Question about Microwave Ovens
Beko freezer TZS490 the red light is on - green and amber not, and it's defrosting. The black cylinder at the bottom at the back is very hot and smelling. Can you help me.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: i have a beko ab910
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Feb 20, 2011
How to defrost freezer model #4931 montgomery ward .There is a drain at the bottom , but is there a drain pan to empty? Do I take the back panel off?
There is a drain plug at the bottom center under the basket. Remove this. Snap out the base cover and you will find a hose behind it. Place the hose in a pan to collect the water. Turn off the freezer and let it thaw. Watch the pan that it does not overflow. I sometimes use hot water to help the melting process along.
Aug 06, 2011 | Microwave Ovens
I want to defrost my GE chest freezer but i do not know where the drain is
Since you did not include a model number this is my best guesses:
http://manuals.appliancesonline.com.au/kcm2100wc/kcm2100wc.pdf (Page 1 w/pic)
and
http://www.appliancesdirect.com/InstallationPdf/49-60442.pdf (page 7 no pictures)
For Complete Defrosting
Turn the temperature control to the
OFF position and unplug the freezer.
Remove all food and place it in
corrugated boxes, insulated bags,
picnic coolers, etc. Use towels and
newspapers for insulation as needed.
With the door/lid open, use pans of
hot water to speed loosening of frost.
Remove large pieces before they melt.
Chest models have a defrost water drain
at the front.
NOTE: Water may drip from the back flange of
the lid cover during defrosting. This is normal.
Ice builds up in the lid insulation when the lid is
open for adding or removing food, and melts
during the defrosting operation.
Sponge excess water from the bottom
of the freezer as it collects to prevent
overflowing.
After defrosting, clean the inside of the
freezer (see Care and Cleaning).
Replace the drain plug inside the
cabinet and the cap on the defrost
drain. Fold over and dry the gasket
on the hinge side of the lid.
Plug in the freezer. Return the
temperature control to its previous
position and return food to the freezer.
Hopefully with this information you can find the drain. If not go to www.ge.com and click on service and support to download your manual. (Model number required)
or contact them here:
800 GE CARES
(800.432.2737).
Thanks for choosing FIXYA,
Kelly
Jul 24, 2011 | General Electric Microwave Ovens
FRIDGE button is set on 3, red light flashes, air system works but it is not cool for at least 1 hour, Freezer set on 4 S and works.
Start out with the easy stuff first...make sure the lights go out when you close the door(s), make sure the doors are closing properly and the gaskets are closing fully and not torn. Check to make sure the evaporator fan in the freezer is working, this fan blows the cold air around. If the fan is not working, possible bad fan motor - check for power to the fan motor and also check the fan switches around the door openings, ( if your fridge has these switches, not all do ). A common problem cropping up in the last several years has been the air damper not opening up and allowing the cold air from the freezer to be blown into the fresh food section ( mostly on SxS refrigerators ). For many years the air damper was manually operated and now we have motorized controlled or temperature controlled or thermistor and electronic boards controlling air dampers, and if this device sticks closed the FF section will normally warm up. An example picture of "one" style and an air damper ( called a diffuser by Whirlpool ). Next would be to check the condenser tubing, a good place to start is to make sure the condenser coils are not built up with dust!! Make sure the condenser fan motor is also working properly. Check for any "clicking on and off" noises from the compressor, is the compressor running.
The most common fridge "not cooling" problem is a frost free failure. Remove the access panel in the freezer section to expose the evaporator coils. If the coils in the freezer section get plugged up with frost, this frost will block the evaporator fan motor from blowing the cold air around. The fan blade can also hit this frost and either become noisy or stop altogether. Locating the defrost timer can be tricky....they are often hidden behind the back bottom corners of the fridge at the bottom, in the last few years the timers have been located in the ceiling of the fresh food section, and some behind the cold control cover. Once you locate the defrost timer, slowly turn the screw like wheel in the middle of the defrost timer with a straight screwdriver until the fridge shuts off. You are now in defrost. If the defrost heater(s) comes on now, replace the defrost timer and defrost thermostat. If the heater(s) does not come on, you can ohm test the defrost heater for continuity or volt test for 120 volts to the heater(s). If you have no power to the defrost heater(s) you can also bypass the defrost thermostat to see if the defrost heater will come on, join the 2 wires together to bypass the defrost thermostat. If the heater now comes on, replace the defrost timer and defrost thermostat. If the heater itself is bad, defrost the fridge with a hair dryer, replace the defrost heater* and defrost thermostat. If the defrost timer seems "hot" to the touch or is noisy ( like a ticking or screeching noise )...replace it. Then make sure all the vents are clear and not being blocked by food cartons. One new safety device added to refrigerators in the last few years has been a in-line fuse added to both sides of the defrost heater. If one of these fuses let's go, you must replace the whole defrost heater, as it comes as an assembly. If the defrost heater does not work, you should check for one of these fuses being open. Check it with a volt meter or ohm meter.
New link from Appliance Repair Aid on how the wiring circuit works for a frost free fridge, the link is here.
