Console says replace belt unit even though I have minimal copies on the printer. Dell 3115 color laser
  • 1 more comment
  • marc279 May 28, 2011
    Can you be specific on what tod do to reset to factory settings. Your original instructions were received garbled see below.
    Try and reset the power to the printer and re-install check the toner cartridge. If this doesn't help then please try and reset the printer to default factory settings. Y?? ??n reset ???r Dell printer by using 'Reset Dell Printer' icon. Y?? ??n g?t t? th?? icon in folder 'UAN'--> 'Logic Utilities' -->Reset Dell Printer. Hope this helps... Please post back if you need more information.
    Daniel
    I do not see a reset dell printer icon, and as long as there is an error message I cannot access the menu. I must do the reset using functions available on the printer itself.
    When the printer is Ready (Copy, Scan, Fax appears in the LCD), press the 'down' button until Setup is indicated, then press the tick mark/check mark button.
    When the printer boots up it immediately display belt unit error and locks out all console buttons. Is there any other way to achieve factory settings.
    I have connected via USB - I cannot find a folder called UAN. Where is it?
  • 4,323 Answers
Hi
Daniel
Posted on May 28, 2011
  • 1 more comment
  • Daniel Scott
    Daniel Scott May 28, 2011
    Apologies. Original post--
    Try and reset the power to the printer and re-install check the toner cartridge. If this doesn't help then please try and reset the printer to default factory settings. You can reset your Dell printer by using 'Reset Dell Printer' icon. You can get to the icon in folder 'UAN'--> 'Logic Utilities' -->Reset Dell Printer.
    However, the above method only works when the machine is connected to the computer via USB cable. If the above method doesn't work then you would need to reset the NV-RAM of your printer. When the printer is Ready (Copy, Scan, Fax appears in the
    mark button.
    Press the 'down' button until Admin Menu appears, then
    Press the 'down' button until Wired Network is displayed, then
    Press the 'down' button until Initialize NVM appears, then
    When the 'Are you sure?' message appears on the operator
    panel with the default indicated as No, press the left or right button to
    indicate yes, then press 'square' button. The display momentarily indicates
    Wired Network, Initialize NVM, Initializing... followed by Restart Printer to
    apply setting.
    When the display returns to Initialize NVM, turn the
    printer off, wait a few moments, and then turn the printer on.
    Hope this helps...please post back
    for further assistance.
    Daniel
  • Daniel Scott
    Did you try this--- Try and reset the power to the printer and re-install check the toner cartridge. If this doesn't help then please try and reset the printer to default factory settings. You can reset your Dell printer by using 'Reset Dell Printer' icon. You can get to the icon in folder 'UAN'--> 'Logic Utilities' -->Reset Dell Printer.
  • Daniel Scott
    Click Start--> Search for Files or Folders--> search for the folder UAN. Double-click the UAN folder--> System Utilities folder-->Double-click the Reset Dell Printer icon.
    If unable to find UAN folder this way then the printer drivers are not installed and you would need to first install printer drivers on Computer before proceeding.
Removal of paper stuck in a dell 3115 fuser?
It's best to remove the fuser to get access to it. This video will show you how to remove it, and which levers to move to release tension in the pinch roller to clear the jam http://www.youtube.com/watch?v=UjyggtF8d1k After you remove the jam make sure to do a close inspection on the internal roller (use a flashlight). You're looking for any scratches or "dents" in the colored roller (sometimes a deep red/brown color sometimes blue) if there are scratches you are probably going to have to replace the fuser. The imperfections on the fuser roller will show up on your printed pages. If you do need a new fuser you can find them for $160, or the entire rebuild maintenance kit for $375 http://www.fastprinters.com/productdetails.asp?PRODUCT_ID=DELL-UG190
Dec 19, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
Dell 3115 manual feed doesn't work
If this printer is a few years old on the load paper tray there is 2 grey rubber rings they get a flat spot on them. replace and no paper problem till the next time they wear out
May 25, 2012 | Dell 3100cn Laser Printer
Dell 3110 laserjet printer, belt unit close to life
This message is displayed when the pagecount of the transfer belt is 80,000 (ish)+.
The rated life of the transfer belt in the Dell 3110/3115 is 100,000 pages.
After that pagecount the transfer belt 'expires' and no further printing is possible until the transfer belt is replaced.
Feb 03, 2011 | Dell 3110cn Laser Printer
Donde encuentro manuales de esta impresora DELL 5319n
Workgroup Laser Printers Contents: Dell Laser Printer 5210n/5310n Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Dell Support ...Dell 3115cn Color Laser Multifunction Printer - Dell 3130cn Color Laser Printer - Dell 5210n Mono Laser Printer - Dell 5310n Mono Laser Printer - Dell 5330dn Mono Laser Printer - Dell 7330dn Mono Laser Printer...
Documentation ...Printer 5110cn Dell Laser Printer 5210n / 5310n Dell 5350dn Laser Printer Dell 7130cdn...
Documentation Contents: Dell Laser Printer 5210n/5310n Dell™ Laser Printer 5210n/5310n Tech Sheet View Download (PDF, 116 KB) ...
Systems Management Support Information Matrix for Dell Management Console Version 1.1 ...Color Laser Printer 5110cn Laser Printer 5210n/5310n Laser Printer S2500 (n) Workgroup Color... 5330dn Dell 7330dn Dell 2145cn ...
Systems Management Supported Information: Dell Management Console Version 1.0 User's Guide ... Dell PowerVault ...Dell PowerConnect ...Dell'EMC ...Laser Printer 1815n ...Laser Printer 5210n/5310n Yes ...
Dec 13, 2010 | Dell 5310n Laser Printer
RICOH CL7200 MAGENTA AND CYAN LINES ON COPIES
It sounds like the transfer belt needs to be replaced. They get scratched up and milky looking and the sensors can't see the color reg marks good enough. It could be other things also but the transfer is a good place to start.
Apr 01, 2009 | Ricoh Aficio CL7200 Laser Printer
Horizontal Striping Problem on a Dell 5100cn
As you have just replaced the drum you may have a faulty drum unit put old one back in a test if lines go way then return drum to store and get a replacement. If they do not go the check the toners and the fuser unit.
Thanks J
Jan 21, 2008 | Dell 5100cn Laser Printer
175 people viewed this question
jasbo
jasbo
