Question about Cycling
I have a relatively cheap 21speed bicycle, a genesis made by kent intl. a knocking/grinding noise has just started in my crank housing, unfortunately the instructions are in portuguese my question is should I 1. just take it to a shop. or 2. try and take the thing apart (which i might not be able to put back together properly) to check the bearings, please respond at your earliets convince. Thank You!
  • 4,350 Answers
Yeah, take it to a shop. Often you need a special wrench to tighten correctly... Not a big repair.
Posted on May 28, 2011
Where can I get service info on Kent Bicycles,and parts
Kent are cheap bikes usually sold in large department stores. There isn't anything special about them and any local bike shop will be able to service them for you. They use all the common size tires/tubes, pedals, bearings etc. and replacement parts are relatively cheap from your local specialty bike shop retailer or can be found online at Amazon or Ebay.
Oct 20, 2014 | Kent Eriksen Cycling
Need a owners manual for kent alameda tricycle
Look on Kents web page. There is a customer service number on the frame down by the crank
Sep 16, 2014 | Cycling
Need manual for Genesis Onyx 29" Cruiser Bicycle
I need Manual complete the " 29 men genesis onex"
Aug 09, 2013 | Genesis Onyx 29" Cruiser Bicycle
Noise my 03 xterra makes when I crank it up. One guy said exhaust manifold and another said knock sensor. Just need a second opinion.
Many times a bad starter motor makes noise like clanking, clicking or grinding when crank the engine. Replace the starter. Sometimes, if the starter motor is grinding the gears on the flywheel, the engine will have a metallic grating sound when you first crank it. This type of starter noise is normally indicative of a starter motor that is worn and about to fail. If you do need to replace your starter this site looks like it has cheap prices, free shipping and great reviews http://www.buyautoparts.com/starter.htm
Jul 05, 2013 | Cars & Trucks
My 1999 Silverado has engine knocking when starting. Using Mobil 1 and good filter. Any suggestions?
Most engine knocks/noise is caused by worn rod/main bearings or piston noise, you are sure this is not a valve follower tap? in any event unless it gets worse I would not be concerned, most of the knock noises are piston related and will not cause early failure of the engine, if it is deep hard knock u have a failed crank or rod bearing, this must be repaired as it will only get worse.
Sep 30, 2010 | 1999 Chevrolet Silverado 1500
No Rear Quick Release
Some less expensive bikes do not come with quick release skewers. You just unscrew the bolts like you would any other using a wrench or socket. The will probably be really tight so you may need to bear down or use a cheater pipe. Unfortunately, these bolt on wheels tend to be solid axles and cannot take a quick release skewer. You would need to replace the wheel.
May 20, 2010 | Schwinn Miramar Women's 21Speed Bicycle
How would I install an upper suspension arm to
nissan primera in the US is called an Infiniti G20. the grinding or knocking if its coming from the front, is gonna be the tension rod bushings are warn out. get new tension rods for real cheap. thats all i can help with, suspension is my thing, motor is not.
Jul 16, 2009 | 1995 Nissan 200SX
Loud grinding noise when washer is draining
something in the impeller housing. not usually serviceable. not sure if that unit has two pumps. you could look underneath the tub and try to determine that, and where the noise is coming from.
i am confident the issue relates to a pump unit.
good luck
mark
Oct 22, 2007 | KitchenAid KUDR01TJ Dishwasher
Cycling Logo
44 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
