Question about Samsung TX-R2779H 27" TV
Samsung TX-R2779H 27" TV. Suddenly there is no
3 Suggested Answers
  • 35 Answers
SOURCE: Samsung DynaFlat TX-P2775H 27
Do you get any indication of power to the unit? Mine didn't.. the light next to the power button didn't come on. Turned out it was just a fuse inside the unit. So, take it in for repair and hopefully its a simple fix.
Posted on Dec 13, 2007
taran_2005
  • 10515 Answers
SOURCE: My Samsung TV model TX-R2435
This is a failure on theT-conn board, if under warranty , it is advisable to contact manufacturer.
This is a very simple approach.
(Please click on high lighted words)
Would like for you to take your meter and place it on DC voltage the positive end on every connector that says a voltage and the negative wire to the panel this is the best ground. Turn on and see if the unit tries to climb, If you don't find one that's trying to climb suspect it, the 5VDC line if it isn't exact un hook the LVDS cable and see if it goes to 5vdc. Another method is to locate a short circuit, place meter on ohms or beep test follow same procedure no voltage should be shorted to ground. And this is the problem,
Make sure to see if DVD plays well in the input that you use for cable TV, if it does your problem is your signal, if you use cable/box unplug for 60 sec. then Re Plug it. And if picture is bad on the DVD, you will need a main board, some of the logic processing is corrupted, contact manufacturer or list below for best price. And to make sure nothing is just loose.
Ok I would like for you to open unit and in the middle of the panel is the T-CONN board, it has the LVDS cable going to it and the main board. First try to wiggle the LVDS cable to make sure no loose connections while set is on. Next disconnect LVDS from T-CONN board make sure to not let the cable touch any metal turn set on and see if screen lights up and with a clear screen. If not ok some models won't let you check this way. But if it does the panel is not faulty it is ok, LVDS or main board or T-CONN issue. So let's hope it's the CABLE, LVDS is loose. If you isolate inside the unit you may find your problem much quicker.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 20, 2011
Samsung TX-P3075WH blinking red light
Hello
Check its LOT [Line Output Transformer]. Replace it along with Line Output Transistor.
Apr 07, 2012 | Samsung TX-P3075WH 30" TV
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Jun 15, 2011 | Samsung TXP2036 20" TV
My samsung slim fit tv has a horizontal line which
hum bar. possibly related to power supply filtering. sometimes reversing the power plug will help. check cable connections for tight fit.
Sep 20, 2009 | Samsung SlimFit TX-S3082WH 30" TV
Samsung tx-p2734 TV Issues: Wavy lines on SIDE of tube...
For the buzzing noise try tipping tv jently forward and jently placing back.
May 07, 2009 | Samsung TXP2734 27" TV
Program Code
Here is every code for Samsung, including stand-aloneDVD (738, 651, 652, 667, 668, 691, 740, 741) and VCR (738, 515, 517, 534, 579, 591, 675, 755), in additition to DVD/VCR (738, 667, 691).
Jan 28, 2008 | Samsung DVD-VR357
If it's not yet a year old it should have some warranty - take it to the shop.. It's probably the HOT (Horizontal Output Transistor) which have been a problem child in this series all the way back to the TXP2745... But don't even crack the case on this one if it's that new - labor might not be covered but parts might. In any event replacing the HOT is not a difficult or expensive job.
Bill
Nov 15, 2007 | Samsung DynaFlat TX-P2775H 27" TV
High pitched squeal from TV
Get a small wood/plastic stick and touch the different coils/transformers to see which one is the cause. Replace part or if the part doesn't run hot, use a small amount of hot melt to quiet. Don't completely encapsulate in glue, don't want to create any hazards.
Oct 29, 2007 | Samsung TX-R2779H 27" TV
Samsung TX-R2779H 27" TV Logo
76 people viewed this question
Jerry Greenberg
Jerry Greenberg
