Question about Samsung Televison & Video
Samsung LN52A550P3FXZA LCD had clicking noise and Tv would not come on. No sound, No picture. Replaced 2 bulging capacitors. Other capacitors looked fine. I now have sound, but not picture. Very faint images in background. What's going on? What do I need to do?
  • Samsung Master
  • 19,396 Answers
Hi.
If there are very faint picture in background, then the back light system is not working. That means that problem is either inverter powering the lamps with AC, main controller board managing the inverter, or PSU providing primary DC voltage to the inverter.
In your case the PSU was defective. The damage may have concerned more components apart the capacitors (resistors, more capacitors, solder joints etc.). Testing is done tracking voltage to inverter. The first thing to test is voltage to inverter from PSU. A general procedure is described here.
This test is done reading the DC voltage from the PSU to main controller. A malfunctioning controller board may not turn on inverter. Voltage in input and high voltage on inverter must also be checked. Voltages to check are 120VDC at CN801 on IP board (inverter power board) and DC B13V,B12V,B5V Voltages at BD105L,C1261,BD101 on PSU. For safety reasons testing with power on must be done by a trained person.
To make things easier, the whole service documentation has been uploaded here.
Here parts for this TV.
Regards.
Ginko
Posted on May 28, 2011
Model LN52A550P3FXZA. Video and audio cycle on and off every 30 seconds or so. When picture switches off, the screen is filled with multi-color horizontal lines.
It is a common problem for this model, the problem is the main board. There are 2 Tantalum capacitors (C102 & C131) 47MF/10V, 1 Passive Voltage regulator KIA7805AF (IC300), 1 Step-Down Power Conveter IC MP2363DN (IC101) need to be replaced. If you do not have soldering skills, just order a new board.
May 16, 2017 | Samsung Televison & Video
My Samsung tv has sound but no picture. it is 2 yrs old. any ideas ? thx.
Hi Brenda,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 11, 2015 | Samsung Televison & Video
Samsung ln22a450 red light indicator blinking 5 times also sound like initial screen but no picture no audio after that. 10 min later the tv it shut off by it self
- Flickering screen
- Dim screen
- Slow start
May 02, 2014 | Televison & Video
Samsung LCD TV Model LN46A550P3FXZA sound is cutting in & out 1-2 second intervals
Your video and audio (sound) signals are generated on the main board. However, for those circuits to work properly, they have to have clean and accurate power from the power supply board. The power supply boards are notorious for bad capacitors. Has your power supply been recapped? Do you see any bulging tops of any of the capacitors? If you are not familiar with capacitors, just google bulging capacitors. There are plenty of pictures on the web to show you what they look like. It is possible that the main you have has a problem. I assume you order the same exact part #?
Nov 12, 2013 | Televison & Video
When TV switched on momentarilly turnson then shuts off. This repeated over and over. Must disconnct power. to shut off. No picture or sound.
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Sep 24, 2012 | Samsung LN46A650 46 in. LCD HDTV
Samsung ln40a450c1d no picture on screen when pressing the channel button it blink only with a low grey look no sound or picture thanks
Good day!!!!
Jun 05, 2012 | Samsung 460UX-2 LCD TV
Proscan 42LA45H has picture and no sound
Good day!!!!
Jun 05, 2012 | Proscan 42LA45H 42 in. LCD TV
When I turn on my Samsung LE46F86BDX LCD TV it click's for some time. After about 2 minutes the TV starts playing normal. Afterwards you can turn off the TV and back on again. The TV starts normal....
This problems very common on a LCD tv.It the tv power supply board,have bad dying capactors,these capacitors are alway bulges or puffing up on it tops.That the board,where the power a/c cord plug into it.U have all the tools,know basic electronic and can do basic soldering?Just check the power supply board,for those dying capacitors that bulges or puffing up on it tops.Replaced these dying capacitors on the tv power supply board,ur tv will power up normal again and have no more clicking sounds and will not take anymore 2 mins or more to turn it on.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 25, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Televison & Video Logo
788 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
