Question about Kenwood Audio Players & Recorders
HI, need to set up my Kenwood stereo (A 57) again however when I plug in the cables from the speakers into the main box (I dont know how it is done, just do trial and error, I have 8 holes where you can connect the cables from the speakers) I cannot figure out a combination which makes both speakers work. I seem to be able to plug in one cable in any hole, but the second one then must be in the upper right one. This is true for both speakers, so effectively I can only use one, because I only have one upper right hole to plug it into. Do you know what I mean? Could you please help me? Thank you! Regards, Nick
SOURCE: sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Posted on Oct 09, 2007
  • 1512 Answers
SOURCE: Wharfedale 9.5 Diamond Front Speaker
you have a poor connection somewhere in your signal path. This sort f problem could be anywhere from inside the speaker box to the output stages of the amp. speaker protection relay in the amp, or even a noisy vol control or dry solder joints in the output stages of the amp. eliminate anything external to the amp by swapping right for left and test, spray the speaker protection relay in the amp with 2-26 or burnish the contacts with a piece of white business card cut to fit into the contacts. You will see deposits on the card that you have cleaned from the contacts. Carefully inspect the soldering about the output stages(heatsink area) and re-solder any poor or cracked solder joints. Good luck... these are the most common problems. I can go further in if the problem remains after you have done this. Good luck
Posted on Jan 30, 2008
  • 4338 Answers
SOURCE: logitech x-140 speakers connection
Did you try the black plug? Also, look at the right hand side of the tray and see if you have a Speaker icon. And if you do have a speaker icon, make sure that your sound is not muted.
Posted on Oct 25, 2008
SOURCE: Connecting Creative t6060 to my philips 5.1 dvd player
You can certainly go ahead and connected yours 5.1 creative speaker with no issues just logon to below link to get the step by step instructions with images to how to connect
Enjoy the 5.1 surround experience
Posted on Nov 11, 2008
SOURCE: Prima HT 8104 home theatre
in the 3D processing turn on the Pro Logic and the for the mode as well set it to pro logic.
it simulates 5.1 surround.
this is what I did and it's decent. Other way would be to run the system through a amp/receiver that supports 5.1 surround.
Posted on Apr 27, 2009
Where can I find a manual for Kenwood Tuner kt-57?
Is it a tuner only? If so you will need a power and or just a receiver with speakers. A tuner only has no power output for things like tvs.
Mar 25, 2016 | Kenwood KT-57 Stereo Synthesizer AM/FM...
How do I connect my technics SB-G920 speaker to my Kenwood VR-60RS Audio-Video Control Center
I believe both devices, the speakers and the Audio-Video control Center is all but the same as many other past devices sold before the one you have at home. The only difference is their connection fittings at the back of either the speaker (boxes) and the Kenwood. I have such system, a 7 channel Quad-stereo system connected to a Pioneer Radio receiver/Amplifier and the connection of speaker wires are critically important to be connected correctly or else... Booom! gone is either the speakers or the Amplifier. Whatever your machine is, we always call it an amplifier, even though you can connect the video cables from a DVD player, through the Amplifier RCA sockets and out to a TV or Projector.
Now, you must have really heavy duty cables specially designed for high definition or HDMI video playback quality (without picture loss). Once you've determined the right distance between the DVD and the Kenwood and the TV or projector, you purchase these special cables. There are RCA video cables that have a better shielding and are usually all three as one cable with three RCA connectors on each end. Yellow is Video and is usually a thicker cable, followed by red (right), white (left) connectors. Take your time and pay attention on the correct connection to avoid trouble later. If you want a better, clearer video, you can use the S-Video cable. This cable has fragile plugs and when connecting, if you force them without aligning the right pins, you'll damage the plug.
Now, connecting the speaker. For a loss free sound, good quality speaker cables are essential. Otherwise cheaper cables are OK but it does seem that the sound quality is sacrificed on high peak (louder sound) as a fraction of energy and heat is generated through thinner cables than thicker ones, like when vacuuming a carpet, you can feel the cable getting a degree of warmth because the motor is labouring to suck and blow out cleaned air.
Start with the speaker boxes. Speaker cables usually have one wire colored and the other plain and they are as an 8 shape (o-o). The one that has a colored line marked on the cable is the positive wire. Before you start, split the splice the ends at least half an inch and twist the strands. If you have a soldering iron, solder these strands to form a solid wire, easier to insert it in the connecting clamps. Now, insert the one with the colored line marked on the cable into the red connector and the one without the line in the black connector. repeat with other speaker boxes. Place the speaker boxes in their locations before you cut the other ends of these cables so you don't end up having them too long or too short. I have already said why. Too long and too thin, the cables lose energy and releases heat. Too short and you have to restart again by purchasing new cables. Joining a short cable because of a mistake is not recommended. So, you either measure the before you purchase the cables or buy excess and cut to size later.
Now, the connection to your Kenwood amplifier is to be done really carefully as there are quite an number of connectors at the rear of the device and you have to study carefully which is what and where is which. It takes a little patience and a pen and paper in have to work out what is where. Bear this in mind that usually for large output speaker boxes the Amplifier had bigger connector to fit thicker wires (cables) and rear or mid speakers (pairs) have smaller connectors for cables that are slightly smaller in thickness.
