Question about Dryers
Ceiling fan chain broke
Hertiage hugger ceiling fan
    President:
  • 1,952 Answers
Motor: XTR-200
Blade Span:
60"
Blade Pitch:
Downrod:
3.5"
Blades: Choice of
Traditional Wicker Black, Tropical Wicker Weather Bronze or Adirondack Reclaimed Antique Blades
Light kit: Optional
Control: Included
W-81 Wet-Rated Wall Control
Posted on Aug 25, 2008
Harbor Breeze fan light keeps blinking on and off. Is problem in switch or in fan unit assembly?
That's what you get when you buy a low-end store brand fan. Also, you should never buy a hugger fan unless your ceiling is under 8 ft. Most hugger fans are worthless. They have a cheap motor and no blade pitch.
Aug 24, 2013 | Westwind Classic Hugger Polished Brass 52"...
Hunter ceiling fan pull chain for fan broke
First write down which color wire goes in which slot on switch.Turn power off! Disconnect wires from defective switch by inserting a paper clip or something a little bigger into the wire connection.Then press the spring down and release the wire to insert in new HUNTER switch. DO NOT CUT WIRES!Call 1-888-830-1326 with model # to order the correct switch.
Mar 24, 2013 | Hunter (25417) Ceiling Fan
I just replaced a 4 wire 3 speed pull chain switch on my ceiling fan and now it still wont turm on. It is making a humming sound now. I was careful to match wiring???Please help
it sounds like the new switch has a different pin out or you got it wired wrong? is the motor jamed up, will it turn by hand,,,the humming sound you here is curent running through the motor windings,, if it cant turn its going to get very hot,, it could burn the motor out,, have another look at the wiring
Nov 16, 2009 | Westwind Classic Hugger Polished Brass 52"...
Ceiling Fan Chain Broken Off
You have to kill all power to the fan and start taking it apart till you get to the switch. There's usually just a bottom plate to remove. Sometimes lights. Replace switch and reassemble. If some chain is still connected to the switch you can add chain to it and won't have to replace switch.
Oct 04, 2009 | Dryers
Model H52 hugger ceiling fan. Speed switch broke. I replaced switch but only get one speed.
If you replaced the speed switch with a dimmer control or a lighting control device it will not work properly. You specifically require a fan control switch.
Sep 16, 2009 | Encon Industries Dryers
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Ceiling fan will not turn off
There is 2way switch attached to this chain you need to replaced it.
Jun 04, 2007 | Hampton Bay 48670 Flemish Pewter Finish...
Dryers Logo
296 people viewed this question
Top Dryers Experts
