Question about Dell Optiplex GX280 (99301) Motherboard
Desconfigure bios gx280 dell y ahora solo sale f1 y f2 pero se queda en f2.como volver al original
5 Suggested Answers
SOURCE: GX280 - is it the motherboard?
I had the same problem and now it is resolved.
See: http://www.fixya.com/ThreadView.aspx?prdid=349309&thid=1316656
Posted on Mar 17, 2009
nblady
  • 206 Answers
SOURCE: Quitar Password de Bios de Pc Dell Optiplex GX100,
Hope you can read this. if not, GOOGLE...TRANSLATE.
Removing the PSWD jumper is the correct method of clearing the BIOS password. Removing the battery resets the CMOS.
Remove the power from your computer. Remove the battery. Remove the PSWD jumper. Wait!!!!
Keep power off the computer for at least 30 minutes, overnight is better.
Replace the battery. Plug the computer in. Do Not Reconnect the PSWD jumper.
Now reinstall your operating system and drivers. When finished, restart your system. If everything works and you want to redo the BIOS password, shut the computer down. Unplug the power. Remove the battery. WAIT.
Replace the PSWD jumper. Replace the battery. Plug in the power. Restart the computer, hitting "F2" as it starts....to open the BIOS setup page. Reset your password here. Esc to continue, Yes to save.
Good luck
Posted on Feb 24, 2010
  • 60 Answers
SOURCE: Dell GX110, como remover en password del BIOS
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Posted on Jun 08, 2010
claudio_enrr
SOURCE: debo resetear la bios de mi dell inspiron 1525 y no se como
yo puedo ayudarte si me das el service tag que aparese cuando arranca la computadora....
ejemplo: this computer system, #00000000-00000 , is protected by a password
Posted on Jul 16, 2012
Mi honda accord me pide un codigo para desbloquear el radio como lo soluciono?
buenas tardes el estereo de mi accord 2005 se bloqueo y en el U sale 1222 y L 7575 pero solo trae del 1 al 6 como meto ese codigo
Feb 23, 2011 | 2001 Honda Accord
MI PORTATIL SONY VAIO PCG FX-120 NO ENCIENDE.\r\nTENIA UN PROBLEMA EN EL CONECTOR DE CORRIENTE, LUEGO DE SOLDAR FUNCIONO UN TIEMPO Y SE REINICIO. PERO NO CARGA WINDOWS. LO APAGUE TENIENDO SOSTENIDO EL...
How old is the battery? Sounds like one of the NIMH cells went dead or the battery management circuit in the battery pack is bad. There are YouTube videos available for laptop battery problems.
Jan 26, 2011 | Sony VAIO FX120 Notebook
Como puedo cambiarle la carcaza ami motorokr z6 yo misma? es q se le rompieron unas partes xq se m callo al piso, y ay q compre una carcaza nueva me gustaria saber si m pueden explicar como la puedo...
loba , tenes que conseguirte un destornillador especial, lo desatornillas de atras de la pantalla( la q sube). UNa vez que sacaste los tornillos, levantas la carcaza y la deslizas un poquito hacia abajo PERO NO LA RETIRES DEL TODO!!! porque la botonera esta unida al telefono. Con un destornillador plano desenchufa la botonera del telefono ( con cuidado) una vez que esta desenchufada ahi la podes retirar. Yo estoy haciendo lo mismo pero tuve q comprar la carcaza, los botones y el lente todo por separado , si la tenes completa solo tenes que enchufar la botonera al telefono , si no asegurate de tener todas las partes (el lente si lo sacas no se puede volver a poner) Espero que te sea de ayuda, a mi me resulto facil pero el problema es que ahora se me rompio la pantalla=( pero ya me fije como cambarla. Saludos.
Jun 12, 2010 | Motorola Mobility MOTOROKR Z6 Cell Phone
Falla nokia 5530 al responder o hacer llamadas
buen dia a mi me pasa igual y me dijeron una mala noticia. tiene un corto. me ddijeron q lo tienen q soldar y queda commo nuevo eso si, me cobran 500 pesos mex. pero ojo hay algunos sitios q te dicen q se la juegan que puede darse el caso q quede brickeado osea q se quede como labrillo o pisapapeles.sniff no tengo cash para arreglar el mio. waaaaa. eso se debe a q falla ese modelo de la nada. eso me explicaron.
Mar 04, 2010 | Nokia 5530 XpressMusic Smartphone
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Como le quito el password al bios
para sacar la password de la bios de la maquina solo tienes que abrir la maquina, al lado de la pila en la placa madre hay un jumper(un plastiquito que sirve de conexion)lo tenés que cambiar al 2-3, esta gralmente en el 1-2, osea lo sacas, lo pones en el 2-3, prendes la maquina unos segundos, la apagas, vuelves a cambiar el jumper a la posicion 1-2 y listo tu bios queda borrada, ahora solo tienes que entrar a la bios y configurar tu disco duro, la hora, etc,etc , si no hubiera tal jumper, entonces directamente sacas la pila por unos segundos, la vuelves a poner y listo,
Jul 15, 2009 | Toshiba Satellite L25-S119 Notebook
NO SYSTEM ON HDD
I FIXED! LO ARREGLé!!!!... Mi objetivo era ponerlo a funcionar de cualquier forma y LO HICE!!, igual que todos, lo formateé y me comenzó a dar el error del sistema en el HDD, prácticamente tenía un DD portátil. Ahora lo tengo funcionando con el software libre “ROCKBOX” el cual tiene solamente ventajas en comparación al limitado firmware del GIGABEAT y es abrumadoramente más completo y, por ejemplo, no se necesita nada ni similar al “GIGABEAT ROOM” para cargarle música al reproductor pues es tan simple ahora como copiar y pegar (inclusive desde el WINDOWS VISTA) . Los pasos exactos no los podría decir pues fue puro ensayo y error pero es simple, deben buscar el “ROCKBOX” para GIGABEAT serie F en la misma página de ellos (totalmente gratuito) y también buscar la carpeta “GBSYSTEM” pero en Internet, desgraciadamente no puedo dar la dirección exacta pues no la guardé pero no tardé mucho y OJO, no sirve la carpeta “GBSYSTEM” que viene con el cd del reproductor, esa está vacía o con unos archivos ocultos, la que se baja de la red trae al menos dos archivos del tipo “FWIMG” (es más, estoy casi seguro que en la página de “ROCKBOX” explican como conseguirlo de forma simple), la pegan en el reproductor conectándolo como USB. Teniendo todo ello listo, van instalándolo según las indicaciones del PDF que está en la página de “ROCKBOX”… Mucha suerte!!!! Y apreciaría que me contaran si tuvieron el mismo éxito que yo a josedanielcr@gmail.com.
Oct 04, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
No tengo cd para configuracion
atras del router, al lado de la conneccion WAN, hay un hoyo donde puedes meter un sujeta papeles (paper clip). detenlo adentro por 15 segundos.
desconecta el router, pero detenlo adentro. espera 15 segundos.
ahora, connecta el router pero sigue deteniendolo por otros 15 segundos. despues dejalo.
ahora, trata de cambiar tus settings porque se regresaron a las de la factoria.
Aug 27, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
77 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