For the largest speakers you connect the left (F) cable into the left clip-ons (or snap-on, or rotating screw type connectors where you just undo the screw, insert the wire into the hole and the screw tight), paying attention to the polarities (watch the colored line marked on the cable. Then do the same with the right speaker box cable (wires), insert them where it says right or just 'R'. The same goes with other speaker boxes. Paying attention their polarities.
Once done, test it before you put the Kenwood back in the cabinet or platform. if everything works as it should, then put the device (Kenwood) back in its place and give it a final check. Cheers
Feb 03, 2015 | Kenwood Audio Players & Recorders
What is the wirer color diagram 1999 toyota avalon car stereo radio wiring diagram radioconstant12v+wire??
Hi Slick, From my experience working on Toyota motor vehicles, they don't use colour coding. You'll need to identify the cables with a voltmeter and an used AA or AAA battery (like those from the TV remote). First find the constant power (which keeps the memory function of the set powered. Then by a process of elimination turn on the ignition and check each of the other cables until you find the ignition switched power. Check to make sure it' switched by turning the ignition on and off. To identify the speaker cables there should be a number of white cables with black tracer lines. Take any pair (removing a little insulation from the end to leave the metal cable open) and hold one cable onto the negative end of the battery and swipe the other cable end over the positive. As you do that the cable speaker will make a popping sound, where by you can identify which speaker is attached to what set of cables. Regards John
Oct 24, 2012 | Toyota Cars & Trucks
Hi there. I have an old KAC-9020 amp, but it is in very good condition and I wouldn't like to see it go to waste. However, the input for the amp is an 8 pin DIN cable. I could custom wire an adapter if I...
I found the owner's manual on the Kenwood website. Please visit the link below:
You'll notice that the plug in the diagram is plugged to receiver/tuner/car stereo. Apparently it's a common plug/setup for the Kenwood stereos that have this type of output plug. You would just need to find any Kenwood car stereo that has this output to get the wiring of the plug if you wish to use this amp with a different car stereo. (Or just get a Kenwood car stereo that has this type of output). Good Luck.
Oct 04, 2010 | Car Audio & Video
I do not know how to wire nenwood kdc-422 to a 94 buick century?
You should have a wire harness pigtail that comes with your kenwood.
you can also purchase a harness adapter plug/pigtail at most audio auto stereo shops to fit your car make and model.
Be sure to save the packaging because the plastic bag has the color/codes for the harness. This harness is designed to plug right into the factory plug inside the dash just like the stock radios do.
All you need to do is splice the kenwood cables to the adapter plug pigtail you purchase for your car.
match up each wire as described here:
1994 Buick Century Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 22, 2010 | Kenwood KDC-422 CD Player
Bose 151 main with amp
Does your tv have stereo outputs? if yes all you have to do is run RCA red..white jacks into tv outtput then run the other ends into the amps tape or aux or cd input and your done! If you dont have outputs on tour tv you will have to but an RF converter box (about 20.00 at wal-mart) and hook that into the tv and the cables will run out of that to the stereo!
Jan 14, 2009 | Bose 901 VI Main / Stereo Speaker
Kenwood Receiver connected to my pc
using the Y adapter method (i am guessing you are using just a single stereo mini-jack cable with a mini-jack to RCA adapter) you are only sending a standard Stereo signal to the receiver. Setting 5.1 in windows is just simulating (if using Stereo) or actually mixing 5.1 if you are using analog 5.1 (3 stereo mini-jack cables going to 3 mini-jack to RCA adapters using a 6 channel DVD input). if you have a surround sound audio card i suggest using the Analog 6 channel input by using 3 stereo cables each with their only adapter.
or, if you have a Digital output (Coaxial or TOSlink [optical]) try using that.
good luck.
Nov 12, 2008 | Kenwood VR-406 Receiver
I have a Kenwood kdc mp828. I disconnected my battery cable and now can not remember my security code. I need to reset the unit so I can again listen to my stereo.
I read a blog on your site about Kenwood stereo's. I used that information to unlock my stereo security code. Albiet, I did have to figure out a bit of the code needed myself. I am again able to listen to music on my stereo.
Jun 26, 2008 | Kenwood Car Audio & Video
HEY COWBOY, I ALSO JUST PURCHASED A SET OF THESE TODAY FROM A D.I. STORE IN SALT LAKE (JUST LIKE GOODWILL BUT MANY TIMES BETTER) I TOO NEEDED THE CABLES AND FOUND THEM ON EBAY. HERE IS THE ITEM DESCRIPTION MAKE SURE TO ENTER IT INTO THE SEARCH BOX EXACTLY LIKE I AM GIVING IT AND IT WILL TAKE YOU DIRECTLY TOO THE ITEM.HERE IT IS....Sony #177553111 SAVA SA-VA 1 27 29 55 57 59 SPKR CABLE IF YOU HAVE ANY PROBLEM PLEASE EMAIL ME. i also bought the cable it was i believe 24.95 and 7.95 shipping i think. i used to own this set and they are a very nice tower speaker and sound very good i was fortunate to get mine today for 15.00 minus the center and rears. later jim
Feb 02, 2008 | Sony SA-VA1 Rear Speaker
Top Kenwood Audio Players & Recorders Experts
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
