Question about HP Pavilion m7434n (ER901AA) PC Desktop
My computer blinks amber and blue when i plug it into the wall. the fans turn for a second then everything just stops. any idea what it might be??
  • 100 Answers
There might be a problem with your motherboard or the processor.
Posted on May 28, 2011
Power light flashing amber
Follow the steps given below. (Please be careful when handling computer electrical components like batteries and AC Adapters)
  • Remove the battery and hold down the power button for few seconds (to drain all remaining power)
  • Power up the computer without the battery with the A/C adapter plugged in.
  • Wait for few seconds and plug the battery back in
After a few tries the computer should start charging normally. The amber battery stops blinking and turn green when fully charged.
Feb 13, 2015 | Acer Aspire One Kav10 Netbook
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
I have an Acer AL1912 that when you plug in the ac, the green power light will blink for about a minute and a half then go solid. The backlight will come on and you can see a faint ghost of vertical lines...
If it is still in warranty call the manufacturer.
if not give more info elah4@zoominternet.net. May be somthing simple like a cable
shutdown computer unplug then disconnect the video cable on the computer from the monitor, plug monitor back in and turn it on, there should be a display that says no video source within a few seconds, if unit is working properly. shutdown and connect video again and then reboot computer. sometimes it just takes a compleat power disconect to reset things,
Jan 30, 2010 | Acer AL1912B 19" LCD Monitor
I got the steady Amber light of Death in my dell.
As a hardware repair technician at a local university, I have seen the amber power light problem on quite a few Dell computers. If the machine is in warranty, Dell insists the power supply be the first thing replaced, even if it tests ok. If that does not do it, then they send me a new motherboard. Of the dozens of machines that have had this problem, only 1 of them needed a new motherboard. The power supply alone resolved the problem on all the rest. I have found this to be true on out-of-warranty systems as well.
Jun 28, 2009 | Dell Dimension 8400 PC Desktop
Powers On if I plug it in, and power supply fan runs...
Think of blinking amber as the initial state of the LED. As long as the system is receiving power from a power source and can pass that power through the system board to the LED on the Control Panel it should, at least, blink amber. As a result, a blinking amber Power Button LED is a reliable indicator that the system is receiving power from a power source. This, in turn, tells us that the source and power cord are likely to be functional. The Blinking Amber LED also tells us that the power supply to system board connection is good as well as the connections between the system board, I/O Panel and Control Panel. Depending on the components installed and the condition of those components, the LED may progress past blinking amber and move to solid amber. If the LED does not progress past blinking amber it indicates that the system is not able to properly distribute power to the system components. This is discussed in the next section of the interaction.
It does not indicate that the power supply is bad. It simply indicates that, for whatever reason, one of the power supply 'rails' is not operating within its specified range or, simply, that there is a short somewhere in the system.
The LED state could be the result of a misconfigured or incorrectly installed system component. A bad drive, for example, may be shorting out one of the rails. Incorrectly installed memory can cause a blinking amber front panel power button LED.
Feb 05, 2009 | Dell PowerEdge 1800 Server
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Amber Light and fan running
1st thing, disconnect everything but keyboard mouse and monitor, see if anything changes.
If the issue persists, ensure that all power and card connections for the motherboard are tight and secure. If you've added RAM or other parts, remove them. Reseat the RAM in the motherboard that came from Dell.
If none of those ideas have any effect on the issue, replace the motherboard.
Jul 01, 2008 | Dell Dimension C521 PC Desktop
BIOSTAR K8M800 Micro AM2 wont boot
It's suppose to do that. These motherboards are new generation. After everything is ready to go, you plug the power cord to the wall and pc. The computer power supply fan spins for about 3 seconds or so and maybe a few lights blink. This is normal. Its kind of a self diagnostic telling itself (I'm ok, you can power me on now). Did I answer your guestion? If not, let me know.
Jun 30, 2007 | Biostar K8M800 Micro AM2 Motherboard
HP Pavilion m7434n (ER901AA) PC Desktop Logo
32 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