On a frost free refrigerator, the cooling coils should be in the freezer section. On a SxS style refrigerator the coils will be behind a cover on the back wall. On a freezer on top style the coils could be behind the back wall or under the freezer floor. Removing the cover and exposing the evaporator coils could be a valuable tool. Seeing what the cooling coils looks like may help split your not cooling problem. Totally covered coils with white snow is a frost free problem. and the rest are bare is an indication of a system problem
If you find this helpful, a vote with the thumbs up would be appreciated for the free advice
Jul 13, 2011 | Microwave Ovens
Refigeration line in freezer gets so hot it glows red.
Thats your defrost element :) If you are not having any problems with your freezer staying frozen, that is normal
Mar 25, 2011 | Microwave Ovens
I am getting power and the freezer appears to be working but the fridge is not cold at all, any suggestions? Many thanks Dave McRae
Hi Dave and welcome to FixYa, I am Kelly,
Take a look in the back of the freezer compartment. Look for any signs of icing on the back access cover. Usually but not always the evaporator coils freeze up because the unit is not automatically defrosting properly or there is a problem with the evaporator fan not running fast enough / at all. Press gently with your hand of the back cover of the freezer compartment and feel for ice. Also check the front of the chassis for signs of being HOT. It is ok to be warm not hot.
Also check to see that the light goes on and off as you actuate the light switch plunger. Some units have the door switch in the top of the door hinge but most have the switch in the door fold area of the chassis some where.
If you find that the evaporator coils have iced up:
  • Perform a manual defrost of the unit but first unplugging it
  • Remove the freezer contents
  • Direct an external fan into the freezer compartment for just over 2 hrs. (makes a water mess)
  • After 2 hrs clean up the water mess and return the unit to normal service.
  • Watch after 3 days if the fresh food compartment once again starts warming up. If it does you have and automatic defrosting problem.
No ice noted:
  • Possible temp control problem (Thermostat / cold control or thermistor)
  • Possible Air Damper problem. There are 2 kinds of air dampers. One is electrically controlled and the other is nothing but a mechanical baffle that is positioned partially open. If you have the electrical type the air damper motor may have failed or the movable baffle is stuck.
Front of chassis is almost HOT to the touch vs warm:
  • Open the back of the unit by removing the black fiberboard cover and inspect for lint and that the condenser fan is running anytime the compressor is running.
Light always on:
  • Door switch failure. Some door switches also control the evaporator fan along with water in door and ice in door functions. The water and ice in door should NOT work with the door open.
The above is pretty much an in home repair techicians check list for the symptom you describe.
If you discover that you have an automatic defrosting problem I will need you MAKE & MODEL number via your next response here so I can tell you what you can do to troubleshoot. (
Thanks for choosing FixYa,
Kelly
Feb 28, 2011 | Microwave Ovens
I have a beko ab910 w . the top half of both the fridge and the freezer have defrosted whilst the bottom half of the freezer and the fridge are frozen .
Refrigerator
heatman101
Feb 20, 2011 | Microwave Ovens
The fridge section of my Candy CPCA270FFK frost free fridge freezer is cool but not cold whilst the freezer section is warm. The appliance is silent, the compressor is very hot to touch and the control...
IF THE COMPRESSOR IS TO HOT TO TOUCH WITH YOUR HAND MORE THEN LIKELY THE REED VALVES IN THE COMPRESSOR ARE PASSING HOT GAS BACK INTO THE COMPRESSOR AND HAS DAMAGED THE UNIT. MY ADVICE IS TO LOOK ON TOP OF THE COMPRESSOR GET THE MODEL# & SERIAL # & MAKE AND LOOK ON LINE AND GET A PRICE FOR A NEW COMPRESSOR, PENDING ON MAKE AND MODEL THEY RUN AROUND 3-4 HUNDRED DOLLARS JUST FOR COMPRESSOR INSTALL CAN COST MORE THEN THE COMPRESSOR UNLESS YOU KNOW SOME ONE WHO HAS THETOOLS TO DO IT RIGHT
Feb 05, 2011 | Microwave Ovens
I have a skandiluxe chest freezer and the orange light is on - is this right?
On my Skandiluxe CF309 chest freezer, the ORANGE LIGHT IS FAST FREEZE and should be depressed to quick freeze when adding newly bought items as the temperature will go up when you've opened the lid for prolonged periods. This is also used to drop the temperature when restoring after defrosting. REMEMBER TO TURN THIS OFF. Also, take note of the gauge in the inside of the freezer which tells you which setting to switch the dial to according to how full the freezer is, and therefore the most energy-efficient setting.
The red light is the warning or "alarm" and will light up when the temperature is too warm.
The green light is a "control" light and I can't remember what this is for, but I don't recall seeing it on in the 15yrs or so that I've had the freezer.
TO DEFROST:
(The drain comes out directly underneath the drain hole and there is no hose. Not a very helpful design. I found that if you tip the freezer forward and scoop out as much water as you can, then mop up the rest with a large bath towel, it should do the job.
BTW if you are planning to defrost the freezer (or any freezer for that matter), once you've switched it off, if you have access to a hand-held steamer, and place something like an empty plastic box to catch the ice (we used an unused litter tray as it's the perfect size to catch all the ice in an upright freezer), it saves a significant amount of time. If you don't have one, it's worth investing in a cheap one with the squeegee function so you can do all the nitty-gritty jobs around the house including the windows in no time and no elbow grease at all !!
Aug 12, 2010 | Microwave Ovens
Microwave Ovens Logo
99 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
