Question about GPS
When I plug the system into either a wall socket to charge or a cigerette socket it will not work. If I take the charge out and turn it on it works only when unplugged. So I guess I need to charge the thing up and hope its a short journey!!! What a pile of rubbish Garmin is.
    President:
  • 1,514 Answers
When it's plugged into the cigarette lighter socket it should work. Sometimes the reason it won't is because the mini USB plug of the charger is not pushed fully into the satnav and it goes into mass storage mode showing a picture of a satnav connected to a computer. The plug appears to be fully pushed in but it's not. Pushing it in further usually solves the problem.
I hope this solves your problem and that you find that garmin satnavs aren't so bad after all.
Posted on May 29, 2011
Is there a way to charge my 930 T on a wall socket AC adapter
The trouble with cheap chargers ' Mobile Fun Blog
www.mobilefun.com/blog/the-trouble-with-cheap-chargers/
Jul 10, 2012 - The abbreviation for amp is A. There are also milliamps which have the abbreviation mA. ... The other way around isn't as much of a problem. If you try tocharge an iPhone (1.1A) using an iPad charger (2.1A), ... micro USB cables can't tell the difference between a wall socket (AC power) and a USB port.
How USB charging works, or how to avoid blowing up your ...
www.extremetech.com > Computing
ExtremeTechAug 26, 2015 - If you take a smartphone which came with a 900mA wall charger, and plug it ... It turns out there's a method to all this madness - but first we have to ... A regular USB 1.0 or 2.0 socket has four pins, and a USB cable has four wires. ..... Last week I couldn't find my phone charger (wall plug), so I tried using ...
What wall plug chargers can be used to charge PS3 ...
gaming.stackexchange.com/.../what-wall-plug-chargers-can-be-used-to-c...
Jun 19, 2012 - I want to charge my PS3 controllers (SIXAXIS) without having the PS3... I have noticed there are (expensive) third party PS3 controller charger ... Why can'tthe normal wall plug chargers, that are able to charge way ... The PS3 controller won't charge when connected to any usb outlet (where only ...
Amazon.com: AC Adapter Wall Charger w/6'FT Power Cable ...
www.amazon.com/Adapter-ChargerCity-Manufacture...
Amazon.com, Inc.
Rating: 5 - ‎5 reviews
ChargerCity GPS AC Wall GPS USB Power Adapter Cable Accessories for ... XXL 550 540 535 530 GO 920 930 720 730 740 630 640 TOM TOM LIVE Traffic GPS ... I don't really have any need for the Micro SD Memory Card Writer so can't ... I now cancharge my TOMTOM from a wall socket instead of leaving it in my car.
Charging your Lumia 930 ' MyUCS
Jan 03, 2016 | Computers & Internet
After connecting the charger cord and plugging it into the wall socket, is the iPhone to be turned off or turned on?
If you turn it off, it will charge faster. I've done both. This morning my charge was very low. Then I noticed the plug became out of the socket. Try it both ways,see what happens. If you are charging with it on, have you closed all your apps? Double press the on/off button on the bottom front. Any open apps will appear half size. Place your finger on the app, and slide it UP and "OFF" the unit. Turn it off, try charging. Be sure your plugs are all the way in. If you try it turned off, the unit will briefly show your current charge, then turn itself off.
Sep 22, 2014 | Apple iPhone 5c
IPod Touch 4th gen won't charge with from a wall socket
Have you tried different outlets? I have an outlet in my room that won't charge my devices all of a sudden for some odd reason.
Dec 02, 2013 | Apple Audio Players & Recorders
I had to buy a new in car charger for my navman s30,but when i plug it in to the sat nav & cigerette socket it keeps showing a computer,usb & navman picture.
  • Turn the Navman off by holding the power button in the upper left corner of the device until the screen goes blank.
  • Plug the unit into its charger using the USB port on the bottom of the unit. The battery indicator light next to the power switch should turn orange, indicating that the device is charging. Once the light has turned green the charge is complete. If the light does not turn on, verify that the car charger is plugged into a working outlet.
Jun 19, 2012 | GPS
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Motorola h500 bluetooth headset
Make sure the wall socket it's plugged into is on. Some have wall switches that must be turned on to activate the socket. Leave it plugged in over night if you are using it the first time. Plug something else into the socket (like a desk lamp) to make sure it is delivering electricity.
If it still doesn't turn on after attempting to charge with an electrical socket you know works, the product may be defective.
Apr 25, 2009 | OEM Systems Motorola Bluetooth Headset...
Cigerette Lighter won't work 2003 galant
the fuse you are looking for is accy or accessory. I hope this helps. Don't forget to rate my answer, thanks.
Feb 13, 2009 | 2003 Mitsubishi Galant
Cig lighter not working and 12 v in ford foucs ztec diesel 2009
check the fuse in the plug in
it should unshrew and put another in
try that first
Jan 31, 2009 | 2004 Ford Fusion
Power Socket not working
check your fuse if thats good take a test light or voltmeter and see if you have any power to the socket. If you don't have power you will need to remove your radio and see if the wires are connected to the socket.
Dec 29, 2008 | 1994 Toyota Tercel
GPS Logo
112 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
