Question about Poulan Pro 22" Self Propelled High Wheel Mower
Just bought a used poulan pro with a honda 5.5 22" super clean, like new the gas tank was empty, I put new gas in and it doesn't even want to try to start....any ideas?...thanks
  • andyavery May 28, 2011
    I took the screw out of the bottom of the bowl, had to remove the air filter assembly to get to the bowl....it is on there pretty tight so I didn't get it off- shouldn't it just pull off?....also, with the screw out of the bowl and the carb loose, should gas flow freely when I open the valve?....I turned the valve with the carb off and just a few drops came out of the bowl....thanks, Andy
    Hi ..Just checking to see if you received my comment a couple of hours ago after your suggestions....thanks
  • 345 Answers
Hi! I'm going to throw some possibilities out there and some may sound stupid but I want to cover all of our bases and they are arranged in order of the most likely cause of the problem and in order of the troubleshooting teps you should take.
  1. Have you attempted to prime the line/tank?
  2. The most common cause of having zero response when you attempt to start it is a bad spark plug connection to the plug. Check the boot to the plug and the terminal connector and make sure that everything is OK. The prior owner may have intentionally disconnected it for storage or may have removed the sparkplug entirely.
  3. If the connections seem OK, try replacing the sparkplug. The gap tolerance is .028 to .036.
  4. Again, since this is used, Check your battery, make sure it's actually connected and then make sure that it's actually good. Give it a charge if necessary, if it doesn't take, replace it.
  5. Your model has an option for an electric starter. If yours came with this, again check all of the connection.
  6. The last thing I could recommend would be to check the fuel line but since you didn't mention the smell of gasoline I doubt that it's damaged, however it could be gunked up. The problem with buying used even if the item is "like new" is that you never know to what extent that the previous owner used it, and whether it was just cleaned up really well to make it look like new.
If you have any more questions or can provide more information, let me know and I'll be glad to help however I can. Thanks for using FIxYa, Andy!
Posted on May 29, 2011
  • Poulan Master
  • 14,411 Answers
Check plug and make sure its the right one,replace if needed,check air filter.replace if necessary and theres a bowl under carburator,a screw is holding it on,block fuel line going to carb.,then remove screw under bowl,be careful,theres a rubber gasket on lip of bowl.Clean bowl with clean towel and push up on float to make sure float is not stuck,put bowl back on with rubber gasket,tighten screw and uncrimp gas line and start it up.
Posted on May 28, 2011
  • Thomas Perkins
    Thomas Perkins May 29, 2011
    Make sure your self propelled is not engaged will trying to start,remove cover and see while you are trying to start.Also clean your carb. bowl.
Poulan pro honda engine stalls as auto choke lever moves
Hi, when you say you cleaned the carb, did you strip it down and blow all the jets out with compressed air? If so, check that you have fuel flowing into the carb. If all this is ok check the valve clearances. Regards Phil.
Jun 24, 2012 | Poulan Garden
I have a Poulan Pro leaf blower/vac. The fuel lines cracked inside the gas tank so I pulled them out & bought new ones. Now i can't get them back in to the gas tank. I understand there are
Make sure that you have the right size lines the smaller diameter line goes into the bottom hole of the tank cut a 45 angle at the end of the line as you put the line into the tank twist and push until you get enough line to pull up through the fuel filler hole then cut the line so that the 45 is no longer and slip the fuel filter on then pull back the line until the filter rests at the bottom of the tank. Do the same with the upper line except that line will only go in 3 to 4 inches. I hope this helps you.
Feb 29, 2012 | Poulan Pro Gas BlowerVacuum ()
Poulan 18" PP4218 Pro 952051338 It has fuel
you may need to clean your sparkplug, or replace it
Aug 05, 2011 | Poulan 952051338 18Inch Chain Saw Chain 38
Does the fuel lines just stick into the holes on the gas tank?
Yes, the fuel line and return line simply feed throught the holes in the gas tank but they should go in tight enough that they won't come out by themselves and gas doesn't leak out.
Jul 06, 2011 | Poulan Pro Super Blowervacuum
Poulan pro weedeater will not start without starting fluid and wont accelerate after starting Once started the first time it is easy to restart and idles fine, just cant accelerate the motor without it...
Your carburator is clogged.
1st make sure you have FRESH gas.
Empty and clean the fuel tank
Remove and disassemble the carburator and soak it in fresh gas for about 15 minutes to disolve any gunk.
Using a can of small carburator cleaner ( available at Lowes, Home Depot etc.) blow out all the ports.
reassemble and refuel with clean fresh gas
The little carbs clog easily
May 19, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
I have a 2010 49cc Tao Tao moped. I have only had it for six months. I bought carburator and jet cleaner for it called "Sea Foam" for small engines. I put the amount the bottle told me to add to...
HI,,empty your gas tank,,and drain the carb put some new fuel in the tank and dont use additives again,,some do more harm than good (especialy in 2-strokes)
Apr 20, 2011 | Husqvarna CR 250 Motorcycles
I put oil in gas and gas in the oil can it be fixed
YES IT CAN. TAKE OFF BOTH CAPS AND TURN THE SAW OVER AND EMPTY THE TANKS. GO TO AN AUTO PARTS STORE AND BUY A GOOD DEGREASER THAT YOU CAN SPRAY IN THE TANKS AND WASH CLEAN. WAIT TILL DRY AND REFILL HTE RIGFHT WAY.
Nov 13, 2010 | Poulan Pro Chain Saw 46cc 20"
Poulan 446 Pro engine won't run
its probably not getting any gas from the tank try putting your finger on the hole on the carberator and pull your finger should be wet if not take fuel line of the carburator and thenblow then take off the gas cap and blow through the hole on the gas tank it should flow freely throgh teh line to the carburator
Nov 06, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan Pro 22" Self Propelled High Wheel Mower Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
