Question about Akai LCT3201AD 32 in. LCD Television
Power Shuts off after 30-45 minutes
I replaced with a power supply purchased at Best Buy Parts Search. Unfortunately, it produced the same symptom, and that is the LCD TV will shut off after power will shut off after 30 minutes or less this time around. I question the ps board as the person at the other end said the ps board that I'm getting works with other Akai models. In any case, the new ps board did not change anything.
Is it possible for the main board (or mother board) to go defective somewhere. Do you know where I can purchase the parts for the Akai LCT3285A. Appreciate your response. Thanks.
  • 2,337 Answers
I will say that the part that you bought could have been removed from another LCD and it might not be working properly due to components that become defective when they overheat.
It looks like there are not service parts or they are difficult to find.
Most power supplies I've repaired have components that failed after about 1500 hours of use.
The only way to get the LCD working is to repair the power supply to the component level instead of swapping it.
In about 95% of the time the power board is defective.
Let me know if you need further assistance.
Posted on Aug 16, 2008
6ya staff
SOURCE:
My Sharp Aquos LC-32D44U Is malfunctioning.
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 13, 2017 | Sharp AQUOS LC-32D44U 32 in. LCD TV
My samsung hl-s5686w tv shuts off after staying on for 15 minutes, replaced lamp, no help. Any sugestions?
Oct 11, 2016 | Samsung Televison & Video
Flat screen tv shuts down after 10 minutes
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Check whether the timer is set to 10 minutes or not.
Mar 23, 2015 | Televison & Video
Toshiba Cinema Series projection TV 1998 purchased. The TV powers off on its own now; could be after watching for just a few minutes or a couple of hours or more. Red power light flashing once a second. ...
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 23, 2017 | Toshiba 55H70 55" Rear Projection...
I have a Trinitron Wega 32HS510 that sometimes will not turn on. It sounds like it is going to turn on but shuts down immediately. The red light fast blinks either 6 or 7 times over and over again -...
Apr 30, 2017 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Samsung TV...Turn on tv, it operates for maybe a minute, then shuts itself off and has a consistant clicking pattern, like a relay switch. Sometimes turns itself back on
Not knowing the specific model for your Samsung TV and how old it is, I can only offer this possibility because I've encountered what sounds like the same problem. Certain models of Samsung HDTVs around 3-4 years back have a design problem with their power supplies - they put in the wrong size capacitors (aka "Caps"). After a few years, the capacitors fail, and the power supply also fails. I think it's possible to replace individual capacitors, but most likely you will have to replace the power supply. Unfortunately if it's out of warranty, it will cost several hundred dollars, especially for a home / onsite visit. There is a visible symptom - from 2-6 capacitors on the power supply board will bulge out, as shown in this pic:digizen.jpg
You might try calling Samsung customer service and tell them you are aware of problems with their power supply design, and try to get them to repair the TV for free, especially if you are just out of warranty.
Nov 04, 2010 | Samsung Televison & Video
I purchased a SANYO TV (Model: CM29FS2) two years back. Recently I experienced a fault from this TV. After warming i.e. 30-45 minutes from switching on, a sound (like the one when we turn on/off any switch...
Apr 29, 2017 | Sanyo Televison & Video
Computer wont turn on, power light in back goes out when you press power,
Hello and thank you for using Fixya's services.
You will need to replace the power supply unit in your desktop. These can go out due to dust, power surges or other faulty hardware.
Go to manufacturers website and look up replacement part. Go to ebay and run a search for power supply. You will pay 75% less than purchasing from OEM by getting from eBay.
Once you get the power supply in, unplug the computer, open the case and make sure you are grounded. Get a pen and paper and make note of where the power supply ends lead to (this will make the installation of the new power supply less complicated). Double check everything before plugging in.
Please let me know if you have any questions.
Nov 02, 2009 | HP Pavilion a400n (DQ173A#ABA) PC Desktop
TV loses picture/sound after 5 minutes then comes back. Repeat
Sep 02, 2017 | Sony KDSR50XBR1 50" Projection HDTV
Westinghouse 32 inch screen goes blank
Westinghouse LTV-32w1
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Dec 25, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Akai LCT3201AD 32 in. LCD Television Logo
78 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
KISHORE DESHPANDE
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
