My sony s air ipod speaker systems says "pull plug protect" and won't play the ipod. Any idea what this means and how I fix it?
  • Ryan buchowski Mar 29, 2013
    I had the same problem with the "pull plug protect" message popping up. Try pressing the Display and power button at the same time on your remote. It worked for me.
My Sony speaker says "pull plug protect" has this happend to anybody else I've unplugged them and it still says that any suggestions
Posted on Jun 14, 2014
5 Suggested Answers
SOURCE: Sony STR DE-725 going into ''protection'' mode
Audio Amplifier IC damaged
Posted on Aug 23, 2009
bobhifi
  • 635 Answers
SOURCE: I recently moved and just
If your satellite box is connected using a digital cable to the 601 receiver you won't get any sound through zone 2.Zone 2 can process only analogue sound ( inputs ).
Posted on Jul 06, 2011
  • 66 Answers
SOURCE: Hello, I have a Sony
Headphone jack is an output not input jack. Your going to need a cord to go from your headphone jack(output) of your phone to audio input on your receiver. The cord has a mini stereo plug to the phone and RCA plugs of left and right to your receiver auxiliary input. Good luck..
Posted on Jul 15, 2011
  • 3287 Answers
SOURCE: my samsung avr720 reads "protection" when turned
Protect, Protection, Protector, etc. are all indicators of a problem with the output (speakers) of the device. Most times, if you're lucky - you'll find a shorted speaker wire. Other times, it can be an expensive fix. Hopefully, you shut it off right away without cranking the volume up.
Start at the rear of the unit. Make sure no individual strand of the speaker wire has touched the binding post of an adjacent speaker. Continue along each speaker wire to the binding post or termination point on each speaker. Make sure the insulation along the entire length of all the wires haven't become crushed or damaged where they pass under rugs, around corners, etc.
If you can't find a problem, you can try disconnecting all the speakers and plugging in headphones. and power on again. If the Protect message is clear, you should be able to hear the program through the headphones and have full control over the volume. This means there is stall an issue with the speaker wire(s) from the back of the unit up to and including a speaker(s).
If it still indicates Protect, the original problem continued long enough or the volume was turned up high enough to cause an internal failure of the amplifier's output transistors and will require service t restore to working order again.
I hope this helps & good luck!
Posted on Sep 13, 2011
I have a Sony Dream Machine ICF-CS15iP Personal Docking Station. It won't play the iPod music through the speakers of the docking station.
I have the same radio and the exact same problem. I reset the radio and it wirks for a day. I go and try my iPhone the following day, and reverts back to error this device does..... Well you know the restored of resetting this thing every other day.
Sep 05, 2012 | Sony Dream Machine FMAM radio with...
Tip
How to make a connection to an iPod and Sony SS2300
<p>The SS2300 is a Sony digital surround sound system with a Blu-ray player. This gives you the ability to play high-definition video, while experiencing the content in full surround sound audio. However, the speaker system audio inputs, so you can connect external devices, including Apple iPods. Although no direct connection to iPod, you can use a single cable to the signal from the iPod surround sound system. <br /> <p><br /> <p>1. Insert the end of 3.5 mm to 3.5 mm to RCA splitter in the headphone port on top of Apple's iPod. <br /> <p><br /> <p>2. Connect the RCA cables into one of the "Audio In" ports on the back of the Sony SS2300. Multiple connections exist and you better take note of the connection you use. This makes it easier later on if the connection to the iPod. <br /> <p><br /> <p>3. Power on the Apple iPod and Sony SS2300 receiver. Press the "Input" and select the connection to the iPod is connected. <br /> <p><br /> <p>4. Press the "Play" button on the iPod and play audio content through the Sony surround sound system. <br />
on Aug 09, 2011 | Apple iPod touch
My samsung avr720 reads "protection" when turned
Sep 13, 2011 | Samsung Audio Players & Recorders
The "PROTECT" light indicator came on and now the
The protect light generally comes on when the is a short in the speaker cabling. as a test, turn on the mixer without any speakers hooked up. If it still goes into protect mode the problem is in the mixer. Take it to your local music store and have their tech look at it. if it doesn't go into protect, check the speaker cables by plugging them in one at a time. The bad one will send it into protect.
good luck
Sep 12, 2011 | Fender 150 Watt PA System
Sony Mini - Hi Fi MHC - EC55 won't play CD's. Says it is "Reading" then says "No Disk". I have used lens cleaner and reset factory settings. Any ideas
If you've already tried to clean the lens then with no improvement then its down to the laser having failed.
In some cases these are availble as a replacement part but aren't normally cost effective.
Jul 11, 2011 | Sony 720W 5-Disc Mini Hi-Fi Component...
My speakers won't play any sounds when hooked up to the computer. I hooked it up to my ipod and it played
im not sure i understand what won't means????????
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 18, 2011 | MidiLand MLi 691PA Computer Speakers
The sound has stopped working on my sonic impact I fusion and I have no idea why please help
the part were my ipod plug into Sonic Impact i-Fusion is very loose and at times will not play music- I need to put presser on the ipod to play music - how can I fix this loose ipod plug in?
Aug 24, 2010 | Sonic Impact Technologies i-P23 Portable...
Will the apple ipod nano 5th gen. work with this system. Sony AIRSA20PK S-AIR iPod Dock and Digital Wireless speakers
  • Compatibility: iPod mini; iPod nano 1G, 2G, 3G, 4G; iPod classic 4G, 5G, 5.5G, 6G; iPod touch 1G, 2G; iPhone, iPhone 3G, iPhone 3Gs
  • Wireless audio system includes iPod Dock/Transmitter and two wireless speaker systems with LCD display and alarm clock function
  • AM/FM tuner provides alternative to iPod content; multi-zone function means iPod can play in one room while radio plays in another
  • Expandable system is easy to set up, and is compatible with up to ten speakers with the compatible audio receiver
  • Connect to your home AV system with composite audio and video cables for enjoying iPod content
  • May 07, 2010 | Apple iPod nano 5th Generation
    Re: Sony 771 ... constant buzzing sound in background
    Sounds like feedback. Check your speaker connections at the speaker and the main unit.
    Jun 26, 2017 | Sony MHC-771 Shelf System
    113 people viewed this question
     Grubhead
    Grubhead
