it in - but no apparent screw to tighten? What am I...
Sorry, I got your solution and was about to post and at the same moment supply went off. I don't use a ups. sorry for my fault. I will not let your money flush out, Indeed I will fix your sink. I'm barely on my bike battery because no supply is here kindly give me another few hours because we are facing a torando out here. I will make sure that you will get your output more than your investment.
Apr 02, 2011 | Microwave Ovens
How do I get to the cartridge to see if it is blocked in some way. I have reduced flow. This is on my kitchen faucet. American Standard Jasmine Kitchen faucet
You have to turn off the water and disassemble the valve from the top side. Check your screens at the discharge point, particles block there, also.
Mar 05, 2011 | Microwave Ovens
I purchased the Danco 80701 "Repair Kit for Delta, Aquasource, and Glacier Bay Faucets with #70 Ball" so that I can repair a leak in my Delta kitchen faucet. The instructions on the package are...
Sounds like the old style center-control delta type faucet, rubber washers describe older type but still good. The rubber seats have holes in middle, supply water to the cylinder which diverts water to the spout, and has a seal over top of ball allowing stem for handle.
Think they are talking about flex-hose type faucet accessory getting clogged, Maybe: lift the flex-hose faucet housing off the center-control faucet body? Water to it runs directly from center-control faucet and if broken seat gets in narrow line could inhibit spray.
Kitchen faucet spout too has an O-ring under where it connects to the faucet body. Unscrew large nut where meets the faucet body unit (slip-joint pliers), once free of threads, spout should pull straight up, easy or slight tug. I use bent paper clip to remove old one trying to save it in one piece so as to get exact size (that's important) to replace, push on one side then other.
Jan 13, 2011 | Microwave Ovens
Just installed a kitchen faucet Moen CA87316SRS and there's hardly any water pressure when I open tap. Is there an adjustment I can make somewhere?
no adjustment make sure your water shut off valves are fully open and the hoses or pipes are not kinked.
Dec 26, 2010 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
