Question about Sanyo Bag-Free SC-240 Canister Vacuum
How can i get an intruction manual for my sanyo pulse bagless upright cleaner
reddevil6
  • 1673 Answers
SOURCE: Hi, my sanyo pulse 1500 bagless vacuum has very little suction.
If the vacuum will run without the hose attached, does the suction seem ok at the opening where the hose goes into? If so, then you have a clog in the hose or down below where the dirt is first sucked up. If suction is poor at the vacuum, then check the filters, they go bad after awhile.
Posted on Feb 29, 2008
SOURCE: Bissell Bagless Vacuum cleaner
There is no release, the part is a plastic handle release lever, you can find those at www.hesco.com, the cost is approximately 2.29 each, I have replaced more than 20 of these on the commercial vacuums for my cleaning crew, the part is easily broken and easily replaced. I always have 6 or more on hand.
Turn the vacuum over, remove the bottom plate, with a flat head screw driver punch out the old part. turn the vacuum upright again after the broken part is removed. With the body laying back on a hard surface, carefully push in the new part. Unfortunately, these are plastic, too bad they cannot design a more sturdy part for this.
Posted on Jul 06, 2008
buffalonyman
  • 1865 Answers
SOURCE: No manual.
The manual is located here: http://www.hoover.com/pdfs/manuals/U5194900.pdf
Posted on Apr 24, 2009
  • 21 Answers
SOURCE: Looking for the instruction manual for the Eureka
Go to http://www.eureka.com/service/manuals/80244.pdf this is a direct link to the owners guide for your model or you can call customer service at 800-282-2886 and request a hard copy
Posted on Jul 19, 2009
SOURCE: I have the Bissell upright
Easy to do. Unplug the vac. Turn the vacuum over and look for three finger latches on the bottom behind the brushes. Unlatch these and pull the faceplate off. Then, grab one side of the brush and pull straight up (they just sit in grooves on the sides). Once the brush is up, then pull it out of the belt. Look towards the back of the vac, the belt rides on a shaft. There is room to work the belt off to the side.
Replace the belt on the shaft, onto the brush, and then fit one side of the brush in and push down the other side. Rotate the brush to center the belt (you did unplug it, right?). Put the plate back on, front first, the little tabs will go into the slots. Then push it down firmly, latching the three latches. Take the time now to completely pull everything apart and clean it, including the hose, running a coathanger through it to make sure it's clear. You're done!
Posted on Dec 21, 2009
Manual for bissel upright bagless vacumn cleaner
Not knowing what needs to be put back together I am giving
you this phone #....Bissell Consumer Services !-800-263-2535
Make sure you have the Model Number available.
Regards,
Dennis.
Aug 24, 2014 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell powerforce manual
You should be able to download manual from this site.
There seem to be quite few filters to worry about.
Good luck.
Bissell User Guide Upright Bagless Vacuum Cleaner 6594 ManualsOnline com
Aug 10, 2014 | Bissell 6594 PowerForce Bagless Upright...
I just got a used sc-a102 vacuum and I need to
Greetings from GoVacuum.com,
The Sanyo Performax model SC-A102 use the Sanyo Upright Bags Part Number PU-1 Bag. We stock most of the parts for this Sanyo if you ever need anything.
Here's some links to the products on our site that will fit your vacuum cleaner:
- Sanyo PU-1 Upright Vacuum Cleaner Bag, Generic 9pk.
- Sanyo SC-A102 Performax Vacuum Cleaner Belts, 2pk. Part SC-BL3
- Sanyo SC-A102 Performax Vacuum Cleaner Exhaust Filters Part SC-FU1
- Sanyo SC-A102 Perfoxmax Roller Brush Part 6490002487:
http://www.govacuum.com/sanyo-bagless-upright-12-inch-replacement-roller-brush-beater-bar-sanyo-part-6490002487.html
GoVacuum.com can also special order any part that you require. I hope that this helps you. The Sanyo uprights are pretty good quality, inexpensive vacuum cleaners. They use metal in all the right places, and last longer, unlike models that use just plastic.
If you found this helpful, please rate it as helpful by clicking the 4 Thumbs Up Icons in the top right hand corner of the page.
Thank you!
Chris Jones
GoVacuum.com
Mar 20, 2010 | Sanyo Permax SC-A102 Bagged Upright Vacuum
Looking for the instruction manual for the Eureka Altima 2993AV HEPA Upright Bagless Vacuum Cleaner
Jul 02, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Trying to find a manual to replace power bush belt
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
dsfgsf
Mar 15, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Pulse Bagless dust press system vacuum cleaner I need to download the instruction manual
Dear Customer
please check the following link for
Sanyo Instruction Manual Upright Bagless Vacuum Cleaner SC-150, SC-180
http://homeappliance.manualsonline.com/manuals/mfg/sanyo/sanyo_upright_bagless_vacuum_cleaner_product_list.html
please rate this,Thank u
Dec 16, 2008 | Sanyo Vacuums
Sanyo Bag-Free SC-240 Canister Vacuum Logo
67 people viewed this question
Top Sanyo Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Roy May
Are you a Sanyo Vacuum Expert? Answer questions, earn points and help others
