Question about Konica Minolta Dimage Scan Dual IV Film Scanner
I have tried to follow the procedure outlined in the following link: http://www.frisno.com/2009/11/10/konica-minolta-dimage-scan-dual-iv-works-in-vista/ to install a driver for my dimage scan dual IV on my windows 7 64-bit laptop. I completed step 1 and installed the original driver files on my laptop, but when I attach the scanner I get an error that "the scanner connection could not be confirmed". How do I install the driver for this device? Richard
  • Konica Minolta Master
  • 6,674 Answers
4 Suggested Answers
SOURCE: konica minolta dimage scan dual IV
Are you doing index scans or prescans? Sometimes the software gets funky - try doing at index scan if you are doing prescans, and vice versa. Also try CHTL+SHIFT+I which is a recalibration (don't that will do anything but it can't hurt). The best thing might be to just remove Dimage totally (you may have to delete the main folder if you've created any Jobs) and then reload the software. Before you do that, update your virus software, do a system check, and maybe some maintenace like a Defrag - then reboot, remove the software, reboot again and reload software.
Posted on Dec 03, 2008
  • 35 Answers
SOURCE: error 4 ... Konica Minolta Dimage Scan Dual IV
Use VueScan. A free trial is available so you can test it before you commit to buying it. Available for Windows and Mac.
http://www.hamrick.com
Posted on Aug 16, 2009
SOURCE: Konica Minolta DiMAGE Scan Dual IV Film Scanner driver in an IMac
DS Dual 4 even works with SnowLeopard on a CoreDuo MBP. But it doesn not support Autofocus when used under USB2. You have to use a USB1.1 Port, if you want to use autofocus function. Every time the software crashes, because you tried e.g. to use autofocus with USB2, you will have to close the application, go to the folder User/Library/Preferences/DS Dual4/... and look whether there is a file name something like "MFSlib...." and pull it to the trash bin. You can start the application again. PS.: Your keyboard USB port is a USB 1.1 port!
Posted on Jan 06, 2010
What causes it to shut off?
I found nothing... iHeater 1500 Advanced...
(MY fault: strongly suggest the TELEPHONE)
Try
officialiheater.com
http://officialiheater.com/
or follow contact instructions (below)
Please be sure to read and follow all of the service
procedures outlined in this owner's manual. If you have
any questions concerning your iHeater, contact the
iHeater Customer Service Department at 1-800-469-0456
1-800-469-0456
iHeater, LLC.
5789 Park Plaza Court, Indianapolis, IN 46220
www.officialiheater.com
Carnac the Magnificent
Jan 02, 2016 | IHeater 1500 Advanced Infrared Heater...
I need to calibrate the speed of my ProForm 680 LT.
Remove the front motor cover. Inside is a copy of the tech sheet. The procedure is outlined there.
These machines do not do an electronic calibration, it is a mechanical one. You must adjust the motor controller for max speed by following the procedure outlined.
If the speed readings are incorrect, you may be set for Kilometers rather than Miles. It's easy to determine. 3MPH=4.8KM...
Follow the procedure in your owners manual to change from metric to miles..
Dec 12, 2010 | Proform 680 LT Treadmill
The monitor is very dark and I can hardly make it out
Please refer to the following article which outlines a detailed procedure to diagnose & fix your problem:
http://www.fixya.com/support/r6430776-troubleshooting_laptop_power_failures
Oct 30, 2010 | Dell Computers & Internet
The remote control for my liftmaster 1280LM garage door opener does not work. I have changed the battery, made sure the lock feature is off and have tried reprogramming the remote. It does not appear to...
The receiver is going out and will not receive signal from the remotes. try to reset it by unplugging the motor from the power sorce for about 30 seconds and then plug back in. this should reset the logic board. If this doesn't work you will need to replace the board
Sep 26, 2010 | liftmaster Chamberlain Garage Door Opener...
My ink cartriges are stuck and I cannot get them out
Have you followed the proper procedure for removing/replacing the ink cartridges as outlined in your printer manual? (Opening the printer correctly will move the cartridges to a specific area where they can be removed/replaced).
If not, follow the instructions from HP support:
Replacing Ink Cartridges
Dec 20, 2009 | HP Officejet 5610 All-In-One InkJet...
How do i replace the car battery on a saturn sl1 1993
The battery is under the hood and for a full breakdown on the procedure please view this FixYa Tip.
The Saturn battery is held in with a tie down and you will need a 3/8 socket to release it from the car once you have followed the procedure as outlined.
Thanks for using FixYa.
Nov 10, 2009 | 1994 Saturn Sl
Always saying remove cartridge
please take a look in the following link "hp office jet 6110 users' manual" page 42-46.
it is too long for me to post the information here.
make sure to follow the procedures outlined in the manual.
Feb 23, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Kenmore dishwasher lock light
you tried holding hte "control lock " buttonn for 3-5 secs and it still didnt unlock??? if thats the case your problably gonna need to replace te console/ touchpad
Nov 30, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Konica Minolta Dimage Scan Dual IV Film Scanner Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
