Question about Amana AEW3530DDS Electric Single Oven
Neither the broiler or baking element come on. The fan works and so does the oven light
  • Amana Master
  • 1,902 Answers
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on May 28, 2011
Neither oven or broiler work. Upper elements work well. Why is the bake light flashing / blinking?
if it is not coming on then you may have the same problem again with the ignitor.
May 04, 2014 | Ovens
Lancer 92 ecr location
check elements with a multi meter for continuity
Apr 08, 2014 | Dacor Ovens
All the lights and buttons work/sound on control panel. Broiler oven works but baking element not working. Replaced baking element with new, but still doesn't work. Convection fan works, light works,...
Manufacture and model would be nice ohm out the bake element might be open some are in the oven cavity others are hidden below the lower oven plate and have to check from the rear by removing back cover in the bake mode the broil element element cycles on/off thats why you have some heat.
Feb 10, 2014 | Ovens
Broiler element doesn't work
Reseating the Element The broiler is heated using an electric element which should be clipped in to the top of the broiler enclosure. If this has come loose then it might not be making contact with the necessary terminals. Try to reseat the terminal but before doing so you must ensure that the electricity is turned off.
Testing the Element The element is what heats up and cooks the food in the broiler. Over time the heat can damage the broiler element. These elements are supported by stand-offs and if the element burns out or becomes damaged then this can be a common reason why the broiler isn't working.
The easiest way to test whether this is working is to turn the broiler on and look at the element. If it is working correctly then the element should be glowing red.
Another slightly more complicated test for the broiler element is to remove the element from the oven and disconnect it. Then use a multimeter to check the continuity of the element. Set the multi-meter to measure resistance and then put it either side of the element. The normal measurement should be between 20 and 40 ohms. If the element is infinitely resistant then this means it's broken and will need to be replaced.
Testing Oven Controls Another reason why the broiler will fail to work is because of problems with the oven controls. A thermostat is used to set the temperature of the broiler, and the oven selector controls are used to control the setting of the broiler.
Turn the oven controls on to see whether the broiler is working properly. If not the controls can be removed and tested using a multimeter. Check the outputs to ensure that the controls are working correctly.
These can also be replaced if required by fitting a replacement part designed specifically for your oven.
Read More: Troubleshooting an Oven Broiler Doesn Work
Feb 09, 2014 | Thermador SEC302 Electric Double Oven
Ran self clean now oven will not heat up
Turn the breaker off for 5 minutes then turn it back on see if this helps if not let me know.
Sep 27, 2011 | Whirlpool RBS305PRS Stainless Steel Oven
When I turn my oven on bake the broiler element runs and eventuly the f2 codes comes on.
your oven uses fboth the broiler element and the oven element during baking. Since you know the broiler element works, you most likely will have to replace the oven element.
Oct 01, 2009 | Ovens
Kenmore electrical oven
Trying to better define the problem....
Do you have any cuts, holes or "shorting" or tin-foil/aluminum around your bottom bake heat-element? If so, you may need to replace the baking Heat Element. (Ensure you do not use aluminum foil around your heat element to prevent your oven from getting dirty)
To replace your baking heat element, with power off; remove 2 screws securing the bake element. Slightly tug and pull towards you for about 3 inches or so and disconnect the connecting wires at each end. Then completely remove the heat element and install new in reverse manner. Whats' you're model number?
Jan 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven will not heat - Thermador SMW272 Electric Oven
since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
Dec 12, 2008 | Thermador SMW272 Electric Double Oven
Broiler element not working
It's either the switch that supplys power to the broiler element or it's the element itself (probably the element itself). I'd go after that first as it's not that expensive.
It's not a thermostat because if it was, the bake element wouldn't work either. The broiler element is not supposed to come on except when in the broil mode or cleaning mode.
Mar 13, 2008 | Amana AOES3030 Electric Single Oven
Amana AEW3530DDS Electric Single Oven Logo
54 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Ismael Rodriguez...
Are you an Amana Oven Expert? Answer questions, earn points and help others
