Question about Frigidaire FGHD2433KF Builtin Dishwasher
Our Frigidaire dishwasher (FGHD2433KF) leaks intermittantly. Maybe 1 out of every 8 loads, when it leaks it leaks big.. Any thing cvome to mind?
2 Suggested Answers
dynastygrani
  • 21 Answers
SOURCE: frigidaire fghd2433kf dishwasher. less than
Hello bidness_67 please check inside of the sink cabinet look for a switch on the back wall. If there is one flip it. Many new building electrical codes require a switchto turn off power to the dishwasher. Sometimes when putting items in the cabinet the switch is hit unknowingly. If there is no switch check outlets (the GFCI ones)and press the reset then check the dishwasher.if not those two items check breaker box for a tripped breaker.
Posted on Oct 18, 2011
Door Gasket keeps coming loose on Frigidaire FGHD2433KF. How Do I keep it in? Glue?
Good Morning friend, thanks for your post!
From the information you have provided the door gasket on your Frigidaire dishwasher continues to come loose. Typically, when your gasket starts coming out you may need to have a replacement gasket installed. I would recommend operating the gasket you need from your manufacturer and replacing it. I hope this information is helpful. -Matt
Feb 28, 2015 | Frigidaire FGHD2433KF Builtin Dishwasher
Frigidaire FGHD2433KF starts when closing the door without pushing the on button
Hi Charles - From what you have described it sounds like there is a miscommunication with the control board/panel and you will need to contact a professional to diagnose it for repairs.
Sep 24, 2012 | Frigidaire FGHD2433KF Builtin Dishwasher
I have the dishwasher model number FGHD2433KF, I have noticed the last few times I try to run the short cycle that after a few minutes it jumps to 99+. What could be causing this and how do I fix it?
Sounds like the control board is having a communication error. Reset the unit at the circuit breaker and retry. If it happens again contact the manufacturer for a repair.
Jul 29, 2012 | Frigidaire FGHD2433KF Builtin Dishwasher
My frigidaire dishwasher works intermittently. It'll completely stop mid -cycle, as if the power was shut off - then eventually indicate a power failure on the display. Then it wil work fine for a c
Hello Tom Weiss, There are a couple of things to check.
1. Check connection at the dishwasher. It is possible that the wire nuts came lose. Re-tighten and wrap with electrical tape to secure.
2. Check for a small leak from sink or faucet this has also been the culpret before.
Dec 05, 2011 | Frigidaire Dishwashers
Water will not drain. I did have a new garbage disposer installed a couple of days ago, but don't know enough about dishwashers to even see where it connects to the disposer.
Hi Ruthp53, I am JK. I see that you have installed a new garbage disposal and now are having problems with your dishwasher (model FGHD2433KF) draining. I would recommend checking for blockage at garbage disposal and the drain. Also, new garbage disposables normally have a plug that will need to be taken out.
Hope this helps!
Sep 09, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Frigidaire fghd2433kf dishwasher. less than a year old. flashed PF. the power hasnt been off. now whole unit is dead. no lights or movement.
Aug 15, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Dishwasher leaks below the door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Apr 20, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
My dishwasher is making a load hum what its in a wash cycle. The model is a Frigidaire FGHD2433KM. What would cause this problem? David
Chances are it is a defective motor. The motor in mine went out three months after installaton and again nine months later, just outside of the warranty period. Frigidaire offered to replace it, covering parts and labor, as a "good will gesture" but said they would not replace it a third time unless I purchased the extended warranty. In my opinion the part was either designed poorly or manufactured poorly, or both.
Nov 08, 2010 | Frigidaire FGHD2433KF Builtin Dishwasher
Frigidaire FGHD2433KF Builtin Dishwasher Logo
60 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
